Transcoding MPEGTS Audio for LG Bluray BD570...
passat25
Post Sat May 21, 2011 9:06 am
I have wmv and mpegts files with VC1 encoded movies... I tried the Serviio DLNA Server, and I was able to make it transcode VC-1 encoded files properly. Below the Profile instruction I added to do that... But I am unable to get sound on the M2TS files, only video :( ... Am I missing something???... Help will be greatly appreciated...
<Profile id="8" name="LG BD player" extendsProfileId="1">
<Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video">
<Matches container="asf" />
<Video targetContainer="mpegts" targetVCodec="mpeg2video">
<Matches container="mpegts" vCodec="vc1" />
StartCodon
Post Sat May 21, 2011 4:17 pm
Re: Transcoding MPEGTS Audio for LG Bluray BD570...
Part of this might be due to the slightly broken xml you have - it should look more like this:
You had two video sections, which means the second <video></video> section wasn't getting any instructions as to the target audio codec. This will transcode the audio from all mpegts video files encoded with VC1 to AC3.
passat25
Post Sun May 22, 2011 5:28 am
StartCodon wrote:Part of this might be due to the slightly broken xml you have - it should look more like this:
It's just not working... I have tried it many times to no avail.. Are you sure you are not missing something on the xml profile you gave me???
Before, I was able to get at least the video on VC-1 files... This time, I am not getting anything... It's not transcoding at all... Not error message or anything..
There is something we are missing... I betcha it's just a little tweak here and there..
Let me know... Appreciated
Post Sun May 22, 2011 11:00 am
post ffmpeg -i of the file
Return to LG
