Moxi profile
ggendel
Post Sun May 22, 2011 3:49 pm
Moxi profile
Anyone have a profile for the Moxi DVR? I'm probably transcoding a lot of things that I don't need to but it's easier than identifying all the things that don't work.
Gary
Post Sun May 22, 2011 5:41 pm
Re: Moxi profile
We could help you to create your specific profile. First see my signatures links. And post here the result.
ggendel
Post Sun May 22, 2011 9:52 pm
Re: Moxi profile
I'm not sure why "Device Spy" can't see the Moxi. This is consistent with the logs errors from Serviio. Probably something funky with my router. However, I did get the Certificates for the Moxi and Moxi-Mate and attached them here.
REG68274221.pdf
Moxi DVR
(105.24 KiB) Downloaded 604 times
REG54502570.pdf
Moxi-Mate
(161.12 KiB) Downloaded 621 times
Post Mon May 23, 2011 7:57 am
Re: Moxi profile
0) What is your device model Moxi DVR or Moxi Mate ?
1) For "device autodetection", we need some "device header" information, for that enable detailed logging file and post here result (just after serviio starting).
2)You could start with "Generic Profile" and verify list native formats supported, for example format listed on the dlna certificat:
JPEG
MP3
MPEG_PS_NTSC
MPEG_TS_SD_*
MPEG_TS_HD_NA*
WMVHIGH
WMVMED
Then with unsupported file, provide "ffmpeg -i" result to create specific profile transcoding section.
ggendel
Post Mon May 23, 2011 7:16 pm
Re: Moxi profile
Illico wrote:0) What is your device model Moxi DVR or Moxi Mate ?
JPEG
MP3
MPEG_PS_NTSC
MPEG_TS_SD_*
MPEG_TS_HD_NA*
WMVHIGH
WMVMED
I have one of each. The Moxi Mate is a disk-less version of the Moxi DVR I use on a second display. The autodetection seems to be having issues with all of my devices. They always show up as "Unrecognized device". I've got a couple of Mac OS/X computers as well as the Moxi devices. The logs show:
2011-05-23 15:00:28,945 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://10.101.1.142:80/XD/DeviceDescription.xml
I can retrieve this file using wget as described in another thread talking about the Moxi, so I'm not sure why serviio can't. At least serviio sees the devices while the uPnP Device explorer can't.
That said, I'm running serviio on an OpenIndiana server. I remember reading something about uPnP issues on an earlier version of OpenSolaris so I'm going to open a discussion with their developers as well.
Post Mon May 23, 2011 7:23 pm
Re: Moxi profile
Illico wrote:1) For "device autodetection", we need some "device header" information, for that enable detailed logging file and post here result (just after serviio starting).
ggendel
Post Thu May 26, 2011 6:39 pm
Re: Moxi profile
I've attached the log, but I don't think it will help much. It just says it can't get the description file, but I can get it using wget.
BTW, this is an OpenIndiana machine, if that might help.
Gary
serviio.log.orig.gz
(1.65 KiB) Downloaded 607 times
Post Thu May 26, 2011 6:42 pm
Re: Moxi profile
can you turn on detailed logging? see my signature
ggendel
Post Thu May 26, 2011 7:53 pm
Re: Moxi profile
Whoops! I thought I did that. Here is the debug level output.
serviio.log.gz
(7.21 KiB) Downloaded 587 times
freeflysage
Post Sat Jan 19, 2013 12:51 am
Re: Moxi profile & general
I too have a semi rare moxi, and would love any info you have discovered regarding it and serviio. I currently have it set up and playing most things very well. I'd love some rare nuggets of info, and am currently trying to get the online transcoding working before my 15 day trial ends.
online transcoding of an mpg and or mov is showing this in the logs
2013-01-18 18:55:29,392 WARN [ServiioStatusService] IOException occured. Returning error code 500 to the REST layer. Message: Transcoded file '/tmp/Serviio/transcoding-temp-2886-flv_player-MEDIUM.stf' cannot be found, FFmpeg execution probably failed
I've compiled ffmpeg by hand from todays git
ffmpeg version N-48987-ge1d7d4b Copyright (c) 2000-2013 the FFmpeg developers
built on Jan 18 2013 11:04:22 with gcc 4.4.6 (GCC) 20120305 (Red Hat 4.4.6-4)
configuration: --enable-gpl --enable-postproc --enable-nonfree --enable-postproc --enable-libfaac --enable-avfilter --enable-pthreads --enable-libxvid --enable-libvpx --enable-librtmp
[root@dlna log]# lsb_release -a
LSB Version: :core-4.0-amd64:core-4.0-noarch:graphics-4.0-amd64:graphics-4.0-noarch:printing-4.0-amd64:printing-4.0-noarch
Distributor ID: OracleServer
Description: Oracle Linux Server release 6.3
Release: 6.3
Post Sat Jan 19, 2013 9:02 am
Re: Moxi profile
Moxi device could not be discovered by serviio, because it cannot retrieve device description DeviceDescription.xml
