Problem with some file formats
berni
Post Tue Mar 29, 2011 6:30 pm
i have a Sasmung UE40B7000. The Render Profile is detecting Samsung DTV DMR (this should be the right one for the TV).
But after selecting some Movies (mostly mkv) the TV shows that the videoformat is not supported or on other movies the audioformat is not supported.
The console output for some movies is
.... Cannot resolve DLNA format profile of the original file.
Is there an easy way out for me?
Cheers
Berni
Post Tue Mar 29, 2011 7:37 pm
Re: Problem with some file formats
No, as you have not provided any details of the files whatsoever. Check FAQ and HOWTO entries in the Support forum.
Samsnag
Post Mon May 16, 2011 9:05 pm
I have a similar problem with a Samsung LE32D580K2KXXU and a .mov file: it plays it from a USB stick, but not through Serviio, tho it shows up on the TV screen. The original was an .AVI file on a Fujifilm compact which I resaved as a .mov file, I think in Quicktime. NB I am a computer near-illiterate. Here is the detail from the cmd enquiry:
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Desmond>cd "\Program Files \Serviio\lib
C:\Program Files\Serviio\lib>ffmpeg.exe -i "C:\Documents and Settings\Desmond\My
Documents\My Videos\Snow over the back green (evening).mov"
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
Seems stream 0 codec frame rate differs from container frame rate: 600.00 (600/1
) -> 30.00 (30/1)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'C:\Documents and Settings\Desmond\My Do
cuments\My Videos\Snow over the back green (evening).mov':
major_brand : qt
minor_version : 537199360
compatible_brands: qt
creation_time : 2008-01-04 16:19:13
Duration: 00:00:30.00, start: 0.000000, bitrate: 9344 kb/s
Stream #0.0(eng): Video: mjpeg, yuvj422p, 640x480, 9213 kb/s, 30 fps, 30 tbr
, 600 tbn, 600 tbc
Stream #0.1(eng): Audio: pcm_u8, 16000 Hz, 1 channels, u8, 128 kb/s
C:\Program Files\Serviio\lib>^V
Post Mon May 16, 2011 10:55 pm
The file has to be transcoded, but this config is already in the Samsung B profile. make sure i's selected. If it still doesn't work, post detailed log.
Samsnag
Post Tue May 17, 2011 9:15 am
Thanks - how do I select a B profile if my TV is listed on the console as a C/D series?
Post Tue May 17, 2011 9:55 am
On console, click on profile name field: list of profiles appears, selected proper profile, save and restart serviio service.
Post Tue May 17, 2011 10:09 am
Samsnag wrote:Thanks - how do I select a B profile if my TV is listed on the console as a C/D series?
Sorry, I was looking at the guy before you. Your TV is D series so the profile is correct. Can you post detailed log of when you're trying to play the file to see if FFmpeg fails transcoding?
Samsnag
Post Tue May 17, 2011 10:27 am
Will do - may be a day or so before I can do this. Thanks meanwhile for instant response.
Samsnag
Post Sun May 22, 2011 8:49 pm
Hi again,
From my Samsung32D I have just tried to run 4 files in my video folder, only the last one ('Hogmanay fireworks') actually played. Two .avi files and two .mov files. Following what I think are the instructions for a detailed log, here is the log from what I've just done. Sure is big.
2011-05-22 21:10:16,390 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-05-22 21:10:16,390 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Range: bytes 14573505-21724142/21724143,Content-Length: 7150638,Date: Sun, 22 May 2011 20:10:16 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG4_P2_MP4_ASP_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-05-22 21:10:16,468 DEBUG [MediaItemDAOImpl] Getting file of media item 3005
2011-05-22 21:10:16,468 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3005) and extractor EMBEDDED
2011-05-22 21:10:16,515 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-05-22 21:10:16,531 DEBUG [WebServer] Incoming connection from /192.168.1.77:56837
2011-05-22 21:10:16,531 DEBUG [ResourceTransportRequestHandler] GET /resource/6836/MEDIA_ITEM/MPEG4_P2_MP4_ASP_AAC$0 HTTP/1.0, headers = [Range: bytes=14611424-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.64:8895]]
2011-05-22 21:10:16,531 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.77
2011-05-22 21:10:16,531 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:16,531 DEBUG [ResourceTransportRequestHandler] Request for resource 6836 and type 'MEDIA_ITEM' received
2011-05-22 21:10:16,531 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6836)
2011-05-22 21:10:16,531 DEBUG [VideoDAOImpl] Reading a Video (id = 6836)
2011-05-22 21:10:16,531 DEBUG [VideoDeliveryEngine] Delivering item '6836' for client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:16,531 DEBUG [VideoDeliveryEngine] Delivering file 'Hogmanay Fireworks.mov' in native format
2011-05-22 21:10:16,531 DEBUG [MediaItemDAOImpl] Getting file of media item 6836
2011-05-22 21:10:16,531 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 7112719
2011-05-22 21:10:16,531 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-05-22 21:10:16,531 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Range: bytes 14611424-21724142/21724143,Content-Length: 7112719,Date: Sun, 22 May 2011 20:10:16 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG4_P2_MP4_ASP_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-05-22 21:10:16,578 DEBUG [MediaItemDAOImpl] Getting file of media item 3006
2011-05-22 21:10:16,578 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3006) and extractor EMBEDDED
2011-05-22 21:10:16,671 DEBUG [MediaItemDAOImpl] Getting file of media item 3007
2011-05-22 21:10:16,671 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3007) and extractor EMBEDDED
2011-05-22 21:10:16,781 DEBUG [MediaItemDAOImpl] Getting file of media item 3008
2011-05-22 21:10:16,781 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3008) and extractor EMBEDDED
2011-05-22 21:10:16,875 DEBUG [MediaItemDAOImpl] Getting file of media item 3009
2011-05-22 21:10:16,875 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3009) and extractor EMBEDDED
2011-05-22 21:10:16,984 DEBUG [MediaItemDAOImpl] Getting file of media item 3010
2011-05-22 21:10:16,984 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3010) and extractor EMBEDDED
2011-05-22 21:10:17,078 DEBUG [MediaItemDAOImpl] Getting file of media item 3011
2011-05-22 21:10:17,078 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3011) and extractor EMBEDDED
2011-05-22 21:10:17,187 DEBUG [MediaItemDAOImpl] Getting file of media item 3012
2011-05-22 21:10:17,187 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3012) and extractor EMBEDDED
2011-05-22 21:10:17,281 DEBUG [MediaItemDAOImpl] Getting file of media item 3013
2011-05-22 21:10:17,281 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3013) and extractor EMBEDDED
2011-05-22 21:10:17,390 DEBUG [MediaItemDAOImpl] Getting file of media item 3014
2011-05-22 21:10:17,390 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3014) and extractor EMBEDDED
2011-05-22 21:10:17,484 DEBUG [MediaItemDAOImpl] Getting file of media item 3015
2011-05-22 21:10:17,484 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3015) and extractor EMBEDDED
2011-05-22 21:10:17,593 DEBUG [MediaItemDAOImpl] Getting file of media item 3016
2011-05-22 21:10:17,593 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3016) and extractor EMBEDDED
2011-05-22 21:10:17,687 DEBUG [MediaItemDAOImpl] Getting file of media item 3017
2011-05-22 21:10:17,687 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3017) and extractor EMBEDDED
2011-05-22 21:10:17,796 DEBUG [MediaItemDAOImpl] Getting file of media item 3018
2011-05-22 21:10:17,796 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3018) and extractor EMBEDDED
2011-05-22 21:10:17,890 DEBUG [MediaItemDAOImpl] Getting file of media item 3019
2011-05-22 21:10:17,890 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3019) and extractor EMBEDDED
2011-05-22 21:10:17,953 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-05-22 21:10:17,953 DEBUG [WebServer] Incoming connection from /192.168.1.77:47571
2011-05-22 21:10:17,953 DEBUG [ResourceTransportRequestHandler] GET /resource/6836/MEDIA_ITEM/MPEG4_P2_MP4_ASP_AAC$0 HTTP/1.0, headers = [Range: bytes=15036141-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.64:8895]]
2011-05-22 21:10:17,953 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.77
2011-05-22 21:10:17,953 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:17,953 DEBUG [ResourceTransportRequestHandler] Request for resource 6836 and type 'MEDIA_ITEM' received
2011-05-22 21:10:17,953 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6836)
2011-05-22 21:10:17,953 DEBUG [VideoDAOImpl] Reading a Video (id = 6836)
2011-05-22 21:10:17,953 DEBUG [VideoDeliveryEngine] Delivering item '6836' for client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:17,953 DEBUG [VideoDeliveryEngine] Delivering file 'Hogmanay Fireworks.mov' in native format
2011-05-22 21:10:17,953 DEBUG [MediaItemDAOImpl] Getting file of media item 6836
2011-05-22 21:10:17,953 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 6688002
2011-05-22 21:10:17,953 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-05-22 21:10:17,953 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Range: bytes 15036141-21724142/21724143,Content-Length: 6688002,Date: Sun, 22 May 2011 20:10:17 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG4_P2_MP4_ASP_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-05-22 21:10:18,000 DEBUG [MediaItemDAOImpl] Getting file of media item 3020
2011-05-22 21:10:18,000 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3020) and extractor EMBEDDED
2011-05-22 21:10:18,031 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-05-22 21:10:18,046 DEBUG [WebServer] Incoming connection from /192.168.1.77:40817
2011-05-22 21:10:18,046 DEBUG [ResourceTransportRequestHandler] GET /resource/6836/MEDIA_ITEM/MPEG4_P2_MP4_ASP_AAC$0 HTTP/1.0, headers = [Range: bytes=15119323-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.64:8895]]
2011-05-22 21:10:18,046 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.77
2011-05-22 21:10:18,046 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:18,046 DEBUG [ResourceTransportRequestHandler] Request for resource 6836 and type 'MEDIA_ITEM' received
2011-05-22 21:10:18,046 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6836)
2011-05-22 21:10:18,046 DEBUG [VideoDAOImpl] Reading a Video (id = 6836)
2011-05-22 21:10:18,046 DEBUG [VideoDeliveryEngine] Delivering item '6836' for client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:18,046 DEBUG [VideoDeliveryEngine] Delivering file 'Hogmanay Fireworks.mov' in native format
2011-05-22 21:10:18,046 DEBUG [MediaItemDAOImpl] Getting file of media item 6836
2011-05-22 21:10:18,046 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 6604820
2011-05-22 21:10:18,046 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-05-22 21:10:18,046 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Range: bytes 15119323-21724142/21724143,Content-Length: 6604820,Date: Sun, 22 May 2011 20:10:18 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG4_P2_MP4_ASP_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-05-22 21:10:18,093 DEBUG [MediaItemDAOImpl] Getting file of media item 3021
2011-05-22 21:10:18,093 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3021) and extractor EMBEDDED
2011-05-22 21:10:18,171 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-05-22 21:10:18,171 DEBUG [WebServer] Incoming connection from /192.168.1.77:32813
2011-05-22 21:10:18,171 DEBUG [ResourceTransportRequestHandler] GET /resource/6836/MEDIA_ITEM/MPEG4_P2_MP4_ASP_AAC$0 HTTP/1.0, headers = [Range: bytes=15205218-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.64:8895]]
2011-05-22 21:10:18,171 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.77
2011-05-22 21:10:18,171 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:18,171 DEBUG [ResourceTransportRequestHandler] Request for resource 6836 and type 'MEDIA_ITEM' received
2011-05-22 21:10:18,171 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6836)
2011-05-22 21:10:18,171 DEBUG [VideoDAOImpl] Reading a Video (id = 6836)
2011-05-22 21:10:18,171 DEBUG [VideoDeliveryEngine] Delivering item '6836' for client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:18,171 DEBUG [VideoDeliveryEngine] Delivering file 'Hogmanay Fireworks.mov' in native format
2011-05-22 21:10:18,171 DEBUG [MediaItemDAOImpl] Getting file of media item 6836
2011-05-22 21:10:18,171 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 6518925
2011-05-22 21:10:18,171 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-05-22 21:10:18,171 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Range: bytes 15205218-21724142/21724143,Content-Length: 6518925,Date: Sun, 22 May 2011 20:10:18 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG4_P2_MP4_ASP_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-05-22 21:10:18,203 DEBUG [MediaItemDAOImpl] Getting file of media item 3022
2011-05-22 21:10:18,203 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3022) and extractor EMBEDDED
2011-05-22 21:10:18,296 DEBUG [MediaItemDAOImpl] Getting file of media item 3023
2011-05-22 21:10:18,296 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3023) and extractor EMBEDDED
2011-05-22 21:10:18,312 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-05-22 21:10:18,328 DEBUG [WebServer] Incoming connection from /192.168.1.77:50716
2011-05-22 21:10:18,328 DEBUG [ResourceTransportRequestHandler] GET /resource/6836/MEDIA_ITEM/MPEG4_P2_MP4_ASP_AAC$0 HTTP/1.0, headers = [Range: bytes=15264514-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.64:8895]]
2011-05-22 21:10:18,328 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.77
2011-05-22 21:10:18,328 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:18,328 DEBUG [ResourceTransportRequestHandler] Request for resource 6836 and type 'MEDIA_ITEM' received
2011-05-22 21:10:18,328 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6836)
2011-05-22 21:10:18,328 DEBUG [VideoDAOImpl] Reading a Video (id = 6836)
2011-05-22 21:10:18,328 DEBUG [VideoDeliveryEngine] Delivering item '6836' for client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:18,328 DEBUG [VideoDeliveryEngine] Delivering file 'Hogmanay Fireworks.mov' in native format
2011-05-22 21:10:18,328 DEBUG [MediaItemDAOImpl] Getting file of media item 6836
2011-05-22 21:10:18,328 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 6459629
2011-05-22 21:10:18,328 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-05-22 21:10:18,328 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Range: bytes 15264514-21724142/21724143,Content-Length: 6459629,Date: Sun, 22 May 2011 20:10:18 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG4_P2_MP4_ASP_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-05-22 21:10:18,406 DEBUG [MediaItemDAOImpl] Getting file of media item 3024
2011-05-22 21:10:18,406 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3024) and extractor EMBEDDED
2011-05-22 21:10:18,500 DEBUG [MediaItemDAOImpl] Getting file of media item 3025
2011-05-22 21:10:18,500 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3025) and extractor EMBEDDED
2011-05-22 21:10:18,609 DEBUG [MediaItemDAOImpl] Getting file of media item 3026
2011-05-22 21:10:18,609 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3026) and extractor EMBEDDED
2011-05-22 21:10:18,703 DEBUG [MediaItemDAOImpl] Getting file of media item 3027
2011-05-22 21:10:18,703 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3027) and extractor EMBEDDED
2011-05-22 21:10:18,812 DEBUG [MediaItemDAOImpl] Getting file of media item 3028
2011-05-22 21:10:18,812 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3028) and extractor EMBEDDED
2011-05-22 21:10:18,906 DEBUG [MediaItemDAOImpl] Getting file of media item 3029
2011-05-22 21:10:18,906 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3029) and extractor EMBEDDED
2011-05-22 21:10:19,015 DEBUG [MediaItemDAOImpl] Getting file of media item 3030
2011-05-22 21:10:19,015 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3030) and extractor EMBEDDED
2011-05-22 21:10:19,109 DEBUG [MediaItemDAOImpl] Getting file of media item 3031
2011-05-22 21:10:19,109 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3031) and extractor EMBEDDED
2011-05-22 21:10:19,218 DEBUG [MediaItemDAOImpl] Getting file of media item 3032
2011-05-22 21:10:19,218 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3032) and extractor EMBEDDED
2011-05-22 21:10:19,312 DEBUG [MediaItemDAOImpl] Getting file of media item 3033
2011-05-22 21:10:19,312 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3033) and extractor EMBEDDED
2011-05-22 21:10:19,421 DEBUG [MediaItemDAOImpl] Getting file of media item 3034
2011-05-22 21:10:19,421 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3034) and extractor EMBEDDED
2011-05-22 21:10:19,515 DEBUG [MediaItemDAOImpl] Getting file of media item 3035
2011-05-22 21:10:19,515 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3035) and extractor EMBEDDED
2011-05-22 21:10:19,625 DEBUG [MediaItemDAOImpl] Getting file of media item 3036
2011-05-22 21:10:19,625 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3036) and extractor EMBEDDED
2011-05-22 21:10:19,671 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-05-22 21:10:19,671 DEBUG [WebServer] Incoming connection from /192.168.1.77:34492
2011-05-22 21:10:19,671 DEBUG [ResourceTransportRequestHandler] GET /resource/6836/MEDIA_ITEM/MPEG4_P2_MP4_ASP_AAC$0 HTTP/1.0, headers = [Range: bytes=15546847-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.64:8895]]
2011-05-22 21:10:19,671 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.77
2011-05-22 21:10:19,671 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:19,671 DEBUG [ResourceTransportRequestHandler] Request for resource 6836 and type 'MEDIA_ITEM' received
2011-05-22 21:10:19,671 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6836)
2011-05-22 21:10:19,671 DEBUG [VideoDAOImpl] Reading a Video (id = 6836)
2011-05-22 21:10:19,671 DEBUG [VideoDeliveryEngine] Delivering item '6836' for client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:19,671 DEBUG [VideoDeliveryEngine] Delivering file 'Hogmanay Fireworks.mov' in native format
2011-05-22 21:10:19,671 DEBUG [MediaItemDAOImpl] Getting file of media item 6836
2011-05-22 21:10:19,671 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 6177296
2011-05-22 21:10:19,671 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-05-22 21:10:19,671 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Range: bytes 15546847-21724142/21724143,Content-Length: 6177296,Date: Sun, 22 May 2011 20:10:19 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG4_P2_MP4_ASP_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-05-22 21:10:19,718 DEBUG [MediaItemDAOImpl] Getting file of media item 3037
2011-05-22 21:10:19,718 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3037) and extractor EMBEDDED
2011-05-22 21:10:19,734 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-05-22 21:10:19,750 DEBUG [WebServer] Incoming connection from /192.168.1.77:45345
2011-05-22 21:10:19,750 DEBUG [ResourceTransportRequestHandler] GET /resource/6836/MEDIA_ITEM/MPEG4_P2_MP4_ASP_AAC$0 HTTP/1.0, headers = [Range: bytes=15585346-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.64:8895]]
2011-05-22 21:10:19,750 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.77
2011-05-22 21:10:19,750 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:19,750 DEBUG [ResourceTransportRequestHandler] Request for resource 6836 and type 'MEDIA_ITEM' received
2011-05-22 21:10:19,750 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6836)
2011-05-22 21:10:19,750 DEBUG [VideoDAOImpl] Reading a Video (id = 6836)
2011-05-22 21:10:19,750 DEBUG [VideoDeliveryEngine] Delivering item '6836' for client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:19,750 DEBUG [VideoDeliveryEngine] Delivering file 'Hogmanay Fireworks.mov' in native format
2011-05-22 21:10:19,750 DEBUG [MediaItemDAOImpl] Getting file of media item 6836
2011-05-22 21:10:19,750 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 6138797
2011-05-22 21:10:19,750 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-05-22 21:10:19,750 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Range: bytes 15585346-21724142/21724143,Content-Length: 6138797,Date: Sun, 22 May 2011 20:10:19 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG4_P2_MP4_ASP_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-05-22 21:10:19,828 DEBUG [MediaItemDAOImpl] Getting file of media item 3038
2011-05-22 21:10:19,828 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3038) and extractor EMBEDDED
2011-05-22 21:10:19,875 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-05-22 21:10:19,875 DEBUG [WebServer] Incoming connection from /192.168.1.77:60256
2011-05-22 21:10:19,875 DEBUG [ResourceTransportRequestHandler] GET /resource/6836/MEDIA_ITEM/MPEG4_P2_MP4_ASP_AAC$0 HTTP/1.0, headers = [Range: bytes=15628192-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.64:8895]]
2011-05-22 21:10:19,875 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.77
2011-05-22 21:10:19,875 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:19,875 DEBUG [ResourceTransportRequestHandler] Request for resource 6836 and type 'MEDIA_ITEM' received
2011-05-22 21:10:19,875 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6836)
2011-05-22 21:10:19,875 DEBUG [VideoDAOImpl] Reading a Video (id = 6836)
2011-05-22 21:10:19,875 DEBUG [VideoDeliveryEngine] Delivering item '6836' for client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:19,875 DEBUG [VideoDeliveryEngine] Delivering file 'Hogmanay Fireworks.mov' in native format
2011-05-22 21:10:19,875 DEBUG [MediaItemDAOImpl] Getting file of media item 6836
2011-05-22 21:10:19,875 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 6095951
2011-05-22 21:10:19,875 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-05-22 21:10:19,875 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Range: bytes 15628192-21724142/21724143,Content-Length: 6095951,Date: Sun, 22 May 2011 20:10:19 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG4_P2_MP4_ASP_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-05-22 21:10:19,921 DEBUG [MediaItemDAOImpl] Getting file of media item 3039
2011-05-22 21:10:19,921 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3039) and extractor EMBEDDED
2011-05-22 21:10:20,031 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-05-22 21:10:20,031 DEBUG [MediaItemDAOImpl] Getting file of media item 3040
2011-05-22 21:10:20,031 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3040) and extractor EMBEDDED
2011-05-22 21:10:20,031 DEBUG [WebServer] Incoming connection from /192.168.1.77:55610
2011-05-22 21:10:20,031 DEBUG [ResourceTransportRequestHandler] GET /resource/6836/MEDIA_ITEM/MPEG4_P2_MP4_ASP_AAC$0 HTTP/1.0, headers = [Range: bytes=15668327-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.64:8895]]
2011-05-22 21:10:20,031 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.77
2011-05-22 21:10:20,031 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:20,031 DEBUG [ResourceTransportRequestHandler] Request for resource 6836 and type 'MEDIA_ITEM' received
2011-05-22 21:10:20,031 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6836)
2011-05-22 21:10:20,031 DEBUG [VideoDAOImpl] Reading a Video (id = 6836)
2011-05-22 21:10:20,031 DEBUG [VideoDeliveryEngine] Delivering item '6836' for client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:20,031 DEBUG [VideoDeliveryEngine] Delivering file 'Hogmanay Fireworks.mov' in native format
2011-05-22 21:10:20,031 DEBUG [MediaItemDAOImpl] Getting file of media item 6836
2011-05-22 21:10:20,031 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 6055816
2011-05-22 21:10:20,031 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-05-22 21:10:20,031 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Range: bytes 15668327-21724142/21724143,Content-Length: 6055816,Date: Sun, 22 May 2011 20:10:20 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG4_P2_MP4_ASP_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-05-22 21:10:20,125 DEBUG [MediaItemDAOImpl] Getting file of media item 3041
2011-05-22 21:10:20,125 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3041) and extractor EMBEDDED
2011-05-22 21:10:20,234 DEBUG [MediaItemDAOImpl] Getting file of media item 3042
2011-05-22 21:10:20,234 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3042) and extractor EMBEDDED
2011-05-22 21:10:20,343 DEBUG [MediaItemDAOImpl] Getting file of media item 3043
2011-05-22 21:10:20,343 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3043) and extractor EMBEDDED
2011-05-22 21:10:20,437 DEBUG [MediaItemDAOImpl] Getting file of media item 3044
2011-05-22 21:10:20,437 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3044) and extractor EMBEDDED
2011-05-22 21:10:20,546 DEBUG [MediaItemDAOImpl] Getting file of media item 3045
2011-05-22 21:10:20,546 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3045) and extractor EMBEDDED
2011-05-22 21:10:20,640 DEBUG [MediaItemDAOImpl] Getting file of media item 3046
2011-05-22 21:10:20,640 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3046) and extractor EMBEDDED
2011-05-22 21:10:20,750 DEBUG [MediaItemDAOImpl] Getting file of media item 3047
2011-05-22 21:10:20,750 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3047) and extractor EMBEDDED
2011-05-22 21:10:20,843 DEBUG [MediaItemDAOImpl] Getting file of media item 3048
2011-05-22 21:10:20,843 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3048) and extractor EMBEDDED
2011-05-22 21:10:20,953 DEBUG [MediaItemDAOImpl] Getting file of media item 3049
2011-05-22 21:10:20,953 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3049) and extractor EMBEDDED
2011-05-22 21:10:21,046 DEBUG [MediaItemDAOImpl] Getting file of media item 3050
2011-05-22 21:10:21,046 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3050) and extractor EMBEDDED
2011-05-22 21:10:21,109 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (NETGEAR WN121T Wireless USB 2.0 Adapter #3 - Packet Scheduler Miniport) and address 192.168.1.64, timeout = 0
2011-05-22 21:10:21,109 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 0121ef4a-a8e4-3075-80ee-802b5f459d46
2011-05-22 21:10:21,156 DEBUG [MediaItemDAOImpl] Getting file of media item 3051
2011-05-22 21:10:21,156 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3051) and extractor EMBEDDED
2011-05-22 21:10:21,250 DEBUG [MediaItemDAOImpl] Getting file of media item 3052
2011-05-22 21:10:21,250 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3052) and extractor EMBEDDED
2011-05-22 21:10:21,359 DEBUG [MediaItemDAOImpl] Getting file of media item 3053
2011-05-22 21:10:21,359 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3053) and extractor EMBEDDED
2011-05-22 21:10:21,453 DEBUG [MediaItemDAOImpl] Getting file of media item 3054
2011-05-22 21:10:21,453 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3054) and extractor EMBEDDED
2011-05-22 21:10:21,562 DEBUG [MediaItemDAOImpl] Getting file of media item 3055
2011-05-22 21:10:21,562 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3055) and extractor EMBEDDED
2011-05-22 21:10:21,656 DEBUG [MediaItemDAOImpl] Getting file of media item 3056
2011-05-22 21:10:21,656 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3056) and extractor EMBEDDED
2011-05-22 21:10:21,765 DEBUG [MediaItemDAOImpl] Getting file of media item 3057
2011-05-22 21:10:21,765 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3057) and extractor EMBEDDED
2011-05-22 21:10:21,859 DEBUG [MediaItemDAOImpl] Getting file of media item 3058
2011-05-22 21:10:21,859 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3058) and extractor EMBEDDED
2011-05-22 21:10:21,968 DEBUG [MediaItemDAOImpl] Getting file of media item 3059
2011-05-22 21:10:21,968 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3059) and extractor EMBEDDED
2011-05-22 21:10:22,062 DEBUG [MediaItemDAOImpl] Getting file of media item 3060
2011-05-22 21:10:22,062 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3060) and extractor EMBEDDED
2011-05-22 21:10:22,171 DEBUG [MediaItemDAOImpl] Getting file of media item 3061
2011-05-22 21:10:22,171 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3061) and extractor EMBEDDED
2011-05-22 21:10:22,296 DEBUG [MediaItemDAOImpl] Getting file of media item 3062
2011-05-22 21:10:22,296 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3062) and extractor EMBEDDED
2011-05-22 21:10:22,390 DEBUG [MediaItemDAOImpl] Getting file of media item 3063
2011-05-22 21:10:22,390 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3063) and extractor EMBEDDED
2011-05-22 21:10:22,406 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-05-22 21:10:22,406 DEBUG [WebServer] Incoming connection from /192.168.1.77:38437
2011-05-22 21:10:22,406 DEBUG [ResourceTransportRequestHandler] GET /resource/6836/MEDIA_ITEM/MPEG4_P2_MP4_ASP_AAC$0 HTTP/1.0, headers = [Range: bytes=16159898-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.64:8895]]
2011-05-22 21:10:22,406 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.77
2011-05-22 21:10:22,406 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:22,406 DEBUG [ResourceTransportRequestHandler] Request for resource 6836 and type 'MEDIA_ITEM' received
2011-05-22 21:10:22,406 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6836)
2011-05-22 21:10:22,406 DEBUG [VideoDAOImpl] Reading a Video (id = 6836)
2011-05-22 21:10:22,406 DEBUG [VideoDeliveryEngine] Delivering item '6836' for client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:22,406 DEBUG [VideoDeliveryEngine] Delivering file 'Hogmanay Fireworks.mov' in native format
2011-05-22 21:10:22,406 DEBUG [MediaItemDAOImpl] Getting file of media item 6836
2011-05-22 21:10:22,406 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 5564245
2011-05-22 21:10:22,406 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-05-22 21:10:22,406 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Range: bytes 16159898-21724142/21724143,Content-Length: 5564245,Date: Sun, 22 May 2011 20:10:22 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG4_P2_MP4_ASP_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-05-22 21:10:22,500 DEBUG [MediaItemDAOImpl] Getting file of media item 3064
2011-05-22 21:10:22,500 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3064) and extractor EMBEDDED
2011-05-22 21:10:22,593 DEBUG [MediaItemDAOImpl] Getting file of media item 3065
2011-05-22 21:10:22,593 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3065) and extractor EMBEDDED
2011-05-22 21:10:22,703 DEBUG [MediaItemDAOImpl] Getting file of media item 3066
2011-05-22 21:10:22,703 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3066) and extractor EMBEDDED
2011-05-22 21:10:22,796 DEBUG [MediaItemDAOImpl] Getting file of media item 3067
2011-05-22 21:10:22,796 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3067) and extractor EMBEDDED
2011-05-22 21:10:22,828 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-05-22 21:10:22,828 DEBUG [WebServer] Incoming connection from /192.168.1.77:38254
2011-05-22 21:10:22,843 DEBUG [ResourceTransportRequestHandler] GET /resource/6836/MEDIA_ITEM/MPEG4_P2_MP4_ASP_AAC$0 HTTP/1.0, headers = [Range: bytes=16044941-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.64:8895]]
2011-05-22 21:10:22,843 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.77
2011-05-22 21:10:22,843 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:22,843 DEBUG [ResourceTransportRequestHandler] Request for resource 6836 and type 'MEDIA_ITEM' received
2011-05-22 21:10:22,843 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6836)
2011-05-22 21:10:22,843 DEBUG [VideoDAOImpl] Reading a Video (id = 6836)
2011-05-22 21:10:22,843 DEBUG [VideoDeliveryEngine] Delivering item '6836' for client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:22,843 DEBUG [VideoDeliveryEngine] Delivering file 'Hogmanay Fireworks.mov' in native format
2011-05-22 21:10:22,843 DEBUG [MediaItemDAOImpl] Getting file of media item 6836
2011-05-22 21:10:22,843 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 5679202
2011-05-22 21:10:22,843 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-05-22 21:10:22,843 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Range: bytes 16044941-21724142/21724143,Content-Length: 5679202,Date: Sun, 22 May 2011 20:10:22 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG4_P2_MP4_ASP_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-05-22 21:10:22,906 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-05-22 21:10:22,906 DEBUG [MediaItemDAOImpl] Getting file of media item 3068
2011-05-22 21:10:22,906 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3068) and extractor EMBEDDED
2011-05-22 21:10:22,921 DEBUG [WebServer] Incoming connection from /192.168.1.77:37066
2011-05-22 21:10:22,921 DEBUG [ResourceTransportRequestHandler] GET /resource/6836/MEDIA_ITEM/MPEG4_P2_MP4_ASP_AAC$0 HTTP/1.0, headers = [Range: bytes=16099561-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.64:8895]]
2011-05-22 21:10:22,921 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.77
2011-05-22 21:10:22,921 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:22,921 DEBUG [ResourceTransportRequestHandler] Request for resource 6836 and type 'MEDIA_ITEM' received
2011-05-22 21:10:22,921 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6836)
2011-05-22 21:10:22,921 DEBUG [VideoDAOImpl] Reading a Video (id = 6836)
2011-05-22 21:10:22,921 DEBUG [VideoDeliveryEngine] Delivering item '6836' for client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:22,921 DEBUG [VideoDeliveryEngine] Delivering file 'Hogmanay Fireworks.mov' in native format
2011-05-22 21:10:22,921 DEBUG [MediaItemDAOImpl] Getting file of media item 6836
2011-05-22 21:10:22,921 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 5624582
2011-05-22 21:10:22,921 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-05-22 21:10:22,921 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Range: bytes 16099561-21724142/21724143,Content-Length: 5624582,Date: Sun, 22 May 2011 20:10:22 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG4_P2_MP4_ASP_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-05-22 21:10:22,921 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:16
2011-05-22 21:10:23,000 DEBUG [MediaItemDAOImpl] Getting file of media item 3069
2011-05-22 21:10:23,000 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3069) and extractor EMBEDDED
2011-05-22 21:10:23,046 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-05-22 21:10:23,062 DEBUG [WebServer] Incoming connection from /192.168.1.77:54282
2011-05-22 21:10:23,062 DEBUG [ResourceTransportRequestHandler] GET /resource/6836/MEDIA_ITEM/MPEG4_P2_MP4_ASP_AAC$0 HTTP/1.0, headers = [Range: bytes=16155968-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.64:8895]]
2011-05-22 21:10:23,062 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.77
2011-05-22 21:10:23,062 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:23,062 DEBUG [ResourceTransportRequestHandler] Request for resource 6836 and type 'MEDIA_ITEM' received
2011-05-22 21:10:23,062 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6836)
2011-05-22 21:10:23,062 DEBUG [VideoDAOImpl] Reading a Video (id = 6836)
2011-05-22 21:10:23,062 DEBUG [VideoDeliveryEngine] Delivering item '6836' for client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:23,062 DEBUG [VideoDeliveryEngine] Delivering file 'Hogmanay Fireworks.mov' in native format
2011-05-22 21:10:23,062 DEBUG [MediaItemDAOImpl] Getting file of media item 6836
2011-05-22 21:10:23,062 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 5568175
2011-05-22 21:10:23,062 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-05-22 21:10:23,062 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Range: bytes 16155968-21724142/21724143,Content-Length: 5568175,Date: Sun, 22 May 2011 20:10:23 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG4_P2_MP4_ASP_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-05-22 21:10:23,109 DEBUG [MediaItemDAOImpl] Getting file of media item 3070
2011-05-22 21:10:23,109 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3070) and extractor EMBEDDED
2011-05-22 21:10:23,203 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-05-22 21:10:23,203 DEBUG [WebServer] Incoming connection from /192.168.1.77:34402
2011-05-22 21:10:23,203 DEBUG [ResourceTransportRequestHandler] GET /resource/6836/MEDIA_ITEM/MPEG4_P2_MP4_ASP_AAC$0 HTTP/1.0, headers = [Range: bytes=16204246-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.1.64:8895]]
2011-05-22 21:10:23,203 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.77
2011-05-22 21:10:23,203 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:23,203 DEBUG [ResourceTransportRequestHandler] Request for resource 6836 and type 'MEDIA_ITEM' received
2011-05-22 21:10:23,203 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 6836)
2011-05-22 21:10:23,203 DEBUG [VideoDAOImpl] Reading a Video (id = 6836)
2011-05-22 21:10:23,203 DEBUG [VideoDeliveryEngine] Delivering item '6836' for client 'IPAddress=/192.168.1.77, Profile=Samsung TV / player (C/D-series)'
2011-05-22 21:10:23,203 DEBUG [VideoDeliveryEngine] Delivering file 'Hogmanay Fireworks.mov' in native format
2011-05-22 21:10:23,203 DEBUG [MediaItemDAOImpl] Getting file of media item 6836
2011-05-22 21:10:23,203 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 5519897
2011-05-22 21:10:23,203 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-05-22 21:10:23,203 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mp4,Content-Range: bytes 16204246-21724142/21724143,Content-Length: 5519897,Date: Sun, 22 May 2011 20:10:23 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG4_P2_MP4_ASP_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-05-22 21:10:23,203 DEBUG [MediaItemDAOImpl] Getting file of media item 3071
2011-05-22 21:10:23,203 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3071) and extractor EMBEDDED
2011-05-22 21:10:23,312 DEBUG [MediaItemDAOImpl] Getting file of media item 3072
2011-05-22 21:10:23,312 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3072) and extractor EMBEDDED
2011-05-22 21:10:23,406 DEBUG [MediaItemDAOImpl] Getting file of media item 3073
2011-05-22 21:10:23,406 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3073) and extractor EMBEDDED
2011-05-22 21:10:23,515 DEBUG [MediaItemDAOImpl] Getting file of media item 3074
2011-05-22 21:10:23,515 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3074) and extractor EMBEDDED
2011-05-22 21:10:23,609 DEBUG [MediaItemDAOImpl] Getting file of media item 3075
2011-05-22 21:10:23,609 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3075) and extractor EMBEDDED
2011-05-22 21:10:23,718 DEBUG [MediaItemDAOImpl] Getting file of media item 3076
Post Sun May 22, 2011 8:55 pm
This log shows delivery of file Hogmanay Fireworks.mov, which is not the one you posted the ffmpeg details of. Anyway, for this one there is no transcoding going on so I can only assume the file is encoded in a way the TV doesn't like.
Samsnag
Post Sun May 22, 2011 8:57 pm
No, this is the one that played. Why hasn't the log noted the three I selected for which I got 'Wrong file format' or 'Wrong video codec'?
Samsnag
Post Sun May 22, 2011 9:30 pm
It seems that when I try to play a file which says 'file format not supported', nothing turns up in the log - when I look at it, it's all about 'checking if xyz is in the library' - the 'refresh' function presumably. Is there any more help I can give?
Post Sun May 22, 2011 11:44 pm
Can you follow this and post the device's supported formats? viewtopic.php?f=5&t=19
Samsnag
Post Mon May 23, 2011 1:55 pm
Heretis! Thanks again.
http-get:*:audio/L16:DLNA.ORG_PN=LPCM;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM_ICO,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG_ICO,
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3X;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG1;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_XAC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_XAC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_XAC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_XAC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_XAC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_XAC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_XAC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_XAC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_MP_LL_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_MP_LL_AAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_MP_LL_AAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_ES_PAL;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_ES_NTSC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_ES_PAL_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_ES_NTSC_XAC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_L2_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_L2_AMR;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_L5_SO_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_L4_SO_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_P2_3GPP_SP_L0B_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_P2_3GPP_SP_L0B_AMR;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_MPEG1_L3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_MPEG1_L3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT7;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT7_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_LTP_MULT7_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_LTP_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_LTP_MULT7;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L3L_SD_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L3_SD_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_MPEG1_L3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_MPEG1_L3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_LTP_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_940;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_940_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF30_AAC_940_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AAC_LTP_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L2_CIF30_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_BSAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_BSAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF30_AAC_940;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_MPEG1_L3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_MPEG1_L3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_MPEG1_L3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AC3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AC3_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AC3_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT5;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT5_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT5_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT7;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT7_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_LTP_MULT7_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_540;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_540_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_540_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_LTP_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF15_AAC_LTP_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_BSAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_BL_CIF15_BSAC_T;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_BL_CIF15_BSAC_ISO;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_520;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_LTP_520;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_BSAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_QCIF15_AAC;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_QCIF15_AAC_LTP;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPLL_BASE;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_BASE;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_MP3;DLNA.ORG_FLAGS=ED100000000000000000000000000000,
http-get:*:text/xml:SEC.COM_DIDLSIMAGE=1;SEC.COM_DIDLSAUDIO=1;SEC.COM_DIDLSVIDEO=1,
http-get:*:image/jpeg:*,
http-get:*:audio/mpeg:*,
http-get:*:video/x-msvideo:*,
http-get:*:video/x-ms-asf:*,
http-get:*:video/x-divx:*,
http-get:*:video/x-ms-wmv:*,
http-get:*:video/x-mkv:*,
http-get:*:video/mp4:*,
http-get:*:video/x-avi:*,
http-get:*:video/avi:*,
http-get:*:video/x-flv:*,
http-get:*:video/mpeg:*,
http-get:*:video/3gpp:*
Post Mon May 23, 2011 2:55 pm
Re: Problem with some file formats
Can you run Intel's AV Media Controller, find the file in Serviio's library, get it's properties and find the Resource representing the file - then post the protocol-info value here.
Samsnag
Post Mon May 23, 2011 6:26 pm
Intel's AV Media....jpg (131.9 KiB) Viewed 24487 times
Not sure which is the protocol info, so here's a screenshot:
Samsnag
Post Mon May 23, 2011 6:37 pm
I think this is the one you want, of an .avi file that didn't run on the TV.
Intel's AV Media....Cottesloe avi.jpg (140.05 KiB) Viewed 24487 times
Post Mon May 23, 2011 8:14 pm
Does this file play with Samsung's PC Share manager? If yes, post the same screenshot for the file as served by it.
Samsnag
Post Mon May 23, 2011 10:22 pm
Intel's AV Media....Allshare without Serviio.jpg (218.95 KiB) Viewed 24482 times
No, it doesn't play -'Not supported file format' message appears on TV. Here's screenshots of them together:
Post Mon May 23, 2011 10:48 pm
I see only 1 difference there and that will be changed in the first 0.6 beta. Send me a PM if you want to test it when it's out.
Users browsing this forum: Baidu [Spider], Google [Bot] and 46 guests
