streaming digital audio direct from an A/D converter in RT?
n3mmr
Post Mon May 23, 2011 3:29 pm
Could one stream digital audio directly, in real time, through serviio, from a USB-attached sound card??
I realised it would be neat to have a bunch of small-to-tiny hosts running DLNA servers, and streaming audio and/or low frequency measurement data to DLNA-enabled presentation devices, all over 100Mb/s or Gb/s TCP/IP.
So, is serviio efficient enough for this, and would it be easy to make serviio pick up a digital audio stream on the server host and forward it unadulterated to DLNA renderers?
Post Mon May 23, 2011 3:44 pm
Re: streaming digital audio direct from an A/D converter in
Not at the moment, maybe when rtmp streams are supported.
Return to Feature requests
