Which NAS can be used with Serviio
Mart360
Post Sun May 01, 2011 3:48 pm
Perhaps i should rephrase it :)
Which NAS units will Serviio run on in standalone mode. (IE without needing a PC to run the SW)
There's loads of NAS units out there, but i don't want to buy one, and find i cant run Serviio from it, but have to use there own inbuilt system, which may net be as good as Serviio at doing its delivery coding etc
Mart
KeithDigital
Post Mon May 23, 2011 2:29 am
Re: Which NAS can be used with Serviio
I'd like to know which NAS you guys recommend for Serviio too?
Easiest to setup. Works great, even with .mkv files, etc.
Mart360
Post Mon May 23, 2011 6:36 pm
Looks like ive dropped another clanger :( just won a theacus NAS on the bay, only to find i'd been bidding on the wrong one..
looks like another paperweight for the office lol, unless i can get linux / serviio to fit
Mart
individual
Post Tue May 24, 2011 5:47 am
I have it installed on Synology DS211+. It works fine.
NAS: DS712+, 2x Seagate ST2000DL003
DLNA Server: Synology, Serviio, Twonky, Plex
DLNA Player: Raspberry Pi Raspbmc
DLNA Tablet: Yatse
Mart360
Post Sat May 28, 2011 11:06 am
Well the Thecus works.... but... its a pig to configure / see in the network (there's a surprise)
just installed freenas on the shuttle pc i bought so far its looking ok ...
now to shoehorn servioo on the back of the install
Mart
patters
Post Tue Jun 07, 2011 8:19 pm
If you're looking to buy a NAS specifically for Serviio then your best bet will be the QNAP or Synology ones in the HOWTO sticky topics in this forum. If there's a guide then it's confirmed working!
