Problem with 1080p MKV
Elurian
Post Thu May 26, 2011 12:01 am
Hi Friends!
Serviio is a great soft, and my prefered dlna server about 2 months. But now i´m having some problem to transcoding one MKV movie.
My TV is a Samsung U46C5000 and i using the default profile.xml to transcoding.
Thanks in advance!
The details of movie:
UniqueID : 81040264927912250832818583846878188317 (0x3CF7C98C019219CEB314FF13094C131D)
Complete name : H:\Filmes\HP.RM.P01.1080p.mkv
Format : Matroska
File size : 7.81 GiB
Duration : 2h 26mn
Overall bit rate : 7 656 Kbps
Encoded date : UTC 2011-03-31 22:14:02
Writing application : mkvmerge v4.6.0 ('Still Crazy After All These Years') built on Mar 10 2011 00:34:26
Writing library : libebml v1.2.0 + libmatroska v1.1.0
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 26mn
Bit rate : 6 832 Kbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.186
Stream size : 6.97 GiB (89%)
Language : English
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 2h 26mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 669 MiB (8%)
Language : Portuguese
Audio #2
Format : DTS
Codec ID : A_DTS
Bit rate : 32.0 Kbps
Channel(s) : 1 channel
Channel positions : Mono
Sampling rate : 0
Bit depth : 16 bits
Title : DTS-CORE 1536K
Language : English
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Text #2
Format : UTF-8
Post Thu May 26, 2011 6:57 am
Re: Problem with 1080p MKV
Do you try (for testing) to remux this mkv into a m2ts file with TsMuxer tool?
Check with mkvinfo if "header compression'" is not used in this mkv (not supported by the TV).
Post Thu May 26, 2011 10:26 am
This file should play without transcoding, if it does not it's not encoded properly for the TV. You could setup transcoding for files like these but it'd be transcoding all files that would normally play natively
Elurian
Post Thu May 26, 2011 12:22 pm
I will try to remux this mkv to test, and disable transcoding too.
I´m not home now, but tonight i reply the results of this tips.
Thanks Illico and zip.
Elurian
Post Sat May 28, 2011 9:19 pm
Hi, it´s me again!
I tried to play without transcoding, but not worked.
When i try to use tsMuxer to convert to m2ts, it gave me a error about invalid H264 NAL size.
I use the mkvinfo to get the information.
(MKVInfo) + EBML head
(MKVInfo) |+ EBML version: 1
(MKVInfo) |+ EBML read version: 1
(MKVInfo) |+ EBML maximum ID length: 4
(MKVInfo) |+ EBML maximum size length: 8
(MKVInfo) |+ Doc type: matroska
(MKVInfo) |+ Doc type version: 2
(MKVInfo) |+ Doc type read version: 2
(MKVInfo) + Segment, size 12372592063
(MKVInfo) |+ Seek head
(MKVInfo) | + Seek entry
(MKVInfo) | + Seek ID: 0x15 0x49 0xa9 0x66 (KaxInfo)
(MKVInfo) | + Seek position: 4099
(MKVInfo) | + Seek ID: 0x16 0x54 0xae 0x6b (KaxTracks)
(MKVInfo) | + Seek position: 4273
(MKVInfo) | + Seek ID: 0x1c 0x53 0xbb 0x6b (KaxCues)
(MKVInfo) | + Seek position: 12372562737
(MKVInfo) |+ EbmlVoid (size: 4043)
(MKVInfo) |+ Segment information
(MKVInfo) | + Timecode scale: 1000000
(MKVInfo) | + Muxing application: libebml v1.2.0 + libmatroska v1.1.0
(MKVInfo) | + Writing application: mkvmerge v4.6.0 ('Still Crazy After All These Years') built on Mar 10 2011 00:34:26
(MKVInfo) | + Duration: 8765.250s (02:26:05.250)
(MKVInfo) | + Date: Thu Mar 31 22:14:02 2011 UTC
(MKVInfo) | + Segment UID: 0x3c 0xf7 0xc9 0x8c 0x01 0x92 0x19 0xce 0xb3 0x14 0xff 0x13 0x09 0x4c 0x13 0x1d
(MKVInfo) |+ Segment tracks
(MKVInfo) | + A track
(MKVInfo) | + Track number: 1
(MKVInfo) | + Track UID: 1
(MKVInfo) | + Track type: video
(MKVInfo) | + Forced flag: 1
(MKVInfo) | + Lacing flag: 0
(MKVInfo) | + MinCache: 1
(MKVInfo) | + Codec ID: V_MPEG4/ISO/AVC
(MKVInfo) | + CodecPrivate, length 168 (h.264 profile: High @L4.1)
(MKVInfo) | + Default duration: 41.708ms (23.976 fps for a video track)
(MKVInfo) | + Video track
(MKVInfo) | + Pixel width: 1920
(MKVInfo) | + Pixel height: 800
(MKVInfo) | + Display width: 1920
(MKVInfo) | + Display height: 800
(MKVInfo) | + Content encodings
(MKVInfo) | + Content compression
(MKVInfo) | + Algorithm: 3 (header removal)
(MKVInfo) | + Settings: length 1, data: 0x00
(MKVInfo) | + Track number: 2
(MKVInfo) | + Track UID: 3791633401
(MKVInfo) | + Track type: audio
(MKVInfo) | + Codec ID: A_AC3
(MKVInfo) | + Default duration: 32.000ms (31.250 fps for a video track)
(MKVInfo) | + Language: por
(MKVInfo) | + Audio track
(MKVInfo) | + Sampling frequency: 48000
(MKVInfo) | + Channels: 6
(MKVInfo) | + Settings: length 2, data: 0x0b 0x77
(MKVInfo) | + Track number: 3
(MKVInfo) | + Track UID: 3482123166
(MKVInfo) | + Default flag: 0
(MKVInfo) | + Codec ID: A_DTS
(MKVInfo) | + Default duration: 10.667ms (93.750 fps for a video track)
(MKVInfo) | + Name: DTS-CORE 1536K
(MKVInfo) | + Settings: length 4, data: 0x7f 0xfe 0x80 0x01
(MKVInfo) | + Track number: 4
(MKVInfo) | + Track UID: 435731887
(MKVInfo) | + Track type: subtitles
(MKVInfo) | + Codec ID: S_TEXT/UTF8
(MKVInfo) | + Track number: 5
(MKVInfo) | + Track UID: 1492358246
(MKVInfo) | + Language: und
(MKVInfo) |+ EbmlVoid (size: 1206)
(MKVInfo) |+ Cluster
Elurian
Post Sat May 28, 2011 10:44 pm
Update:
It´s working now!
I got the MkvMerge and mark the option "Disable header removal compression for audio and video tracks by default" like Illico said.
Thanks Illico abd zip.
Serviio is the best =)
mucho
Post Wed Jun 08, 2011 2:54 pm
Elurian wrote:Update:
It´s working now!
Hi! When I try to stream mkv files, I still get "videocdec not supported". I'm a newbie at this, perhaps I can try your profiles.xml?
Post Wed Jun 08, 2011 7:55 pm
mucho wrote:Hi! When I try to stream mkv files, I still get "videocdec not supported". I'm a newbie at this, perhaps I can try your profiles.xml?
Please create a new topic on help& support section and provide "ffmpeg -i" command result of your mkv file (see my signaure)
Users browsing this forum: Google [Bot] and 8 guests
