Serviio with Freenas
dboy
Post Mon Mar 28, 2011 9:30 am
Re: Serviio with Freenas
Sure Perry,
My FreeNAS server has the IP adress: 192.168.0.188
The file is attached.
Before downloading it you should back up the serviio.sh that was in the package using the mv command.
#mv serviio.sh serviio.shoriginal
Then download "my" serviio.sh and put it in the same directory.
I had to change the name to serviio.txt to be able to upload it. Just change the name to serviio.sh using the mv command
#mv serviio.txt serviio.sh
After this you have to edit it using vi and change the ip adress in the end of the file to your FreeNAS IP adress.
-Dserviio.remoteHost=192.168.0.x
The x should be changed to your own FreeNAS IP adress. (Mine is x=188)
Good luck
serviio.txt
(2.41 KiB) Downloaded 1425 times
dboy
Post Mon Mar 28, 2011 9:32 am
Sure Perry,
Good luck
serviio.txt
(2.41 KiB) Downloaded 941 times
perryhome
Post Mon Mar 28, 2011 9:41 am
many thanks....i will try with your file
perryhome
Post Mon Mar 28, 2011 10:05 am
i have try with your file but i think taht i have different problem.....
2011-03-28 10:04:22,705 ERROR [ApplicationInstanceManager] freenas.local: freenas.local
java.net.UnknownHostException: freenas.local: freenas.local
at java.net.InetAddress.getLocalHost(InetAddress.java:1353)
at org.serviio.ApplicationInstanceManager.registerInstance(ApplicationInstanceManager.java:68)
at org.serviio.MediaServer.checkForRunningInstances(MediaServer.java:230)
at org.serviio.MediaServer.main(MediaServer.java:89)
2011-03-28 10:04:22,726 INFO [MediaServer] ------------------------------------------------------------------------
2011-03-28 10:04:22,726 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.1 (rev. 0c488c4fc651)
2011-03-28 10:04:22,726 INFO [MediaServer] Petr Nejedly 2009-2011
2011-03-28 10:04:22,726 INFO [MediaServer] http://www.serviio.org
2011-03-28 10:04:22,726 INFO [MediaServer] Java 1.6.0_07-The FreeBSD Foundation
2011-03-28 10:04:22,726 INFO [MediaServer] OS FreeBSD i386 7.3-RELEASE-p3
2011-03-28 10:04:22,726 INFO [MediaServer] File encoding: ISO-8859-1
2011-03-28 10:04:22,899 INFO [RestletServer] Starting Restlet server exposed on 192.168.50.47:23423
2011-03-28 10:04:22,990 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-03-28 10:04:24,528 WARN [ProfilesDefinitionParser] Cannot get name of the local computer: freenas.local: freenas.local
2011-03-28 10:04:24,803 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-03-28 10:04:24,876 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: replacement
perryhome
Post Mon Mar 28, 2011 3:00 pm
Yheaooooooooo
Now the server can comunicate with the client...but i see the folders Video audio and music but i do not see the content?...any solution?
dboy
Post Mon Mar 28, 2011 3:05 pm
Perry,
Did you manage to get the console running?
You need to tell Serviio to find the files first...
What was the error before? How did you solve it?
perryhome
Post Mon Mar 28, 2011 7:41 pm
dboy
i have solve the problem...there was an error in the Freenas configuration the "domain" field need .com at the end, without thid the serviio do not run, now work all very good with my samsung TV, the nex step will be to add the web gui interface...we can strat the new projet follow this post
viewtopic.php?f=5&t=1310
what do you timhk?
dboy
Post Mon Mar 28, 2011 7:59 pm
Good you solved it. Was the missing .com something you erased by mistake, or was it something that is needed only on your system.
I don't understand what you mean...
I would first like serviio to run as daemon. Now I start it in a putty session but I dont want to need to have a pc running with an open putty window.
I also need to figure out how to start the servio.sh (demon version) during boot so that it starts automaticly if I need to restart the FreeNAS.
Maybe you have solved this already?
perryhome
Post Mon Mar 28, 2011 8:20 pm
dboy
it was an incomplete setting under the first menu of Freenas...where you setting the domain name, if you set only name without ".com" the serviio server soutdown without reason.....
About the secon question it is very simple:
refer to tos topic:
http://www.homemultimedianetwork.com/Gu ... reeNAS.php
but the command will be: sh /directory_serviio/serviio.sh
and set the command when the nas have done the completely boot (postinit)
dboy
Post Tue Mar 29, 2011 10:07 am
Perry,
Ok. Thanks. It works.
Regarding the WebUI I think it is wise to wait for the 0.5.2 upgrade of the WebUI before going that path.
Post Tue Mar 29, 2011 10:18 am
dboy wrote:Regarding the WebUI I think it is wise to wait for the 0.5.2 upgrade of the WebUI before going that path.
There are no API changes between 0.5.1 and 0.5.2 so 0.5.1 webUI will work.
perryhome
Post Tue Mar 29, 2011 11:45 am
ZIP
there is a guide step by step to use this web ui with FREENAS?
dboy
Post Tue Mar 29, 2011 12:02 pm
Perry, Zip,
There is a guide for Ubuntu here:
http://forum.serviio.org/viewtopic.php?f=17&t=1310&start=20#p9421
Should be possible to work from.
Another question is why we need it?
Is it not enough to use the console application to control the FreeNAS installed serviio?
What is the additional benefit?
The only thing i can see would be that you don't need to install the console application on all your computers at home, but I think it is probably easier to install that then to maintain the WebUI.
Please enlighten me!
perryhome
Post Tue Mar 29, 2011 12:29 pm
Dboy
for me it is only for study...and because in this manner we do not need to install the client software, but using only the Web interface....
Post Tue Mar 29, 2011 2:09 pm
There is now 0.5.2 version: viewtopic.php?f=17&t=1310&start=40#p11911
You can use either or both at the same time, up to you. Depends on your preferred method of managing Serviio. Obviously the web UI is not managed by me so I can't give you any support, on the other hand it's open source so anybody can fix possible bugs / add features.
zlt
Post Wed May 25, 2011 5:16 pm
Hello! This is a great discussion and I appreciate all the information you have provided. However, I am completely new to Linux programing, as FreeNAS is my first experience. I have FreeNAS running smoothly and am comfortable with SSH via putty, but some of the things discussed are a bit over my head. I saw a mention of a How To guide for newbies... Any progress? Thanks again for your contribution!
dboy
Post Wed May 25, 2011 9:19 pm
zlt,
Sorry, i kind of wrote I should do that but when retracking I kind of thought all info is in this thread.
I think I might save all info in a log after upgrading to FreeNAS 0.8 and reinstalling Serviio, but I don´t consider it stable enough yet.
I suggest you dive into it and ask questions and we will try to help out...
Good luck!
zlt
Post Wed May 25, 2011 9:46 pm
That's a good suggestion. No better way to learn, right?
dboy
Post Thu May 26, 2011 8:04 am
Yepp, thats it.
You'll find almost everything you need in this post:
viewtopic.php?f=14&t=2060&start=10#p11742]
zlt
Post Thu May 26, 2011 5:01 pm
dboy,
Ok, I've been able to add diablo, xtrans, xproto, and xextproto by following the instructions here: http://sourceforge.net/apps/phpbb/freenas/viewtopic.php?f=15&t=1639 however, I'm getting stuck at javavmwrapper.
zmoneynas:/mnt/Storage/app/java/bin# pkg_add -v /mnt/Storage/app/java/javavmwrapper-2.3.5.tbz -P /mnt/Storage/app/java
Requested space: 77K bytes, free space: 772G bytes in /mnt/Storage/app/java/instmp.hFlWEi
Running pre-install for javavmwrapper-2.3.5..
extract: CWD to /mnt/Storage/app/java
extract: Package name is javavmwrapper-2.3.5
extract: /mnt/Storage/app/java/man/man1/checkvms.1.gz
extract: /mnt/Storage/app/java/man/man1/javavm.1.gz
extract: /mnt/Storage/app/java/man/man1/manvm.1.gz
extract: /mnt/Storage/app/java/man/man1/registervm.1.gz
extract: /mnt/Storage/app/java/man/man1/unregistervm.1.gz
extract: /mnt/Storage/app/java/man/man5/javavm_opts.conf.5.gz
extract: /mnt/Storage/app/java/man/man5/javavms.5.gz
extract: /mnt/Storage/app/java/bin/checkvms
extract: /mnt/Storage/app/java/bin/classpath
extract: /mnt/Storage/app/java/bin/javavm
extract: /mnt/Storage/app/java/bin/manvm
extract: /mnt/Storage/app/java/bin/registervm
extract: /mnt/Storage/app/java/bin/unregistervm
extract: /mnt/Storage/app/java/etc/javavm_opts.conf.dist
Running mtree for javavmwrapper-2.3.5..
mtree -U -f +MTREE_DIRS -d -e -p /mnt/Storage/app/java >/dev/null
Running post-install for javavmwrapper-2.3.5..
/mnt/Storage/app/java/etc/javavm_opts.conf already exists - not installing.
You may need to hand merge changes.
./+INSTALL: /mnt/Storage/app/java/bin/checkvms: Permission denied
pkg_add: install script returned error status
Change working directory to /mnt/Storage/app/java
Delete file /mnt/Storage/app/java/man/man1/checkvms.1.gz
Delete file /mnt/Storage/app/java/man/man1/javavm.1.gz
Delete file /mnt/Storage/app/java/man/man1/manvm.1.gz
Delete file /mnt/Storage/app/java/man/man1/registervm.1.gz
Delete file /mnt/Storage/app/java/man/man1/unregistervm.1.gz
Delete file /mnt/Storage/app/java/man/man5/javavm_opts.conf.5.gz
Delete file /mnt/Storage/app/java/man/man5/javavms.5.gz
Execute 'rm -f /mnt/Storage/app/java/man/cat1/checkvms.1.gz /mnt/Storage/app/java/man/cat1/checkvms.1 /mnt/Storage/app/java/man/cat1/checkvms.1.gz /mnt/Storage/app/java/man/cat1/checkvms.1.gz.gz /mnt/Storage/app/java/man/cat1/checkvms.1.gz.bz2'
Execute 'rm -f /mnt/Storage/app/java/man/cat1/javavm.1.gz /mnt/Storage/app/java/man/cat1/javavm.1 /mnt/Storage/app/java/man/cat1/javavm.1.gz /mnt/Storage/app/java/man/cat1/javavm.1.gz.gz /mnt/Storage/app/java/man/cat1/javavm.1.gz.bz2'
Execute 'rm -f /mnt/Storage/app/java/man/cat1/manvm.1.gz /mnt/Storage/app/java/man/cat1/manvm.1 /mnt/Storage/app/java/man/cat1/manvm.1.gz /mnt/Storage/app/java/man/cat1/manvm.1.gz.gz /mnt/Storage/app/java/man/cat1/manvm.1.gz.bz2'
Execute 'rm -f /mnt/Storage/app/java/man/cat1/registervm.1.gz /mnt/Storage/app/java/man/cat1/registervm.1 /mnt/Storage/app/java/man/cat1/registervm.1.gz /mnt/Storage/app/java/man/cat1/registervm.1.gz.gz /mnt/Storage/app/java/man/cat1/registervm.1.gz.bz2'
Execute 'rm -f /mnt/Storage/app/java/man/cat1/unregistervm.1.gz /mnt/Storage/app/java/man/cat1/unregistervm.1 /mnt/Storage/app/java/man/cat1/unregistervm.1.gz /mnt/Storage/app/java/man/cat1/unregistervm.1.gz.gz /mnt/Storage/app/java/man/cat1/unregistervm.1.gz.bz2'
Execute 'rm -f /mnt/Storage/app/java/man/cat5/javavm_opts.conf.5.gz /mnt/Storage/app/java/man/cat5/javavm_opts.conf.5 /mnt/Storage/app/java/man/cat5/javavm_opts.conf.5.gz /mnt/Storage/app/java/man/cat5/javavm_opts.conf.5.gz.gz /mnt/Storage/app/java/man/cat5/javavm_opts.conf.5.gz.bz2'
Execute 'rm -f /mnt/Storage/app/java/man/cat5/javavms.5.gz /mnt/Storage/app/java/man/cat5/javavms.5 /mnt/Storage/app/java/man/cat5/javavms.5.gz /mnt/Storage/app/java/man/cat5/javavms.5.gz.gz /mnt/Storage/app/java/man/cat5/javavms.5.gz.bz2'
Delete file /mnt/Storage/app/java/bin/checkvms
Delete file /mnt/Storage/app/java/bin/classpath
Delete file /mnt/Storage/app/java/bin/javavm
Delete file /mnt/Storage/app/java/bin/manvm
Delete file /mnt/Storage/app/java/bin/registervm
Delete file /mnt/Storage/app/java/bin/unregistervm
Delete file /mnt/Storage/app/java/etc/javavm_opts.conf.dist
pkg_add: 1 package addition(s) failed
First time I ran this, I got "checkvms: file not found", so I did the trick at the end of the above mentioned post - creating a link from /mnt/Storage/app/java/bin/javavm to /usr/local/bin/javavm. However, I had to create the javavm directories manually, because as you can see, pkg_add deletes them when it hits this error. After creating those directories manually and then creating the link
# ln -s /mnt/Storage/app/java/bin/javavm /usr/local/bin/javavm
I get the above error "Permission Denied". I've set both dir permissions to 777, so I'm not sure what else to do.
3 days ago I had never used a unix based system in my life, so your guidance is much appreciated!
Users browsing this forum: Baidu [Spider] and 22 guests
