Wild media server wmsmpeg.exe for subtitle
Badeend
Post Tue May 24, 2011 8:42 pm
Dear zip,
You have a great product only feature I am missing is embeded subs.
I see Wild media server uses ffmpeg for transcoding through some sort of wrapper (wmsmpeg.exe), is it possible to implement this or something like it to enable embedding of subtitles in movies?
Thank you.
Post Tue May 24, 2011 8:47 pm
Re: Wild media server wmsmpeg.exe for subtitle
I asume it's mencoder. That is not bundled with Serviio and most likely won't be. I think the functionality might be coming to ffmpeg anyway.
Badeend
Post Tue May 24, 2011 8:54 pm
No it realy is ffmpeg.
This is the commandline:
"C:\Program Files\Wild Media Server\wmsmpeg.exe" -i "movie.mkv" -f asf -vcodec wmv2 -b 4000000 -aspect 16:9 -copyts -pix_fmt yuv420p -acodec wmav2 -ab 160000 -ar 48000 -ac 2 -s 1280x720 -vhook "wmssubt.dll movie.srt,Arial,29,1,16777215,0,4,0,0,0,1280,716,23.976,0,0,0,nld,0,0" -map 0:0 -map 0:1 "movie.wmv" -v -1 -loglevel quiet
And this is the output, looks like ffmpeg.
frame=83914 fps= 30 q=4.0 size= 1804348kB time=3499.91 bitrate=4223.3kbits/s
Post Wed May 25, 2011 8:45 am
ok, this is probably the piece that does all the work: wmssubt.dll
Not sure if it's something custom made or just a renamed ffmpeg library
Post Fri May 27, 2011 10:06 pm
wild media server uses mencoder for subttles as zip said above :)
Return to Feature requests
Users browsing this forum: Baidu [Spider] and 14 guests
