LG 47LW6500
Post Mon May 30, 2011 6:41 pm
Re: LG 47LW6500
Check the Presentation tab to see if you have not disabled Image/Video categories.
mina
Post Mon May 30, 2011 11:53 pm
Re: LG 47LW6500
zip wrote:Check the Presentation tab to see if you have not disabled Image/Video categories.
Every single item in the list says "Display category".
mina
Post Tue May 31, 2011 12:01 am
Re: LG 47LW6500
Illico wrote:According to your Library tab settings, you only add a folder path for "images" parsing.
So no audio, no video under the serviio library, only images.
With your TV, when you'll browse audio folders or video folders, you will have empty folders.
But if you select the images category under your TV menu, read the usermanual:
Home --> Smart Share --> Select Device (Serviio) --> Photo List --> Forder
You may have all "images" of the serviio library.
As I said before, there is no Image folder for me to browse to. If I go Home --> Smart Share --> Select Device (Serviio) it brings me to this screen:
I also get to that same screen if I choose Input --> DLNA Network.
Logically, I should at least see a folder for Images because I'm sharing a folder with three jpg files. I can understand why Audio is empty, but I cannot understand why there is no Video folder for me to browse to. Theoretically, there should also be a Video folder that is also empty, right? So confusing! :)
Post Tue May 31, 2011 12:16 am
Re: LG 47LW6500
http://lgknowledgebase.com/kb/index.php ... tryID=6460 --- does that help from LG knowledge base
granted though replace installign nero with installing serviio :)
mina
Post Tue May 31, 2011 12:46 am
Re: LG 47LW6500
Ah, no... the screen they show is a little bit different than mine. There is no icon at all for "My Media". That is probably an older software version shown on their site, as my TV model isn't even listed yet. :?
pasta1234
Post Mon Jun 06, 2011 4:02 am
Re: LG 47LW6500
I have the same exact problem with my new 47lw5700 which I have an open thread as well.
If I install the included Nero media home software all my folders show and work, but with serviio all I get is a audio folder with my music. I would really prefer tobget serviio working due to its options and fkexibility...
Anyone have any ideas, can this be due to an improper dlna profile ?
Post Mon Jun 06, 2011 11:36 am
Re: LG 47LW6500
Post detailed log of when you turn on the TV and browse.
pasta1234
Post Tue Jun 07, 2011 1:41 am
Re: LG 47LW6500
Attached is the Log File and screen shots of the config screens...
I only get to see the Audio Folder on the TV nothing else for some reason.
Thanks,
Pete
Log File LG TV
(63.64 KiB) Downloaded 1087 times
Post Tue Jun 07, 2011 9:00 am
Re: LG 47LW6500
Can you install Intel tools, run AV Media Controller and see if you can see other categories than Audio there?
pasta1234
Post Thu Jun 09, 2011 5:28 am
Re: LG 47LW6500
For some reason I can't get the Intel tools to run without crashing. I am not sure if it has something to do with the. Net framework or something.
Regardless if its of any value the included Nero MediaHome works with video and images.
Is there anything else I can try too get this to function with my TV?
Post Thu Jun 09, 2011 9:06 am
Re: LG 47LW6500
Can you try disabling the audio/video/image categories in the console (Presentation tab), click Save, then enable them again + Save
ttve
Post Fri Jun 10, 2011 6:16 am
Re: LG 47LW6500
Same problem for me with a LG 55LW650S. EDIT: Serviio is running on a Mac mini, OSX 10.6.7 if that makes a difference.
I've tried to disable and re-enable the categories, or just display content, this doesn't fix the problem.
Another TV connected to the same network via a Toshiba box correctly displays the Video and Image categories.
The LG TV works fine with Nero Media Home 4 running on a PC. I haven't tried other DLNA server software, I'll do it to see what happens.
Post Fri Jun 10, 2011 9:20 am
Re: LG 47LW6500
I've created a ticket and will look at it: https://bitbucket.org/xnejp03/serviio/i ... o-category
pasta1234
Post Fri Jun 10, 2011 4:16 pm
Re: LG 47LW6500
Thanks for the Ticket Zip, is there a beta version that we can try ?
Let us know if we can help...
vitoxbc
Post Sun Jun 12, 2011 1:41 am
Re: LG 47LW6500
Hi!
I've got the same problem with LW5500.
With AV Media Controller I can see all folders.
Thanks!
Post Sun Jun 12, 2011 8:53 am
Re: LG 47LW6500
What if you disable the Audio category in the console, can you see anything?
vitoxbc
Post Sun Jun 12, 2011 9:25 am
Re: LG 47LW6500
If I disable the Audio category, then I can see the Image category. If I disable this too, I'm able to see the Video category.
So the TV only shows the first category (alphabeticatilly).
Post Sun Jun 12, 2011 9:26 pm
Re: LG 47LW6500
That is weird. I'll have a look if i can see something dodgy, but I doubt as as it works for every other renderer.
pasta1234
Post Sun Jun 12, 2011 9:41 pm
Re: LG 47LW6500
I have tried that as well and can confirm it only shows the last enabled category in the presentations tab. If i disable Audio and Image, the TV displays the Video folders. Strangely though, its empty..
Pete
vitoxbc
Post Sun Jun 12, 2011 9:52 pm
Re: LG 47LW6500
When I can access to a category (being it the only one enabled) I can access to its content without any problem. It isn't empty in my case ;)
Return to LG
