Stuttering and blocky MKVs Panny G20
SiberPir8
Post Tue May 31, 2011 7:17 am
Hi Guys just registered to say this is 10x's better than any stuff out there. I pulled my hair out with tversity.
I have 2 issues which is less than tversity.
I couldnt play MKV or mp4. I inserted the profile that was posted on page 3 and MP4 works.
But the MKV files stutters and goes blocky.
#2 Subtitles....Ive got subtitles to work with avi's but there is one that doesnt work despite it being the same name. When I click option on remote it shows nothing for subs where as the rest it does.
I dont know if its related but the avi that doesnt show subs I had to join with vitualdub cos it was split.
Thx guys just need to tweek it so its perfect!!
This is on a panny G20 by the way.
Post Tue May 31, 2011 9:15 am
Re: Stuttering and blocky MKVs Panny G20
Could you try this:
   <Profile id="12" name="Panasonic Viera" extendsProfileId="1">
      <ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.PanasonicDLNAMessageBuilder</ContentDirectoryMessageBuilder>
      <MediaFormatProfiles>
      </MediaFormatProfiles>
             <!-- First remux all h264 video on MPEG-TS stream with ac3 audio transcoding, expected profile AVC_TS_MP_HD_AC3_ISO or AVC_TS_MP_SD_AC3_ISO -->
                <!-- if audio different to ac3, must be transcoded -->
                <Matches container="mpegts" aCodec="aac" />
                <Matches container="mpegts" aCodec="mp3" />
                <Matches container="mpegts" aCodec="dca" />
             <!-- All Others video/audio codec will be transcoded into mpeg2ts, mpeg2video and ac3 audio (MPEG_TS_SD_EU). -->
                <Matches container="asf" />
                <Matches container="mp4" />
            <Audio targetContainer="mp3">
            <Matches container="flac" />
            <Matches container="ogg" />
         </Audio>
For MKV files stuttering, could you check the video bitrate with that tools: viewtopic.php?f=17&t=2133
Are you Wifi or wire connected ?
SiberPir8
Post Tue May 31, 2011 10:48 am
Im using wired to eliminate quality of signal.
This is the profile I am using at the min which I added.
<Profile id="11" name="Panasonic Viera" extendsProfileId="1">
<!-- Remux all h264 video to MPEG-TS stream -->
Is it the same at the one you posted?
The bitrate view I have run. what things am I looking for?
Min KBPS is 13
Max KBPS is 5853
Average is 1222 KBPS
Post Tue May 31, 2011 11:52 am
Post "ffmpeg -i" result of files that failed.
Could you try with :
Don't forget to restart serviio service of profile modification.
Video bitrate seems reasonable for DLNA streaming (<20Mbps).
SiberPir8
Post Tue May 31, 2011 1:10 pm
please fogive my noobness. what and how do I test the videos for a ffmpeg -i result? Is there software needed.
Many Thanks
Post Tue May 31, 2011 1:11 pm
SiberPir8
Post Tue May 31, 2011 1:37 pm
ok here is one of the mkvs
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Program Files\Serviio\lib>ffmpeg.exe -i "C:\XBOX Videos\Darker than Black 01.mkv"
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[matroska,webm @ 0161d140] max_analyze_duration reached
[matroska,webm @ 0161d140] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/1001) -> 23.98 (48000/2002)
Input #0, matroska,webm, from 'C:\XBOX Videos\Darker than Black 01.mkv':
title : Darker Than Black - 01 - The Star of the Contract Shoots By (Part One)
Duration: 00:24:29.21, start: 0.000000, bitrate: 192 kb/s
Chapter #0.0: start 0.000000, end 309.200000
title : Introduction
Chapter #0.1: start 309.200000, end 409.000000
title : Opening
Chapter #0.2: start 409.000000, end 1337.333000
title : Episode Start
Chapter #0.3: start 1337.333000, end 1426.874000
title : Ending
Chapter #0.4: start 1426.874000, end 1469.218000
title : Next Episode
Stream #0.0(eng): Video: h264, yuv420p, 1280x720, PAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
title : 01 - The Star of the Contract Shoots By (Part One)
Stream #0.1(jpn): Audio: mp3, 48000 Hz, 2 channels, s16, 192 kb/s
title : Japanese Audio (2ch MP3)
Stream #0.2(eng): Subtitle: ass
title : English Subtitles (ASS)
Stream #0.3: Attachment: [0][0][0][0] / 0x0000
filename : Sapir Sans.ttf
Post Tue May 31, 2011 1:54 pm
Could you try:
SiberPir8
Post Tue May 31, 2011 2:19 pm
Thanks Ill give it a whirl.
SiberPir8
Post Tue May 31, 2011 9:44 pm
Ok now serviio wont even start... It says server not running.
I think because of the profile coding, cos put back to original it works.
Here is the coding with the profile in you posted
<Profiles version="1.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="http://www.serviio.org/xsd/profiles/1.5/Profiles.xsd">
      ========================= DO NOT EDIT - start ====================================
   <Profile id="1" name="Generic DLNA profile">
      <ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.GenericDLNAMessageBuilder</ContentDirectoryMessageBuilder>
      <ProtocolInfo>DLNA</ProtocolInfo>
      <DeviceDescription>
         <FriendlyName>Serviio ({computerName})</FriendlyName>
         <ModelName>Serviio Media Server</ModelName>
      </DeviceDescription>
         <MediaFormatProfile mime-type="audio/mpeg">MP3</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/L16;rate=44100;channels=1" name="LPCM">LPCM16_44_MONO</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/L16;rate=44100;channels=2" name="LPCM">LPCM16_44_STEREO</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/L16;rate=48000;channels=1" name="LPCM">LPCM16_48_MONO</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/L16;rate=48000;channels=2" name="LPCM">LPCM16_48_STEREO</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/x-ms-wma">WMA_BASE</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/x-ms-wma">WMA_FULL</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/mp4">AAC_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/mp4">AAC_ISO_320</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/flac">FLAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/ogg">OGG</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/jpeg">JPEG_SM</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/jpeg">JPEG_MED</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/jpeg">JPEG_LRG</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/jpeg">JPEG_TN</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/png">PNG_LRG</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/png">PNG_TN</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/gif">GIF_LRG</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG1</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG_PS_PAL</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG_PS_NTSC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_EU</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_EU_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG_TS_SD_EU_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_NA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_NA_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG_TS_SD_NA_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_KO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_KO_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG_TS_SD_KO_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-msvideo">AVI</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-matroska">MATROSKA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-flv">FLV</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-dvr">DVR_MS</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/wtv">WTV</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_HD_720p_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_HD_1080i_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_HP_HD_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_LPCM</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_ASP_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_SP_L6_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_NDSD</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_AAC_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG4_P2_TS_ASP_AAC_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG4_P2_TS_ASP_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_MPEG1_L3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG4_P2_TS_ASP_MPEG1_L3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AAC_MULT5_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_SD_AAC_MULT5_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_MPEG1_L3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_SD_MPEG1_L3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AAC_MULT5_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_HD_AAC_MULT5_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_MPEG1_L3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_HD_MPEG1_L3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_HD_DTS_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_HD_DTS_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_HD_50_LPCM_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_HP_SD_MPEG1_L2_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_HP_SD_MPEG1_L2_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_HP_HD_MPEG1_L2_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_HP_HD_MPEG1_L2_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">WMVMED_BASE</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">WMVMED_FULL</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">WMVHIGH_FULL</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">WMVMED_PRO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">WMVHIGH_PRO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-asf">VC1_ASF_AP_L1_WMA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-asf">VC1_ASF_AP_L2_WMA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-asf">VC1_ASF_AP_L3_WMA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">VC1_TS_AP_L1_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">VC1_TS_AP_L2_AC3_ISO</MediaFormatProfile>
      <AutomaticImageRotation>false</AutomaticImageRotation>
      <LimitImageResolution>true</LimitImageResolution>
      ========================= DO NOT EDIT - end   ====================================
   <Profile id="2" name="Samsung TV (B-series)" extendsProfileId="1">
        <ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.SamsungDLNAMessageBuilder</ContentDirectoryMessageBuilder>
        <ResourceTransportProtocolHandler>org.serviio.upnp.protocol.http.transport.SamsungWiseLinkProtocolHandler</ResourceTransportProtocolHandler>
        <Detection>
            <UPnPSearch>
                <FriendlyName>^TV$</FriendlyName>
                <ModelName>Samsung DTV DMR</ModelName>
                <ModelNumber>1\.0</ModelNumber>
            </UPnPSearch>
        </Detection>
        <DeviceDescription>
           <ExtraElements>
              &lt;sec:ProductCap&gt;smi,getMediaInfo.sec,getCaptionInfo.sec&lt;/sec:ProductCap&gt;
            &lt;sec:X_ProductCap&gt;smi,getMediaInfo.sec,getCaptionInfo.sec&lt;/sec:X_ProductCap&gt;
           </ExtraElements>
            <MediaFormatProfile mime-type="video/x-mkv">MATROSKA</MediaFormatProfile>
            <!-- transcode MKV with DST audio to AC3, remux into mpeg2ts -->
            <!-- transcode H264 MP4 files with LPCM audio -->
                <Matches container="matroska" vCodec="h264" aCodec="dca" />
                <Matches container="mp4" vCodec="h264" aCodec="lpcm" />
            <!-- transcode unsupported codec/container combinations into mpeg2ts -->
            <Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video">
                <Matches container="asf" vCodec="wmv2" />
                <Matches container="flv" />
            <!-- For dvr-ms files force mpeg2video transcoding to fix monotone timestamps problems-->
            <Video targetContainer="mpegts" targetACodec="ac3" forceVTranscoding="true">
                <Matches container="asf" vCodec="mpeg2video" />
                <Matches container="wtv" />
            <!-- transcode audio only for wmv with wmapro -->
            <Video targetContainer="asf" targetACodec="ac3" aBitrate="256">
                <Matches container="asf" aCodec="wmapro" />
            </Audio>
        <SubtitlesMimeType>smi/caption</SubtitlesMimeType>
   <Profile id="3" name="XBox 360" extendsProfileId="1">
      <ResourceTransportProtocolHandler>org.serviio.upnp.protocol.http.transport.XBox360ProtocolHandler</ResourceTransportProtocolHandler>
      <ProtocolInfo>simple</ProtocolInfo>
      <Detection>
         <UPnPSearch>
            <ModelName>Xbox 360</ModelName>
         </UPnPSearch>
      </Detection>
      <DeviceDescription>
         <FriendlyName>Serviio ({computerName}): 1</FriendlyName>
         <ModelName>Windows Media Player Sharing</ModelName>
         <ModelNumber>12.0</ModelNumber>
      <ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.XBox360ContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
         <MediaFormatProfile mime-type="video/avi">AVI</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">VC1_ASF_AP_L1_WMA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">VC1_ASF_AP_L2_WMA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">VC1_ASF_AP_L3_WMA</MediaFormatProfile>
            http://blogs.msdn.com/xboxteam/archive/2007/11/30/december-2007-video-playback-faq.aspx
         <Video targetContainer="asf" targetVCodec="wmv2" targetACodec="wmav2" maxVBitrate="15360" forceStereo="true">
            <Matches container="mpeg" />
            <Matches container="mpegts" />
            <Matches container="mpegvideo" />
            <Matches container="avi" vCodec="msmpeg4" />
         </Audio>
   <Profile id="4" name="Playstation 3" extendsProfileId="1">
      <Detection>
         <HttpHeaders>
            <X-AV-Client-Info>.*PLAYSTATION 3.*</X-AV-Client-Info>
         </HttpHeaders>
      </Detection>
            remux MKV with any video to MPEG2TS and possibly change audio to ac3, also AVI anfd FLV with H264
         <!-- all other unplayable files just transcode to mpeg2 -->
   <Profile id="5" name="Samsung TV (A-series)" extendsProfileId="2">
         </Audio>
   <Profile id="6" name="DirecTV HD-DVR" extendsProfileId="1">
      <Detection>
         <HttpHeaders>
            <User-Agent>.*DIRECTV.*</User-Agent>
         </HttpHeaders>
      </Detection>
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="mp2" maxVBitrate="8192" forceStereo="true">
            <Matches container="avi" />
   <Profile id="7" name="Samsung TV / player (C/D-series)" extendsProfileId="2">
      <Detection>
         <UPnPSearch>
            <FriendlyName>(^TV-\d{2}C\d{3}.*)|(^\[TV\][A-Z]{2}\d{2}D\d{3}.*)</FriendlyName>
            <ModelNumber>(1\.0)|(AllShare1\.0)</ModelNumber>
         </UPnPSearch>
         <HttpHeaders>
            <!-- for BD players -->
            <User-Agent>.*SEC_HHP_BD-[CD].*</User-Agent>
         </HttpHeaders>
      </Detection>
      <DeviceDescription>
         <ExtraElements>
              &lt;sec:ProductCap&gt;smi,DCM10,getMediaInfo.sec,getCaptionInfo.sec&lt;/sec:ProductCap&gt;
            &lt;sec:X_ProductCap&gt;smi,DCM10,getMediaInfo.sec,getCaptionInfo.sec&lt;/sec:X_ProductCap&gt;
           </ExtraElements>
      <ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.SamsungContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
            <Matches container="mp4" aCodec="lpcm" />
         <!-- transcode MKV with MPEG2 video, remux into mpeg2ts -->
         <!-- transcode AVI with AVC video -->
         </Audio>
   <Profile id="8" name="LG BD player" extendsProfileId="1">
         <Video targetContainer="mpegts" targetACodec="mp3">
            <Matches container="matroska" aCodec="ac3" />
   <Profile id="9" name="Sony Bravia TV" extendsProfileId="1">
      <Detection>
         <UPnPSearch>
            <FriendlyName>BRAVIA.*</FriendlyName>
         </UPnPSearch>
      </Detection>
         <!-- rename native mpeg2ts with h264/ac3 ac3 formats to those supported by the tv -->
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_HD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
         <!-- rename transcoded mpeg2ts with h264 to one of the TV's supported profiles -->
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
         <!-- For dvr-ms files force mpeg2video transcoding to fix monotone timestamps problems -->
         <!-- Transcode all h264 video with HIGH/MAIN > Level 4.1 on MPEG-TS stream with MPEG2VIDEO and ac3 audio transcoding -->
         <!--  expected profile MPEG_TS_SD_EU/MPEG_TS_SD_NA/MPEG_TS_SD_KO -->
            <Matches container="avi" vCodec="h264" profile="high" levelGreaterThan="4.1" />
            <Matches container="avi" vCodec="h264" profile="main" levelGreaterThan="4.1" />
            <Matches container="matroska" vCodec="h264" profile="high" levelGreaterThan="4.1" />
            <Matches container="matroska" vCodec="h264" profile="main" levelGreaterThan="4.1" />
            <Matches container="mp4" vCodec="h264" profile="high" levelGreaterThan="4.1" />
            <Matches container="mp4" vCodec="h264" profile="main" levelGreaterThan="4.1" />
         <!-- Remux all other h264 video on MPEG-TS stream with ac3 audio transcoding -->
         <!--  expected profile AVC_TS_MP_HD_AC3_ISO -->
         <!-- All Others video/audio codec will be transcoded into mpeg2ts, mpeg2video and ac3 audio -->
         </Audio>
   <Profile id="10" name="Sony BD Player" extendsProfileId="1">
      <!-- Since Serviio 0.5.1 this profile is multiregion -->
      <Detection>
         <HttpHeaders>
            <X-AV-Client-Info>.*Blu-ray Disc Player.*</X-AV-Client-Info>
         </HttpHeaders>
      </Detection>
         <!-- force DLNA profile names of supported formats -->
            e.g. though renderer should support wma, it only does so when disguised as mp3 (many other audio types are transcoded later in
            the profile)
         <MediaFormatProfile mime-type="audio/mpeg" name="MP3">WMA_BASE</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/mpeg" name="MP3">WMA_FULL</MediaFormatProfile>
         <!-- set mkv to divx mime-type to allow subtitle and multiple audio track support for European and Canadian players -->
         <!-- This native mkv playback disabled by default - read comment in transcoding section for the reasons -->
         <MediaFormatProfile mime-type="video/divx">MATROSKA</MediaFormatProfile>
         <!-- To avoid needing region-specific profiles, avi must be set to mpeg mime type (US players require this) -->
            AVI clips seems to be a little bit slower to start like this on European players. If that bothers you, delete the line below
         <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_PAL,MPEG_PS_NTSC">AVI</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_PAL,MPEG_PS_NTSC">AVC_MP4_MP_SD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_PAL,MPEG_PS_NTSC">AVC_MP4_MP_SD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_PAL,MPEG_PS_NTSC">AVC_MP4_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_PAL,MPEG_PS_NTSC">AVC_MP4_MP_HD_720p_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_PAL,MPEG_PS_NTSC">AVC_MP4_MP_HD_1080i_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_PAL,MPEG_PS_NTSC">AVC_MP4_HP_HD_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_PAL,MPEG_PS_NTSC">AVC_MP4_LPCM</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_PAL,MPEG_PS_NTSC">MPEG4_P2_MP4_ASP_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_PAL,MPEG_PS_NTSC">MPEG4_P2_MP4_SP_L6_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="MPEG_PS_PAL,MPEG_PS_NTSC">MPEG4_P2_MP4_NDSD</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AAC_MULT5_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AAC_MULT5_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_MPEG1_L3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_MPEG1_L3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AAC_MULT5_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AAC_MULT5_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_MPEG1_L3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_MPEG1_L3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HD_DTS_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HD_DTS_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HD_50_LPCM_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HP_SD_MPEG1_L2_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HP_SD_MPEG1_L2_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HP_HD_MPEG1_L2_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HP_HD_MPEG1_L2_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AAC_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AAC_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG1_L3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG1_L3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">VC1_TS_AP_L1_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">VC1_TS_AP_L2_AC3_ISO</MediaFormatProfile>
            Sony BDP requests all formats except mpeg-ps and mpeg-ts in 32KB chunks which works badly over wifi, hence mkv files are
            remuxed to mpeg-ts by default in this profile. Natively played mkv files stutter irretrievably after seeks, which seems to be a
            DLNA firmware issue with the player. If you have a European or Canadian player (not US), you stream over a wired connection and
            want mkv subtitles, dts support, and multiple audio tracks - but don't care that you can't seek - remove all matroska
            transcoding matches below to have the player decode mkv natively.
            <!-- FFmpeg cannot currently remux dts audio properly so it must be transcoded, but all other audio is left alone -->
            <!-- remux mp4 container files to mpeg-ts to allow seeking -->
            <!-- this also fixes the renderer's jerky playback of mov container files such as iPhone 4 HD video recordings -->
         <!-- unsupported codecs will be transcoded into mpeg-ts, mpeg2 video and ac3 audio -->
            <!-- digital camera video formats -->
         </Audio>
          <!-- remux DTS in MKV to AC3 -->
         </Audio>
   <Profile id="13" name="Toshiba Rezga" extendsProfileId="1">
<Profile id="12" name="Panasonic Viera plasma" extendsProfileId="1">
         </Audio>
</Profiles>
Post Tue May 31, 2011 10:59 pm
you have 2 panasonic profiles with id 12. The id must be unique.
SiberPir8
Post Wed Jun 01, 2011 7:55 pm
So all I have to do is change the new id from 12 to 13? Is that right? Many thanks guys.
Post Wed Jun 01, 2011 8:58 pm
if it doesn't exist yet, yes. you can make it 99 if you want. Or remove the original profile and use the new as 12 instead.
SiberPir8
Post Thu Jun 02, 2011 10:04 am
Cool, thx zip, changed it and it starts fine now.
Ill try it tonight when i get home with the mkv's and ill report back.
Just like to say thanks for all your help so far guys.
SiberPir8
Post Thu Jun 02, 2011 7:06 pm
Ok reporting back that it is exactly the same as the orginal profile for the panasonic.
One MKV's still stutters and the other has lines down the screen and flickers.
Do you guys sugest anything else to try?
Cheers
Simon
SiberPir8
Post Fri Jun 03, 2011 11:30 am
Any more suggestions or do u think mkv's will not play at all on this tv?
Post Fri Jun 03, 2011 11:56 am
Have you tried to play the files with another render? There are some good software based renders that you can use to test files streamed from serviio. That way you can make sure that the file is actually not corrupted.
SiberPir8
Post Fri Jun 03, 2011 12:50 pm
Ahh ok, whats the tool called?
The files play ok in media player classic and vlc.
Ill give it a try tho.
Post Fri Jun 03, 2011 12:54 pm
At the middle of this web page there is a list of software renders you can try to see if Serviio is transcoding it correctly and if it is the TV messing it up.
http://en.wikipedia.org/wiki/List_of_UPnP_AV_media_servers_and_clients
Look for the following section and then pick your Operating system.
UPnP AV clients
SiberPir8
Post Fri Jun 03, 2011 7:33 pm
Is there any that you would suggest I tried 2 and couldnt seem to do anything with them.
On a side note I downloaded wild media server and the mkv's work on that but its has no subs showing.
So does that show the tv can support them with decoding?
Many thanks
Return to Panasonic
Users browsing this forum: No registered users and 52 guests
