Cover Art now shown Samsung UN32D5550
sunchar
Post Thu May 19, 2011 2:59 pm
Hi! I'm new in this forum.
I look for this issue in this forum but i didn't find something related.
I have installed Serviio 0.52 under windows XP, and it works great. Better than any other DLNA server I have tested.
There is only a problem when playing music, it don't show cover art. Browsing folder shows covers but not when playing music.
TV is Samsung UN32D5550.
Hope somebody can help me to solve this thread.
Thanks!!!
Post Thu May 19, 2011 3:32 pm
Re: Cover Art now shown Samsung UN32D5550
I have a B series and have the same problem - it's normal. On C series it shows them. Can you try Samsung's PC Share manager to see if the TV really supports them?
sunchar
Post Thu May 19, 2011 4:34 pm
I have tried with Samsung AllShare 2.0 and it show cover art while playing music.
If you want to check it, this is the URL for download it: http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_MX&CttFileID=3809756&CDCttType=SW&ModelType=N&ModelName=UN32D5550RF&VPath=SW/201102/20110222162523529/AllShare_2.0.exe
Try with a small library, because it take year for creating a medium - long library.
Thanks for your reply and for Serviio, it works great.
Post Thu May 19, 2011 4:58 pm
can you turn on detailed logging and post the bit when you're playing the audio file?
sunchar
Post Thu May 19, 2011 5:59 pm
I`m not in home, but i have my computer ¿log still stored? if it still ¿How can i find that bit you say?
Post Thu May 19, 2011 6:15 pm
search for the song's name in the log.
sunchar
Post Fri May 20, 2011 1:54 am
Hi. This is a block of too many ones that where logged while playing a song (Hope this bit is what you need):
2011-05-19 20:43:00,859 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.100
2011-05-19 20:43:00,859 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.100, Profile=Samsung TV / player (C/D-series)'
2011-05-19 20:43:00,859 DEBUG [ResourceTransportRequestHandler] Request for resource 255 and type 'MEDIA_ITEM' received
2011-05-19 20:43:00,859 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 255)
2011-05-19 20:43:00,859 DEBUG [MusicTrackDAOImpl] Reading a MusicTrack (id = 255)
2011-05-19 20:43:00,859 DEBUG [AudioDeliveryEngine] Delivering item '255' for client 'IPAddress=/192.168.0.100, Profile=Samsung TV / player (C/D-series)'
2011-05-19 20:43:00,859 DEBUG [AudioDeliveryEngine] Delivering file '02 - As Long As You Love Me.mp3' in native format
2011-05-19 20:43:00,859 DEBUG [MediaItemDAOImpl] Getting file of media item 255
2011-05-19 20:43:00,859 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 6562449
2011-05-19 20:43:00,859 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-05-19 20:43:00,859 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: audio/mpeg,Content-Range: bytes 56331-6618779/6618780,Content-Length: 6562449,Date: Fri, 20 May 2011 01:43:00 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MP3;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-05-19 20:43:00,859 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1922) and extractor EMBEDDED
2011-05-19 20:43:00,859 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1922) and extractor COVER_IMAGE_IN_FOLDER
If you need more info or something just tell me.
Post Fri May 20, 2011 8:45 am
there should be another request for COVER_IMAGE just above that. if there is not then the TV won't display the cover art
sunchar
Post Fri May 20, 2011 3:41 pm
Re: Cover Art not shown Samsung UN32D5550
I will try again. Log have a lot of records, maybe miss some ones.
sunchar
Post Fri May 20, 2011 9:33 pm
Hi.
This is the log file that where created, i just turn on computer and play a mp3 "01 Thunderstruck.mp3" as fast as i can trying to reduce log size but still being so long.
serviio.zip
(39.8 KiB) Downloaded 1014 times
Post Fri May 20, 2011 11:36 pm
It doesn't ask for the cover image, not sure why as it's advertised. Can you confirm there is a Resource for the thumbnail if you browse to the file via Intel's AV Media Controller?
sunchar
Post Sat May 21, 2011 4:03 am
It seems that this particular file have cover resources, resources are listed as shown in the attached images.
Resources 2.JPG (43.02 KiB) Viewed 28556 times
Resources 1.JPG (45.98 KiB) Viewed 28556 times
Post Sun May 22, 2011 11:24 am
In that case I'm not sure. For some reason the TV doesn't load it, hard to debug this without the TV here ;-) Could you try any other server (other than Samsung's) to see if they support this?
sunchar
Post Mon May 23, 2011 3:08 pm
Is there a posiblility that is happening the same problem you experienced with your B series??
May be if we compare our log file while playig a song.
Post Mon May 23, 2011 3:45 pm
No, the B series doesn't show it even for the Samsung's server.
sunchar
Post Mon May 23, 2011 6:18 pm
Now i´m trying with TVMobili and it doesn't show cover art.
sunchar
Post Tue May 24, 2011 9:29 pm
I have been checking the post for new replies, and nothing new.
If there is something i can do for fixing this thread just tell me.
sunchar
Post Thu May 26, 2011 5:18 am
Now i have tested Mezzmo 2.3.1.0 and it doesn't show cover.
I don't know why only Samsung's allshare app is the only that show music covers.
Hope some day serviio shows it too.
sunchar
Post Thu Jun 02, 2011 4:51 am
Hi!!!
I was checking log on Samsung's server while playing a song, i found that it is not using images located in the same folder where mp3 are, it creates another folder in installation dir where stores a copy of original images and resizes it. And it looks that creates a relation between resized file with xxxxxxxxxx.jpg name and mp3 file.
Here is the log that was created while playing a song...
http_ss.log
(17.81 KiB) Downloaded 1117 times
sunchar
Post Sat Jun 04, 2011 4:42 am
Hi Guys.
Here are three xml files extracted with Device Spy, i have created three ones because device spy detect three devices whith the same name, UN32D5550.
If it's necesary to sniff network packets just tell me, i frequently use wireshark. I don't know if i should use another tool for this purpose.
Thanks!!!!
UN32D5550 - 3.xml
(3.12 KiB) Downloaded 1282 times
UN32D5550 - 2.xml
(1.23 KiB) Downloaded 1285 times
UN32D5550 - 1.xml
(2 KiB) Downloaded 1316 times
