Every video stop after 15-20 minutes
ruslanoid
Post Sun May 29, 2011 7:57 pm
using Serviio on Windows PC (Vista 64bit) to stream videos to Samsung TV
for some reason - please help understand what - every video stops after 15-20 minutes
replaying and fast forwarding helps, but i would like to solve this
on the PC the service seems to be running ok, network in order and all...
any ideas?
Post Sun May 29, 2011 8:58 pm
Re: Every video stop after 15-20 minutes
ruslanoid wrote:using Serviio on Windows PC (Vista 64bit) to stream videos to Samsung TV
any ideas?
please provide more information on your setup
1. serviio detailed log file ( see howto in signiture) zip it up and attach
2. wired or wireless
3. OS? ok so windows vista 64bit
4. were is media stored? local drive ( drive inside ur pc ) or on usb drive or on network drive ?
5. have you got correct profile selected for your device? ( please give model number of your device )
Post Mon May 30, 2011 5:41 am
Check the temporary folder free space.
ruslanoid
Post Mon May 30, 2011 6:52 am
ok, some more info...
will atach a log when get home, meanwhile...
the connection is all wired - both the PC and the TV ( by the way it's the samsung ua40c6200 - and the profile was detected and set correctly ) connected to to the same router
the files are located at the same local directory on the PC (there are directories in Library which are on external HD via firewire - not sure it has anything to do with this)
temporary folder has more then enough free space (~70GB)
in addition, a couple of times the whole serviio source became unavailable on the TV while watching a video - came back by itself after a few seconds, but it was too fast so i couldn't notice anything wrong
ruslanoid
Post Mon May 30, 2011 8:00 am
attaching debug log at the moment of failure
from what i gathered... file with id=24550 played for ~14 minutes then automatically started the next one
hope this will shed some light
(100.68 KiB) Downloaded 789 times
Post Mon May 30, 2011 6:12 pm
what device is on this IP 10.0.0.5 ( kinda strange ip to what router are u using) as it bombarding serviio with m-search requests 42+ in one second ?
ruslanoid
Post Wed Jun 01, 2011 5:02 pm
well... kinda as expected it is a Windows 7 laptop - it has no serviio on it, and no media that serviio looks at, but it has windows media player's library and upnp support, so from what i gather it is bombarding the serviio on the network with m-search requests like crazy
how do i turn it off? or protect serviio from it?
another thought i had is the netgear router i have - it also has some kind of upnp settings - i left it on default which is AdvertisementPeriod of 30 min. and AdvertisementTimeToLive of 4 hops - could this be related in any way?
Post Wed Jun 01, 2011 5:28 pm
On the windows laptop, you can disable the windows media DLNA server.
Here is a pretty good site on how the DLNA server works on windows 7. It gives enough information to disable it.
http://blogs.msdn.com/b/e7/archive/2009/05/12/media-streaming-with-windows-7.aspx
Another thing that I noticed is the 10.0.0.x IP addresses you are using.
Definition: The IP address 10.0.0.1 is a default for some types of network routers including Cisco brand routers. This address may also be used by network servers.
10.0.0.1 is sometimes called a default gateway address as it typically represents the local side of a router's connection to the Internet. 10.0.0.1 is more commonly found in business networks than in homes, which tend to use routers having default addresses in the 192.168.x.x series. Both the 10.x.x.x and 192.168.x.x series are private IP address ranges.
For students: in classful IP networks, 10.0.0.1 is a class A address with default subnet mask 255.0.0.0.
This could be causing issues because the network packets, I think are going into the local side of the router being processed and then back out of the router. Instead of going through the router straight to the DLNA render.
For example My serviio computer is 192.168.2.14 and my renders are 192.168.2.19, 192.168.2.4, 192.168.2.11 .
Edited: added link to windows 7 media streaming so you can disable it.
Post Wed Jun 01, 2011 6:28 pm
moltra wrote:For example My serviio computer is 192.168.2.14 and my renders are 192.168.2.19, 192.168.2.4, 192.168.2.11 .
+1
Same configuration for me. router is on 192.168.1.1 and is used as DNS for all renderers/devices web access.
ruslanoid
Post Thu Jun 02, 2011 7:45 am
thanks,
the netgear router has the ip of 10.0.0.138 and assignes by dhcp addresses starting from 10.0.0.1 - so my serviio pc got it this way. i will try to change the dhcp range to exclude the 10.0.0.1 as it indeed might be causing extra traffic.
moltra wrote:Here is a pretty good site on how the DLNA server works on windows 7. It gives enough information to disable it.
moltra, could you please add the link?
Post Thu Jun 02, 2011 11:41 am
ovidius
Post Sun Jun 24, 2012 6:29 am
ruslanoid, you fix the problem? I have the same situation and try to fix ...
ruslanoid
Post Sun Jun 24, 2012 10:23 am
tbh, not really remember now how it was solved, but i remember disabling the media sharing on other devices on the network - maybe it did the trick
also i am now using a different router then back then - it has different upnp settings perhaps which i remember playing with when it didn't work
ovidius
Post Sun Jun 24, 2012 5:03 pm
Thanks, I'll try
ovidius
Post Tue Jun 26, 2012 5:41 am
I tried all the advice, does not want to run more than approx. 35-40 min.
Remains to change the switch...
ovidius
Post Tue Jun 26, 2012 8:15 pm
I change the switch, no use.
Attach the last minute log file. Some ideas?
ERORS.txt
(11.71 KiB) Downloaded 796 times
Users browsing this forum: Baidu [Spider], Google [Bot] and 77 guests
