[SOLVED] LG BD670 and MKV's
guzmansoldier
Post Tue May 24, 2011 11:07 pm
Re: LG BD670 and MKV's
Here is the output.
C:\Users\DaMaN>C:\"Program Files (x86)"\Serviio\bin\\..\lib/ffmpeg.exe -i e:\Vid
eo\2012\title00.mkv -y -vcodec copy -copyts -acodec libmp3lame -ab 384k -ac 6 -m
ap 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-2-MPEG2TS
.stf
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[matroska,webm @ 02982e40] invalid dts/pts combination
[matroska,webm @ 02982e40] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 59.94 (60000/
1001) -> 29.97 (60000/2002)
Input #0, matroska,webm, from 'e:\Video\2012\title00.mkv':
Duration: 02:37:45.68, start: 0.000000, bitrate: 10248 kb/s
Chapter #0.0: start 0.000000, end 289.538961
title : Chapter 00
Chapter #0.1: start 289.538961, end 714.196528
title : Chapter 01
Chapter #0.2: start 714.196528, end 931.847294
title : Chapter 02
Chapter #0.3: start 931.847294, end 1317.899628
title : Chapter 03
Chapter #0.4: start 1317.899628, end 1532.947794
title : Chapter 04
Chapter #0.5: start 1532.947794, end 1727.208528
title : Chapter 05
Chapter #0.6: start 1727.208528, end 2077.691994
title : Chapter 06
Chapter #0.7: start 2077.691994, end 2427.074361
title : Chapter 07
Chapter #0.8: start 2427.074361, end 2687.834861
title : Chapter 08
Chapter #0.9: start 2687.834861, end 2941.021128
title : Chapter 09
Chapter #0.10: start 2941.021128, end 3326.272661
title : Chapter 10
Chapter #0.11: start 3326.272661, end 3557.169994
title : Chapter 11
Chapter #0.12: start 3557.169994, end 3909.021494
title : Chapter 12
Chapter #0.13: start 3909.021494, end 4200.612794
title : Chapter 13
Chapter #0.14: start 4200.612794, end 4584.896694
title : Chapter 14
Chapter #0.15: start 4584.896694, end 4898.042861
title : Chapter 15
Chapter #0.16: start 4898.042861, end 5102.914194
title : Chapter 16
Chapter #0.17: start 5102.914194, end 5407.485128
title : Chapter 17
Chapter #0.18: start 5407.485128, end 5794.938861
title : Chapter 18
Chapter #0.19: start 5794.938861, end 6116.526794
title : Chapter 19
Chapter #0.20: start 6116.526794, end 6406.850161
title : Chapter 20
Chapter #0.21: start 6406.850161, end 6679.389094
title : Chapter 21
Chapter #0.22: start 6679.389094, end 7009.418794
title : Chapter 22
Chapter #0.23: start 7009.418794, end 7492.768328
title : Chapter 23
Chapter #0.24: start 7492.768328, end 7743.819128
title : Chapter 24
Chapter #0.25: start 7743.819128, end 8199.607794
title : Chapter 25
Chapter #0.26: start 8199.607794, end 8601.409194
title : Chapter 26
Chapter #0.27: start 8601.409194, end 9465.689000
title : Chapter 27
Stream #0.0(eng): Video: mpeg2video, yuv420p, 720x480 [PAR 32:27 DAR 16:9],
9800 kb/s, PAR 186:157 DAR 279:157, 29.97 fps, 29.97 tbr, 1k tbn, 59.94 tbc
Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
title : 3/2+1
Output #0, mpegts, to 'C:\Windows\TEMP\Serviio\transcoding-temp-2-MPEG2TS.stf':
Stream #0.0(eng): Video: mpeg2video, yuv420p, 720x480 [PAR 186:157 DAR 279:1
57], q=2-31, 9800 kb/s, 90k tbn, 29.97 tbc
Stream #0.1(eng): Audio: libmp3lame, 48000 Hz, 5.1, s16, 384 kb/s
title : 3/2+1
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Error while opening encoder for output stream #0.1 - maybe incorrect parameters
such as bit_rate, rate, width or height
C:\Users\DaMaN>
Post Wed May 25, 2011 6:39 am
And this:
C:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe -i F:\Video\2012\title00.mkv -y -vcodec copy -copyts -acodec libmp3lame -ab 448k -ac 6 -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-2-MPEG2TS.stf
guzmansoldier
Post Sat Jun 04, 2011 4:06 am
Well I converted the files to mkv H264 and everything is playing just fine on the LG BD670. Thank you for all your help.
jadrake75
Post Tue Jun 12, 2012 2:06 am
Re: [SOLVED] LG BD670 and MKV's
Hi I am new to the board, but I'd like to understand something in regards to the solution here.
First my setup. Linux server running Serviio. I have been ripping my DVDs and BluRays to disk using MakeMKV (to allow my multiple players in my house access to my library of movies). So I have a variety of MKVs in the following basic configs:
Blu-Ray: vCodec=H264 (High), aCodec=dca
DVD: vCodec=mpeg2video, aCodec=dca
DVD: vCodec=mpeg2video, aCodec=ac3
I have ripping DVDs that have a DTS track only, since I find if I rip multiple audio tracks, the ac3 will be chosen.
I am using a modified LG BluRay config for my BD670 as follows:
<Profile id="23" name="LG BD player" extendsProfileId="1">
        <MediaFormatProfiles>
            <MediaFormatProfile mime-type="video/x-mkv">MATROSKA</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/x-msvideo" name="">AVI</MediaFormatProfile>
        </MediaFormatProfiles>
            <Matches container="matroska" vCodec="mpeg2video" aCodec="dca" />
         <Video targetContainer="mpegts" targetACodec="mp3">
            <Matches container="matroska" vCodec="mpeg2video" aCodec="ac3" />
First off, Blu-Rays play no problem with DTS sound. Using this config, the DVDs with the ac3 audio will play with MP3 sound (2-channel) and I avoid the "Can not play this file error". For the DTS DVDs, it is sending "Dolby Digital" 2-channel (using the ac3 transcode aCodec as above). Is there anyway to get it to send a 5.1 signal? I have tried using aac and lpcm without results.
Based on the thread here, it looks like if I rewrite the MKV as MKV with H.264 and DCA (DTS) audio codec it would play as DTS?
Do I have that correct?
Jason
Post Tue Jun 12, 2012 7:34 am
jadrake75 wrote:...
Could you check on serviio console transcoding tab, don't check "Downmix to stereo", but use "keep original"
jadrake75
Post Tue Jun 12, 2012 2:45 pm
Thanks Ilico - I did check and it is set to "keep original".
I re-encoded the mkv using ffmpeg using a bitrate which outputs ~ the same sized file (+/- 5%) using libx264 video codec (seems a bitrate of "-b 6500K" provides this) but retaining the audio codec and I can confirm this does play in 5.1 on the player. Not ideal, but I suppose workable unless someone else doesn't have suggestions (since this thread is titled [SOLVED] should I start a new one for this discussion?)
Post Tue Jun 12, 2012 8:16 pm
jadrake75 wrote:Not ideal, but I suppose workable unless someone else doesn't have suggestions (since this thread is titled [SOLVED] should I start a new one for this discussion?)
Yes, you can create another topic with your specific problem.
Previous
Return to LG
