Transcoding MKV with OGG audio
deaerator
Post Sat Jun 04, 2011 2:53 pm
I notice some mkv having oggvorbis for audio, and serviio doesn't even recognize the file.
Wondering if there is a solution to transcode mkv with ogg audio.
Unique ID : 231385042008146297583076814617057304578 (0xAE13235B17227EC59075EF83C99E2002)
Complete name \S01E01 - Cartman Gets an Anal Probe.mkv
Format : Matroska
File size : 204 MiB
Duration : 21mn 50s
Overall bit rate : 1 303 Kbps
Encoded date : UTC 2010-04-04 16:16:01
Writing application : mkvmerge v3.0.0 ('Hang up your Hang-Ups') built on Dec 12 2009 15:20:35
Writing library : libebml v0.7.9 + libmatroska v0.8.1
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 21mn 50s
Bit rate : 1 149 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.125
Stream size : 180 MiB (88%)
Title : Main
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Language : English
Format : Vorbis
Format settings, Floor : 1
Codec ID : A_VORBIS
Duration : 21mn 50s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Delay relative to video : 1ms
Stream size : 20.0 MiB (10%)
Title : Main
Writing library : libVorbis 1.0.1 (UTC 2003-09-09)
Language : English
Post Sat Jun 04, 2011 7:01 pm
Re: Transcoding MKV with OGG audio
Could you post "ffmpeg -i" result of this file?
deaerator
Post Sat Jun 04, 2011 7:12 pm
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "<D:\Torrents\South Park Season
s 1-3 DVDRip XviD [PhZ]\Season 01\South Park Complete Season 01 DVDRip XviD [PhZ
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
<D:\Torrents\South Park Seasons 1-3 DVDRip XviD [PhZ]\Season 01\South Park Compl
ete Season 01 DVDRip XviD [PhZ]>: Invalid data found when processing input
Post Sat Jun 04, 2011 7:16 pm
deaerator wrote: Invalid data found when processing input
This is an FFmpeg issue, not serviio.
Don't know what's this.
deaerator
Post Sat Jun 04, 2011 7:56 pm
I used other different servers such as mezzemo,twonky, and PS3Media Server and it will play the file but it won't support the audio codec.
Post Sat Jun 04, 2011 8:47 pm
there will be vorbis support in 0.6
Users browsing this forum: Google [Bot] and 10 guests
