Category vs Content Only vs Folder
kc1
Post Mon Jun 06, 2011 10:32 pm
Maybe this is a dumb question, but here goes
Why doesn't Content Only present only content?
For example if I want to browse by Actor, with presentation mode "Display Category", I have to select the folder for the Actor's first name, and then a list of actors beginning with that name comes up. I expected with presentation mode "Display Content Only" that when I browsed by Actor, I would get a list of actors, sorted alphabetically, but instead I get folders called A [Actors], B [Actors] and so on.
Is this a limitation / feature of serviio or the dlna standard, or something else?
Trying to get Serviio working with Samsung D7000 and ReadyNas NVX without a PC in between
Post Tue Jun 07, 2011 8:30 am
Re: Category vs Content Only vs Folder
Content Only means to display only content of the original category (Artists in this case). So originally you have:
Audio -> Artists -> First initial -> List of names -> List of songs
with Content Only for artists you have
Audio -> First Initial -> List of names -> List of songs
That's how it's designed in Serviio. Basically just flattening the main category.
kc1
Post Tue Jun 07, 2011 8:39 am
Thanks for the explanation.
Do you have plans to makes it even simpler, like
Audio > Artist > List of names > List of songs
Video > Actor > List of names > List of films?
or it that not possible?
Post Tue Jun 07, 2011 9:11 am
That would mean complete configuration of the tree and it's not planned. Some people want deeper hierarchy, some want flatter. The Initial character is there for convenience especially for large libraries so that you don't have to skip 200 entires beginning with A to get to B.
TheZerg
Post Fri Aug 31, 2012 7:54 am
Probably I missed something, but I can not achieve the folder structure you mentioned.
With this I'm getting a structure:
Audio -> First Initial -> List of names (Atrists) -> List of albums -> List of songs
How can I list ALL the songs of an artist (without have to chose an album)?
Any advice would be appreciated.
PS: I just can't say loud enough: Thank you very much for this wonderful piece of software!!!!
Post Thu Sep 06, 2012 8:18 pm
you are right, you cannot list all songs for an artist in a flat structure
Dworter45
Post Mon Sep 26, 2016 12:17 pm
thanks for information... nice informative post
Users browsing this forum: No registered users and 148 guests
