MKV not playing with UE46D6500
mucho
Post Tue Jun 07, 2011 5:32 pm
Hi all
thanks for the software, it's working great so far.
I've been trying to play MKV - they are playing when coming from the USB stick, however, not from the NAS nor the serviio.
I've read about the profiles.xml, but i am far to less of an expert to get it right. I have not changed the default profiles.xml configuration.
Would you guys point me out into the right direction?
Thanks in advance
Post Tue Jun 07, 2011 5:40 pm
Re: MKV not playing with UE46D6500
mucho wrote:Hi all
Thanks in advance
have u selected the " samsung C/D " profile in the console for your device ??
mucho
Post Tue Jun 07, 2011 5:44 pm
...good questions. Where do you select that?
My Transcoding screen looks like this:
respectively, the other screen looks like this (auto profiled)
Screen shot 2011-06-07 at 7.45.40 PM.png (16.31 KiB) Viewed 8420 times
Screen shot 2011-06-07 at 7.43.47 PM.png (19.43 KiB) Viewed 8420 times
mucho
Post Wed Jun 08, 2011 2:51 pm
Hi all
here's an udpdate (from Samsung) this TV, allegedly, does not support playing MKV over anything else than USB. - That is frankly, frustrating.
BUT, I am sure that there are ways to get Serviio to solve that. I have also heard of on-the-fly file encoding (perhaps that's essentially transcoding) eg, mkv -> VOB. Knowing all that, there's gotta be way. And also, I found this here: http://www.avforums.com/forums/lcd-led- ... t-1-a.html
Not that it would do any good with a differnt TV, but perhaps there are similarities.
Thanks for any suggestions and help on this one
Post Sun Jun 12, 2011 7:13 pm
mucho wrote:Hi all
can you post media info and FFmpeg -i on the file that does not play please because with currently selected profile MKV files should play fine.
see my signiture for howto's if required :)
