Setup to play media on Android devices ... working
pur_berger
Post Wed Jun 08, 2011 9:55 pm
Just found out cause got one of these Xoom tabs not able playing avi and looking for a solution to make it possible ...
There is a setup for playing mkv with subtitles ... on Android ....
What is needed:
Serviio of course
UpnPlay (availible on the market)
MoboPlayer (also available on the market) together with the MoboCodec (you are going to be prompted when starting Mobo the first time if it is required)
Setup: Basically ... nothing but in Mobo to set to ""Default using soft-decoding" in the "Playback" section and set the subtitle size. Everything else is default (assuming Serviio is working correct).
When you start UpnPlay you see servio to select with all options, when selecting a File take Mobo as player ... that's it :-)
Note hat using Not the setting in Mobo "Default using soft-decoding" caused mobo to crash (or better to become unresponsive)
Have Fun!
Post Thu Jun 09, 2011 3:34 pm
Re: Setup to play media on Android devices ... working
You can also try Skifta. I use it on my droid X
pur_berger
Post Thu Jun 09, 2011 9:24 pm
Tried it but it seemed a little unstable to ma as when switching around it started to show only empty folders. UpnPlay is ... not that handsome - but it stayed stable and much faster in Terms of Loading ...
but basically what I'm happy about is the possibility to stream all the Anime content to my tab without going through the trouble and extracting the subs and letting my girlfriend sleep next to me while enjoying my shows :)
Post Thu Jun 09, 2011 10:45 pm
I will have to try Upnplay.
pur_berger
Post Fri Jun 10, 2011 9:28 am
wow - should read bevor posting ;) .... call me Mr. Typo ...
rgalverson
Post Fri Jun 17, 2011 6:42 pm
Hey, this is great, especially since it can play wtv files now. However, my poor android phone (Mytouch 4g) can't keep up with a 1080i wtv video and it plays in slow motion. I thought I would use ffmpeg to scale the size to my screen (800x480), but it doesn't seem Serviio gives that option for some reason. Is the suggested thing to use the maxVbitrate option to scale down the data rate and still have my phone rescale the video size? If so, what bitrate max makes sense for a wifi situation where I seem to usually connect at 65 Mbps (according to my phone).
Post Sat Jun 18, 2011 8:55 am
rgalverson wrote:... I thought I would use ffmpeg to scale the size to my screen (800x480), but it doesn't seem Serviio gives that option for some reason. Is the suggested thing to use the maxVbitrate option to scale down the data rate and still have my phone rescale the video size? If so, what bitrate max makes sense for a wifi situation where I seem to usually connect at 65 Mbps (according to my phone).
Feature request exist about screen format: https://bitbucket.org/xnejp03/serviio/i ... n-renderer
The video bitrate option had sense only with transcoded media, you can add the option into the profile and try different value...
hohum
Post Mon Jun 20, 2011 5:40 am
I have a Windows Home Server (WHS) and am running Serviio on it.
I have a Droid X and have UPnPlay and MoboPlayer. This set up works beautifully for virtually everything.
However, there are a few videos that I would like Serviio to transcode for my Droid X so it can actually play it. Unfortunately, I have no programming skill and was hoping someone knew how to write up a profile for me. I don't mean to hijack this thread; however, it seemed as if this is the crowd I need to be talking to. :)
powerfuljackson
Post Mon Aug 08, 2011 2:33 am
have you tried the following method http://www.bigasoft.com/articles/how-to-play-wtv-files.html? with it, you can easily Play WTV File on Mac, Windows XP/Vista, iPad, iPhone, PS3, android phone, blackberry and more
ronsmits
Post Fri Aug 26, 2011 7:14 am
Late to this topic, but I thought I would post my setup anyway.
To play all content on my samsung galaxy tab 10.1v I use BubbleUpnp and mobyplayer. To make my android play everything I set the profile for bubbleUpnp to "Toshiba Rezga". All 720p and higher mkv's get transcoded to mpeg and gets played without any problem.
just my 0.02 cts
Ron
Post Fri Aug 26, 2011 6:43 pm
wait on 0.6 of serviio and then use (rockplayer/skifta) for best performance on android devices, all files work with the standard generic profile, so no quality loss ;).
lfventura
Post Fri Nov 11, 2011 5:13 am
Hi...
I tried the proposed setup (upnp + moboplayer) but I still not able to get any subtitles in my android devices. I tried in a Motorola Atrix and in a Galaxy Tab 10.1. In Both no subtitles.
In my LG TV and my Samsung TV subtitles are fine.
Which profile are you using? Does it need any other special setup to get it working on android?
thanks in advance
Regards
iMcRabbi
Post Fri Nov 11, 2011 5:28 am
Re: Re: Setup to play media on Android devices ... working
lfventura wrote:Hi...
thanks in advance
Regards
I can't get subs on any device.
Sent from my LG-P999 using THE FORCE
Heffaklump
Post Tue Jan 17, 2012 7:33 pm
I have serviio running but after downloading and installing UpnPlay on my phone I can´t get it to connect to anything but my local files. My serviio server does not show up on my phone :( I use a HTC Gratia btw.
I use windows 7 and its firewall and I also have avast!
Any suggestions on how I can make this work?
Post Tue Jan 17, 2012 9:09 pm
Heffaklump wrote:I have serviio running but after downloading and installing UpnPlay on my phone I can´t get it to connect to anything but my local files. My serviio server does not show up on my phone :( I use a HTC Gratia btw.
http://wiki.serviio.org/doku.php?id=androidtools
Heffaklump
Post Wed Jan 18, 2012 6:24 pm
Thank you for the reply Cerberus. But does this mean that I also need to get the Skifta desktop software? I thought this would work through using the Serviio program?
Post Wed Jan 18, 2012 6:26 pm
no you do not have to use skifta. You can use upnplay or skifta. You are connecting to your home wi-fi network for these to work, right?
Can anything else on your network see serviio?
Heffaklump
Post Wed Jan 18, 2012 6:33 pm
Using skifta I managed to view videos from my phone on my TV. What I really want is to do the opposite. Watch moives from my computer on my phone.
I´m using a Netgear CG3100 modem/router and also the windows firewall. I have enabled UPnP and streaming from my computer to my TV is working quite well, but that is using a network cable and not wireless.
So yes, my TV can see serviio. And I am using my home wi-fi network for this. At least that is what I want to do...
I also tried the upnplay and it looked like servviio picked it up, it said so in the console. But my phone never got connected to anything else than the local folders on my phone.
Post Wed Jan 18, 2012 6:46 pm
did you open the upnplay app up on your phone after you are connected to your wifi network. After you do that in around 10-30 seconds the serviio server should show up, click on the serviio server and it should pop up your serviio presentation folders.
Heffaklump
Post Wed Jan 18, 2012 6:56 pm
moltra wrote:did you open the upnplay app up on your phone after you are connected to your wifi network. After you do that in around 10-30 seconds the serviio server should show up, click on the serviio server and it should pop up your serviio presentation folders.
Using Skifta I can see in my Netgear router that my phones internal ip and ports are open and working. Once I switch to upnplay they disappear and I only see some other device (my TV or maybe Serviio, I´m not sure).
But for what ever reason none of these programs will let me connect my phone to serviio in any working way. I do see upnplay in the serviio window but it is marked red (inactive) Even though it is running on my phone. My best guess is that I need to open up ports in either my router or in windows firewall. But I´m not sure which ports or for what internal ip....
And in the UPnP settings for my router all I can do is turn it on or off, then only watch which devices connects and what ports, protocols and ips they use.
Users browsing this forum: Baidu [Spider] and 15 guests
