C6500 after 0.5.2 install
celwin
Post Sun Jun 12, 2011 8:56 pm
C6500 used to work fine with 051 but since upgrading to 052 I get a "Request cannot be completed.." error everytime I attempt to play a movie from serviio. I've tried resintalled, restarting service. Same result. Any help would be accepted. Log follows:
2011-06-12 16:34:59,763 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2011-06-12 16:34:59,763 INFO [ServiioConsole] Leaving Serviio Console
2011-06-12 16:35:00,483 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2011-06-12 16:35:02,793 INFO [MediaServer] ------------------------------------------------------------------------
2011-06-12 16:35:02,793 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-06-12 16:35:02,793 INFO [MediaServer] Petr Nejedly 2009-2011
2011-06-12 16:35:02,793 INFO [MediaServer] http://www.serviio.org
2011-06-12 16:35:02,793 INFO [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2011-06-12 16:35:02,793 INFO [MediaServer] OS Windows 7 amd64 6.1
2011-06-12 16:35:02,793 INFO [MediaServer] File encoding: windows-1252
2011-06-12 16:35:02,853 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-06-12 16:35:02,883 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-06-12 16:35:03,513 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-06-12 16:35:03,753 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-06-12 16:35:03,823 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-06-12 16:35:03,873 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-06-12 16:35:03,913 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-06-12 16:35:03,953 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-06-12 16:35:03,983 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-06-12 16:35:04,043 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-06-12 16:35:04,063 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-06-12 16:35:04,173 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-06-12 16:35:04,353 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-06-12 16:35:04,403 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-06-12 16:35:04,463 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-06-12 16:35:04,823 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-06-12 16:35:04,833 INFO [WebServer] Socket buffer set to 65535 bytes
2011-06-12 16:35:04,843 INFO [WebServer] WebServer starting on port 8895
2011-06-12 16:35:04,963 INFO [Device] Created UPnP Device with UUID: 204683ed-9f48-3c47-b70d-0da4ab7276fa, bound address: 192.168.1.4
2011-06-12 16:35:04,973 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-06-12 16:35:04,973 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-06-12 16:35:04,973 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-06-12 16:35:04,973 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-06-12 16:35:04,973 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-06-12 16:35:04,973 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-06-12 16:35:04,973 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1307910904973, LastAccessTime = 1307910904973, getTimeToLiveSeconds() = -1, createTime = 1307910904973 ]
2011-06-12 16:35:04,983 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-06-12 16:35:04,983 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-06-12 16:35:04,983 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-06-12 16:35:04,983 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-06-12 16:35:04,983 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-06-12 16:35:04,983 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-06-12 16:35:04,983 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-06-12 16:35:04,983 INFO [CompositeCacheConfigurator] Finished configuration in 10 ms.
2011-06-12 16:35:04,983 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-06-12 16:35:04,983 INFO [EventDispatcher] Starting EventDispatcher
2011-06-12 16:35:04,983 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-06-12 16:35:04,993 INFO [RendererSearchSender] Searching for Renderer devices
2011-06-12 16:35:04,993 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-06-12 16:35:04,993 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet NIC (NDIS 6.20)) and address 192.168.1.4, timeout = 0
2011-06-12 16:35:15,924 INFO [ServiioConsole] Starting Serviio Console
2011-06-12 16:35:15,974 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-06-12 16:35:16,614 INFO [Messages] Loaded console message bundle for locale: en
2011-06-12 16:35:17,434 INFO [Messages] Loaded console message bundle for locale: en
2011-06-12 16:35:17,534 INFO [UpdateChecker] Checking if a new version is available
2011-06-12 16:35:24,344 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-06-12 16:35:24,554 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-06-12 16:35:31,154 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-06-12 16:35:31,154 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
Post Sun Jun 12, 2011 9:38 pm
Re: C6500 after 0.5.2 install
celwin
Post Sun Jun 12, 2011 11:57 pm
zip wrote:Look at this thread: viewtopic.php?f=10&t=2254&hilit=c6500
I did. All categories are set to default "Display category" like they were previously. I even tried removing the <DeviceDescription> section under Profile 7. Nada
celwin
Post Mon Jun 13, 2011 1:48 am
Issue resolved. It was my router. Upon rebooting my router all is well.
Post Mon Jun 13, 2011 1:52 am
celwin wrote:Issue resolved. It was my router. Upon rebooting my router all is well.
that a relief i was scratching my head trying to think what was wrong lolol
