undefined function curl_init line 44
oikon
Post Sun Jun 12, 2011 7:41 pm
while starting serviio web service on my synology ds411+II the integrated server window gives the following error message.
Fatal error: Call to undefined function curl_init() in /volume1/web/serviio/lib/RestRequest.inc.php on line 44
What can I do? Does anyone know how to fix it?
The service onece run fine but without knowing what I've done all for a sudden I can't access the service-window any more.
Serviio itself is running fine and serving all the data to the media-player.
Thanks for your help.
Post Sun Jun 12, 2011 10:43 pm
Re: undefined function curl_init line 44
oikon wrote:while starting serviio web service on my synology ds411+II the integrated server window gives the following error message.
the third party webui ???
oikon
Post Mon Jun 13, 2011 7:59 am
you are right - may be I should have post it under "Third-party tools integration"
What more do you need for help?
Post Mon Jun 13, 2011 11:03 pm
Leave it with me will fire an email off to the dev of that project and see what he says..
i currently have 3 question on hold for users here about teh webui and havent had reple from him in few days..
bifrost.sk
Post Thu Jun 16, 2011 6:18 pm
exactly same problem here...
(ds211j dsm 3,1)
Post Wed Jul 06, 2011 10:40 pm
Sent: Wed Jul 06, 2011 7:59 am
To: Cerberus
Re: Web UI
Sorry for the late reply - I have missed the forum notification.
PHP WebUI requires cURL extension installed - it won't work without it, sorry.
so in short install cURL on teh device and it will work :)
pilothaz
Post Fri Jul 08, 2011 7:48 pm
I have serviio installed and cURL using unionfs virtual drive for usr/local and /var folders...
How could I have this setup for pointing to that directory to have this working?
Post Fri Jul 08, 2011 7:55 pm
pilothaz wrote:I have serviio installed and cURL using unionfs virtual drive for usr/local and /var folders...
its the curl extention you need not curl itself :) what version of linux is running on the NAS if its unbuntu then command is
sudo apt-get install php5-curl
pilothaz
Post Fri Jul 08, 2011 8:16 pm
I am running it on a freeNAS box so, unix. Would be an pkg_add context. Will look it up when I am home.
Post Fri Jul 08, 2011 9:09 pm
pilothaz wrote:I am running it on a freeNAS box so, unix. Would be an pkg_add context. Will look it up when I am home.
ah ok thanks i wasnt sure so your command would be this
pkg_add -r php5-curl
http://sourceforge.net/apps/phpbb/freen ... =15&t=2085 may also help you out as they take about how to setup Curl on freeNAS :)
Users browsing this forum: Baidu [Spider] and 2 guests
