Video in lost on using x264
erro
Post Mon Jun 13, 2011 3:23 pm
I have used to transcode and Xvid file to x264 (MP4 file, while adding subtitles).
On the Xvid I can fast-forward, rewind and pause the movie.
However, when trying the above with x264. The playback 'crash' , sometimes getting the message "playback is not available", and when I try to playback again there is only voice with black screen (no video).
I need to wait for quite long time (sometimes even a day, I don't know why is that probably some of the serviio temp files or the m2ts needs to be deleted) in order to play it from the start.
Please advise.
Post Mon Jun 13, 2011 6:28 pm
Re: Video in lost on using x264
What is your device?
What is the serviio profile selected?
erro
Post Mon Jun 13, 2011 8:50 pm
37EX505.
Using latest serviio with SONY profile.
The movie is x264 with AC3 so when I look at the log it seem ok, no 'codecing' just moving it to m2ts .
Has anyone encounter something similar ?
Post Tue Jun 14, 2011 9:43 am
Could you post "ffmpeg -i" and "MediaInfo" result of your original x264/ac3 file? (see signature for links)
erro
Post Wed Jun 15, 2011 4:40 pm
Here is the ffmpeg -i information (ffmpeg.txt)
and the mediainfo (mediainfo.txt)
mediainfo.txt
(2.85 KiB) Downloaded 747 times
ffmpeg.txt
(1.52 KiB) Downloaded 758 times
erro
Post Sun Jun 19, 2011 6:50 am
Illico , zip , any news ?
Were the logs helpful ?
Post Sun Jun 19, 2011 9:07 am
This D:\my videos\greys anatomy\Greys.Anatomy.S07E18.HDTV.x264-LOL_HEB.mp4
is a MP4 container with AVC/x264 video and AC3 audio.
With the Sony Profile selected, this file must be remuxed into MPEGTS/x264/AC3.
If video crashed, this is probably due to the x264 encoding options used that were not supported by Sony.
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=hex / subme=7 / psy=1 / psy_rd=0.90:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=1 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=16.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
I used to say this is b_pyramid=2 , but I'm not sure 100%
You have to reencode the original...
erro
Post Mon Jun 20, 2011 11:04 am
will try.
10x.
erro
Post Mon Jun 20, 2011 8:16 pm
Illico.
Tried it with b_pyramid=1 and b_pyramid=0 . Didn't work.
If you have SONY TV , you can easily check it even with a short/small file/movie size (play, pause , and then play it again or rewind).
