Linux: too slow to scan folders and keeps disconnecting
zamana
Post Mon Jun 13, 2011 10:44 pm
Hi!
My PC has 3 OSs installed: Windows 7, Ubuntu 11.04 and Linux Mint 11 (all of them 64 bits).
In Windows, Serviio 0.5.2 is fast and stable: it scans my folders quickly and keeps connected with my TV (Samsung UN40C6900) all the time.
But... if I boot one of my Linux systems (anyone), Serviio is very, very, very slow to scan my folders (NTFS mounted under Linux) and my TV keeps disconnecting after 5 minutes or so. Nothing special on the logs.
Question: the problem is on the Linux OS or in the Serviio Linux version?
Anyone has experienced the same problems?
Regards.
Post Tue Jun 14, 2011 2:54 am
Re: Linux: too slow to scan folders and keeps disconnecting
can you post your linux serviio.log? It could be the NTFS under linux.
zamana
Post Tue Jun 14, 2011 4:30 am
Sure.
But can I send the log just to you? I wouldn't like to disclosure my movie titles... (or edit the log file).
Thanks for reply.
Post Tue Jun 14, 2011 5:39 am
zamana wrote:Sure.
Thanks for reply.
like that is it ;) dont worry we dont mind what type of pron your into aslong as we can fix your problem..
Post Tue Jun 14, 2011 9:13 am
zamana wrote:Question: the problem is on the Linux OS or in the Serviio Linux version?
Serviio Linux version is exactly the same, byte for byte, as the other versions.
zamana
Post Wed Jun 15, 2011 3:06 am
You replied my question.
Thank you very much.
Regards
