Cant play any AVI file
jton219
Post Thu Jun 16, 2011 5:06 am
Hi Everyone.
Just got a Panasonic Viera P42s30. Firmware 1.1.. Installed Serviio and added my library. All my videos are in MKV or AVI format. All of the MKVs play. None of the AVIs play. All the audio msuic files ive tested so far play great. Serviio is awesome except for the .avi files.
here is the ffmpeg thing. Im currently using the Panasonic Viera profile. Transcoding on.
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "J:\Media\The Last Dragon\The.L
ast.Dragon.avi"
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
Input #0, avi, from 'J:\Media\The Last Dragon\The.Last.Dragon.avi':
encoder : VirtualDubMod 1.5.10.2 (build 2540/release)
Duration: 01:48:21.00, start: 0.000000, bitrate: 902 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 612x328 [PAR 1:1 DAR 153:82], 25 tbr, 25
tbn, 25 tbc
Stream #0.1: Audio: mp3, 48000 Hz, 2 channels, s16, 126 kb/s
Any help.. Most of my videos are avi format.
jton219
Post Thu Jun 16, 2011 5:09 am
Re: Cant play any AVI file
OGM also not playing
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "J:\Media\Princess Mononoke\pri
ncess.mononoke.ogm"
686-mingw32-
Input #0, ogg, from 'J:\Media\Princess Mononoke\princess.mononoke.ogm':
Duration: 02:08:10.08, start: 0.000000, bitrate: 2031 kb/s
Chapter #0.0: start 0.000000, end 448.120000
title : Chapter 1
Chapter #0.1: start 448.120000, end 732.200000
title : Chapter 2
Chapter #0.2: start 732.200000, end 832.480000
title : Chapter 3
Chapter #0.3: start 832.480000, end 1091.440000
title : Chapter 4
Chapter #0.4: start 1091.440000, end 1235.760000
title : Chapter 5
Chapter #0.5: start 1235.760000, end 1351.440000
title : Chapter 6
Chapter #0.6: start 1351.440000, end 1486.600000
title : Chapter 7
Chapter #0.7: start 1486.600000, end 1673.600000
title : Chapter 8
Chapter #0.8: start 1673.600000, end 1909.040000
title : Chapter 9
Chapter #0.9: start 1909.040000, end 2110.000000
title : Chapter 10
Chapter #0.10: start 2110.000000, end 2563.840000
title : Chapter 11
Chapter #0.11: start 2563.840000, end 3133.040000
title : Chapter 12
Chapter #0.12: start 3133.040000, end 3352.680000
title : Chapter 13
Chapter #0.13: start 3352.680000, end 3893.040000
title : Chapter 14
Chapter #0.14: start 3893.040000, end 4198.880000
title : Chapter 15
Chapter #0.15: start 4198.880000, end 4584.560000
title : Chapter 16
Chapter #0.16: start 4584.560000, end 4877.120000
title : Chapter 17
Chapter #0.17: start 4877.120000, end 5045.040000
title : Chapter 18
Chapter #0.18: start 5045.040000, end 5387.560000
title : Chapter 19
Chapter #0.19: start 5387.560000, end 5673.080000
title : Chapter 20
Chapter #0.20: start 5673.080000, end 6096.840000
title : Chapter 21
Chapter #0.21: start 6096.840000, end 6777.000000
title : Chapter 22
Chapter #0.22: start 6777.000000, end 7219.200000
title : Chapter 23
Chapter #0.23: start 7219.200000, end 7409.480000
title : Chapter 24
Chapter #0.24: start 7409.480000, end 7690.080000
title : Chapter 25
Stream #0.0: Video: mpeg4, yuv420p, 640x336, 25 fps, 25 tbr, 25 tbn, 25 tbc
TITLE : Princess Mononoke
Stream #0.1(English[eng]): Audio: vorbis, 48000 Hz, stereo, s16, 120 kb/s
ENCODED_USING : Made with BeSweet v1.5b28
ENCODER_URL : http://DSPguru.doom9.org
LWING_GAIN : 2.249
LANGUAGE : English[eng]
Stream #0.2(Japanese[jpn]): Audio: vorbis, 48000 Hz, stereo, s16, 120 kb/s
LWING_GAIN : 1.465
LANGUAGE : Japanese[jpn]
Stream #0.3(English[eng]): Subtitle: [0][0][0][0] / 0x0000
leehouse
Post Tue Aug 30, 2011 2:36 pm
I don't know if anyone has found a means around this issue, but I have the same TV and it also won't play .avi through serviio... which is particularly odd as the .avi files I tested play fine if I go through a regular DLNA connect to my computer sharing files.
If anyone has any idea on how to fix this I'd appreciate it.
If more info is necessary, which is likely, I'll try to supply it when I get done with work and have access to the computer.
Post Tue Aug 30, 2011 3:58 pm
In the default Panasonic Profile, AVI files are delivered in native format (with video/divx mime-type)(supposed supported by the TV).
But you could modify the profile to transcode avi files (all avi files) into mpev2video codec supported by the TV by this way:
- Add avi transcoding:
            <Matches container="avi" />
            <Matches container="asf" />
            <Matches container="flv" />
            <Matches container="ogg" />
j22barb
Post Wed Aug 31, 2011 10:12 pm
Try this profile it worked for me with another Viera TV.
<Profile id="12" name="Panasonic Viera" extendsProfileId="1">
<ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.PanasonicDLNAMessageBuilder</ContentDirectoryMessageBuilder>
<MediaFormatProfiles>
<!-- Not supported by TC-P42X3 -->
<!-- <MediaFormatProfile mime-type="video/divx">AVI</MediaFormatProfile> -->
</MediaFormatProfiles>
<!-- remux DTS in MKV to AC3 -->
<Matches container="matroska" vCodec="h264" aCodec="dca" />
Post Wed Aug 31, 2011 10:17 pm
maybe we just need to find a universal mime type for AVI.
Return to Panasonic
