This MKV-file is not being listed by Sony Bravia
kot
Post Thu Jun 16, 2011 6:13 am
It is not, that the TV would not play it. It is that it does not even list it... Here are the parameters.
  • ffmpeg -i
    FFmpeg version 0.6.1, Copyright (c) 2000-2010 the FFmpeg developers
      built on Feb  9 2011 00:58:52 with gcc 4.2.1 20070719  [FreeBSD]
      configuration: --prefix=/opt --mandir=/opt/man --enable-shared --enable-gpl --enable-postproc --enable-avfilter --enable-avfilter-lavf --enable-pthreads --enable-x11grab --enable-memalign-hack --cc=cc --extra-cflags=-msse -I/opt/include/vorbis -I/opt/include --extra-ldflags=-L/opt/lib --extra-libs=-pthread --disable-debug --enable-runtime-cpudetect --enable-libopencore-amrnb --enable-version3 --enable-libopencore-amrwb --enable-version3 --enable-libdirac --enable-libfaac --enable-nonfree --enable-libfaad --enable-libfaadbin --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-libschroedinger --enable-libspeex --enable-libtheora --disable-vdpau --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxvid
      libavutil     50.15. 1 / 50.15. 1
      libavcodec    52.72. 2 / 52.72. 2
      libavformat   52.64. 2 / 52.64. 2
      libavdevice   52. 2. 0 / 52. 2. 0
      libavfilter    1.19. 0 /  1.19. 0
      libswscale     0.11. 0 /  0.11. 0
      libpostproc   51. 2. 0 / 51. 2. 0
    [matroska @ 0x805652010]Estimating duration from bitrate, this may be inaccurate
    Seems stream 0 codec frame rate differs from container frame rate: 47.95 (5000000/104271) -> 23.98 (24000/1001)
    Input #0, matroska, from 'Обитаемый остров.Фильм второй.mkv':
        doctype         : matroska
      Duration: 01:47:07.41, start: 0.000000, bitrate: N/A
        Stream #0.0(rus): Video: h264, yuv420p, 1280x544 [PAR 1:1 DAR 40:17], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
          title           : Release for HDCLUB
        Stream #0.1(rus): Audio: dca, 48000 Hz, 6 channels, s16
          title           : DTS 5.1 @ 1536 kbps
        Stream #0.2(eng): Subtitle: 0x0000
  • mediainfo
    Complete name                    : Обитаемый остров.Фильм второй.mkv
    Format                           : Matroska
    File size                        : 6.54 GiB
    Duration                         : 1h 47mn
    Overall bit rate                 : 8 737 Kbps
    Encoded date                     : UTC 2009-08-14 13:00:04
    Writing application              : mkvmerge v2.9.7 ('Tenderness') built on Jul  1 2009 18:43:35
    Writing library                  : libebml v0.7.7 + libmatroska v0.8.1
    Format profile                   : High@L4.1
    Format settings, CABAC           : Yes
    Format settings, ReFrames        : 9 frames
    Muxing mode                      : Container profile=Unknown@4.1
    Codec ID                         : V_MPEG4/ISO/AVC
    Duration                         : 1h 47mn
    Bit rate                         : 7 227 Kbps
    Width                            : 1 280 pixels
    Height                           : 544 pixels
    Display aspect ratio             : 2.35:1
    Frame rate                       : 23.976 fps
    Bits/(Pixel*Frame)               : 0.433
    Stream size                      : 5.28 GiB (81%)
    Title                            : Release for HDCLUB
    Writing library                  : x264 core 68 r1183M f21daff
    Encoding settings                : cabac=1 / ref=9 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=12 / nr=0 / decimate=0 / mbaff=0 / bframes=5 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=7227 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.80
    Language                         : Russian
    Format                           : DTS
    Format/Info                      : Digital Theater Systems
    Codec ID                         : A_DTS
    Duration                         : 1h 47mn
    Bit rate                         : 1 510 Kbps
    Channel(s)                       : 6 channels
    Channel positions                : Front: L C R, Side: L R, LFE
    Bit depth                        : 16 bits
    Stream size                      : 1.13 GiB (17%)
    Title                            : DTS 5.1 @ 1536 kbps
    Language                         : Russian
    Text
    Format                           : UTF-8
    Codec ID                         : S_TEXT/UTF8
    Codec ID/Info                    : UTF-8 Plain Text
    Language                         : English
FreeBSD port of Serviio is now in the tree. Please, try using it and share your experience.
Post Thu Jun 16, 2011 7:45 am
Re: This MKV-file is not being listed by Sony Bravia
kot wrote:...FFmpeg version 0.6.1, Copyright (c) 2000-2010 the FFmpeg developers
Do you try with the ffmpeg version released with serviio: http://download.serviio.org/opensource/ ... 303.tar.gz
Post Thu Jun 16, 2011 9:11 am
FFmpeg should be ok for this one. Can you see something in the (detailed) log to see if the file has been added or not and why? Might be the russian characters - do you have other with russian file names that are added?
kot
Post Fri Jun 17, 2011 1:45 am
zip wrote:FFmpeg should be ok for this one. Can you see something in the (detailed) log to see if the file has been added or not and why? Might be the russian characters - do you have other with russian file names that are added?
Yes, I do have plenty of other files with Cyrillic characters in their names, that's not the problem. In fact, the first episode of this same movie (in AVI format) is named the same (except for the episode number and extension) and sits in the same directory with the same file ownership and permissions.
I wish, there was a way to list the content of the Derby database from command-line, so that I could verify, what is in there... But the log does contain the following entries:
2011-06-16 21:41:52,057 DEBUG [LibraryAdditionsCheckerThread] Found file 'Обитаемый остров.Фильм второй.mkv', checking if it's already in the Library
2011-06-16 21:41:52,057 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Обитаемый остров.Фильм второй.mkv
2011-06-16 21:41:52,062 DEBUG [MediaItemDAOImpl] Media item Обитаемый остров.Фильм второй.mkv already exists in DB
Post Fri Jun 17, 2011 8:26 am
Ok, so it should be there. Which category are you looking at? Folders? Any chance of trying Intel tools AV Media Controller to see if the file is shown there?
kot
Post Sat Jun 18, 2011 4:59 am
zip wrote:Ok, so it should be there. Which category are you looking at? Folders? Any chance of trying Intel tools AV Media Controller to see if the file is shown there?
I tried looking for it by name — both the title and the name of the folder. It is supposed to be right next to the first episode under both methods, but is not...
kot
Post Fri Nov 11, 2011 4:28 pm
This is still a problem with Serviio-0.6.0.1
Users browsing this forum: Baidu [Spider] and 27 guests
