Can't play AVI files on Sony DBP-S570
CarlosC
Post Fri Jun 17, 2011 11:34 am
I can't play several .avi files, here's the info:
Seems stream 0 codec frame rate differs from container frame rate: 59.94 (2000000/33367) -> 29.97 (30000/1001)
Input #0, avi, from 'd:\Series Animadas\Los Defensores De La Tierra\01-Escape de Mongo.avi':
    encoder         : VirtualDubMod 1.5.10.2 (build 2542/release)
  Duration: 00:21:59.51, start: 0.000000, bitrate: 1241 kb/s
    Stream #0.0: Video: h264, yuv420p, 640x480 [PAR 1:1 DAR 4:3], 29.97 fps, 29.97 tbr, 29.97 tbn, 59.94 tbc
    Stream #0.1: Audio: mp3, 48000 Hz, 2 channels, s16, 128 kb/s
    Stream #0.2: Audio: mp3, 44100 Hz, 2 channels, s16, 112 kb/s
Could it be because of "Seems stream 0 codec frame rate differs from container frame rate: 59.94 (2000000/33367) -> 29.97 (30000/1001)"??
Otherwise, Serviio has been flawless. Great great job. Looking forward to 0.6 :D
Post Fri Jun 17, 2011 11:45 am
Re: Can't play AVI files on Sony DBP-S570
Not sure h264 video codec under avi container were supported by S570.
Could you try to add this in the Sony BDP profile?
<!-- remux mp4 container files to mpeg-ts to allow seeking -->
<!-- this also fixes the renderer's jerky playback of mov container files such as iPhone 4 HD video recordings -->
CarlosC
Post Fri Jun 17, 2011 11:54 am
That should go in the transcoding section, right?
Edit: ah, I see now, there's already a section like that there, It's just adding a line, not the whole block.
Post Fri Jun 17, 2011 11:57 am
CarlosC wrote:Edit: ah, I see now, there's already a section like that there, It's just adding a line, not the whole block.
Yes
CarlosC
Post Fri Jun 17, 2011 12:03 pm
Did as you told me but Serviio would not start. Found the following in the logs:
011-06-17 09:00:28,806 ERROR [XmlUtils] XML Profiles.xsd didn't pass validation, reason: cvc-enumeration-valid: Value 'h264' is not facet-valid with respect to enumeration '[mp3, mp2, ac3, aac, dca, wmav2, wmapro, lpcm]'. It must be a value from the enumeration.
2011-06-17 09:00:28,806 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: org.serviio.profile.ProfilesDefinitionException: Profiles XML file is not valid (according to the schema). Check the log.
Now, if I just rename those files to .mp4 would they work??
Edit again: found the error, should be vCodec... will try correcting that.
CarlosC
Post Fri Jun 17, 2011 12:15 pm
Ok, Serviio started fine, went to the TV and it's displaying the following message:
"The file is damaged or not compatible" (prints the message in spanish, but that's the translation)
CarlosC
Post Mon Jun 20, 2011 10:20 pm
Well, I've tried with several other things and they didn't work. :(
Post Tue Jun 21, 2011 6:24 am
Could you post MediaInfo tool result of this avi file?
CarlosC
Post Tue Jun 21, 2011 12:05 pm
Format profile                   : High@L5.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 2 frames
Codec ID                         : H264
Duration                         : 21mn 59s
Bit rate                         : 984 Kbps
Width                            : 640 pixels
Height                           : 480 pixels
Display aspect ratio             : 4:3
Frame rate                       : 29.970 fps
Bits/(Pixel*Frame)               : 0.107
Stream size                      : 155 MiB (79%)
Writing library                  : x264 core 47 svn-533
Encoding settings                : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x3:0x133 / me=hex / subme=6 / brdo=0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / chroma_qp_offset=0 / slices=1 / nr=0 / decimate=1 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=15 / direct=2 / wpredb=1 / bime=0 / keyint=250 / keyint_min=25 / scenecut=40 / rc=cqp / qp=24 / ip_ratio=1.40 / pb_ratio=1.30
I guess that 5.1 profile is the problem, am I right?
Post Tue Jun 21, 2011 1:00 pm
CarlosC wrote:I guess that 5.1 profile is the problem, am I right?
Right 100%
Post Tue Jun 21, 2011 1:06 pm
CarlosC wrote:Format settings, ReFrames : 2 frames
Width : 640 pixels
Height : 480 pixels
But its strange, because 2RefFrames with 640x480 is a low resolution profile (2 or 2.1)
http://en.wikipedia.org/wiki/H.264/MPEG ... _buffering
You could try this tool to only change the profile to 4.0 on h264 header for example:
viewtopic.php?f=17&t=2118
CarlosC
Post Mon Jun 27, 2011 9:18 pm
I was gonna open a new thread but I decided to post here cause it's the same issue on the same behaviour, but a different issue I think, as this one has a 4.1 profile that should be playable.
The following can't be played:
  configuration: --enable-static --disable-shared --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --arch=x86 --enable-runtime-cpudetect --enable-w32threads --target-os=mingw32 --cross-prefix=i686-mingw32-
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 0 /  0.16. 0
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.92. 0 / 52.92. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.72. 0 /  1.72. 0
  libswscale     0.12. 0 /  0.12. 0
[matroska,webm @ 0158bcf0] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (20000000/417083) -> 23.98 (20000000/834166)
Input #0, matroska,webm, from 'd:\Pelφculas\The Lord Of The Rings\2001 - The Fellowship Of The Ring.mkv':
  Duration: 03:48:18.73, start: 0.000000, bitrate: 3072 kb/s
    Stream #0.0(eng): Video: h264, yuv420p, 1920x800, PAR 1:1 DAR 12:5, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
      title           : TLOTR-I
    Stream #0.1(eng): Audio: dca, 48000 Hz, 7 channels (FL|FR|FC|LFE|BC|SL|SR),s16, 1536 kb/s
      title           : DTS-CORE ES6.1 1536K eng
    Stream #0.2(chi): Audio: dca, 48000 Hz, 7 channels (FL|FR|FC|LFE|BC|SL|SR),s16, 1536 kb/s
      title           : DTS-ES 6.1 1536K chinese
MediaInfo data:
UniqueID/String                  : 245425769623178141373790062165608163946 (0xB8A348ACA1CEBF419B46631FD860EA6A)
CompleteName                     : D:\Películas\The Lord Of The Rings\2001 - The Fellowship Of The Ring.mkv
Format                           : Matroska
FileSize/String                  : 22.5 GiB
Duration/String                  : 3h 48mn
OverallBitRate/String            : 14.1 Mbps
Encoded_Date                     : UTC 2011-06-03 06:29:47
Encoded_Application              : mkvmerge v3.2.0 ('Beginnings') 编译于 Feb 12 2010 16:46:17
Encoded_Library/String           : libebml v0.7.9 + libmatroska v0.8.1
ID/String                        : 1
Format_Profile                   : High@L4.1
Format_Settings_CABAC/String     : Yes
Format_Settings_RefFrames/String : 5 frames
CodecID                          : V_MPEG4/ISO/AVC
BitRate/String                   : 11.1 Mbps
Width/String                     : 1 920 pixels
Height/String                    : 800 pixels
DisplayAspectRatio/String        : 2.40:1
FrameRate/String                 : 23.976 fps
ColorSpace                       : YUV
ChromaSubsampling                : 4:2:0
BitDepth/String                  : 8 bits
ScanType/String                  : Progressive
Bits-(Pixel*Frame)               : 0.301
StreamSize/String                : 17.2 GiB (77%)
Title                            : TLOTR-I
Encoded_Library/String           : x264 core 114 r1924 08d04a4
Encoded_Library_Settings         : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=tesa / subme=10 / psy=1 / psy_rd=1.05:0.10 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=2 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=11090 / ratetol=1.0 / qcomp=0.70 / qpmin=1 / qpmax=63 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=40000 / nal_hrd=none / ip_ratio=1.40 / aq=2:0.90
Language/String                  : English
Audio #1
ID/String                        : 2
Format                           : DTS
Format/Info                      : Digital Theater Systems
Format_Profile                   : ES
CodecID                          : A_DTS
BitRate_Mode/String              : Constant
BitRate/String                   : 1 510 Kbps
Channel(s)/String                : 7 channels / 6 channels
ChannelPositions                 : Front: L C R, Side: L R, Back: C, LFE / Front: L C R, Side: L R, LFE
SamplingRate/String              : 48.0 KHz
BitDepth/String                  : 24 bits
Compression_Mode/String          : Lossy
StreamSize/String                : 2.41 GiB (11%)
Title                            : DTS-CORE ES6.1 1536K eng
Audio #2
ID/String                        : 3
Format                           : DTS
Format_Profile                   : ES
CodecID                          : A_DTS
Title                            : DTS-ES 6.1 1536K chinese
Language/String                  : Chinese
Any ideas?
Users browsing this forum: Baidu [Spider] and 10 guests
