Sony BDP 370 photo issue
maltmoose
Post Fri Jun 17, 2011 3:51 pm
When i view a group of pictures (holiday pictures taken from a sony dsc-tx5) it will show them and a thumbnail which is great, however sometimes it will just decide not to show the picture, just freeze and and look like its still loading. Sometimes hitting pause and play let me get to the next photo sometimes not, sometimes stopping and selecting another picture works. I've also notice that when i go back to view a picture i've already viewed in the same session it sometimes wont let me..
Any ideas?
maltmoose
Post Mon Jun 20, 2011 6:00 pm
Re: Sony BDP 370 photo issue
OK i have found exactly what type of photos are not loading but dont know why they dont load, hopefully someone will be able to help me figure out if its serviio or the BDP 370 etc
The photos that are not loading are all taken on my sony dsc-tx5 and are in portrait mode. You just get the loading symbol in the right hand corner of the TV. All photos taken in landscape mode work fine. I can see the thumbnail on the portrait picture just fine too.
Also all my other portrait pictures from other sources work ok, is anyone aware of any photo limitations for the bdp 370 or serviio?
Post Mon Jun 20, 2011 6:24 pm
You could only play with profile option, change values true/false (you have to restart serviio service after changes)
maltmoose
Post Mon Jun 20, 2011 7:11 pm
Thankyou Illico,
I changed <AutomaticImageRotation>true</AutomaticImageRotation> to FALSE and now it will show my portrait files and display my files in slideshow mode without freezing.
I think the default profile should be updated with this?
FWIW an example file that wont play when this is set to TRUE have the following EXIF
ImageDescription -
Make - SONY
Model - DSC-TX5
Orientation - Left bottom
XResolution - 72
YResolution - 72
ResolutionUnit - Inch
DateTime - 2011:06:07 09:48:10
YCbCrPositioning - Co-Sited
ExifOffset - 256
ExposureTime - 1/320 seconds
FNumber - 4.50
ExposureProgram - Normal program
ISOSpeedRatings - 125
ExifVersion - 0221
DateTimeOriginal - 2011:06:07 09:48:10
DateTimeDigitized - 2011:06:07 09:48:10
ComponentsConfiguration - YCbCr
CompressedBitsPerPixel - 4 (bits/pixel)
ExposureBiasValue - 0.00
MaxApertureValue - F 3.51
MeteringMode - Multi-segment
LightSource - Auto
Flash - Flash not fired, auto mode
FocalLength - 4.43 mm
FlashPixVersion - 0100
ColorSpace - sRGB
ExifImageWidth - 3648
ExifImageHeight - 2736
InteroperabilityOffset - 10702
FileSource - DSC - Digital still camera
SceneType - A directly photographed image
CustomRendered - Normal process
ExposureMode - Auto
White Balance - Auto
SceneCaptureType - Standard
Contrast - Normal
Saturation - Normal
Sharpness - Normal
Maker Note (Vendor): -
Thumbnail: -
Compression - 6 (JPG)
Make - SONY
Model - DSC-TX5
XResolution - 72
YResolution - 72
JpegIFOffset - 10908
JpegIFByteCount - 15312
woohoo slideshow still playing all photo whilst writing this, the girlfriend will be pleased :)
Post Mon Jun 20, 2011 7:19 pm
maltmoose wrote:...I think the default profile should be updated with this?
Good, but does Sony BDP still automatically rotate portrait and landscape pictures?
I confess to not having fully verify this before...
maltmoose
Post Mon Jun 20, 2011 7:39 pm
All 200+ photo's with a mix of portrait and landscape all displayed the correct way in slide show mode with setting set to flase, so i can only assume that the Sony BDP does rotate them correctly.
Post Mon Jun 20, 2011 8:02 pm
Zip, I think we could change Sony Bravia and Sony BDP profiles with following (or remove):
<AutomaticImageRotation>false</AutomaticImageRotation>
Post Tue Jun 21, 2011 4:12 pm
Ok.
