BD-D5700 stutters on mkv with 6 channel AC3 audio?
foobar
Post Tue Jun 21, 2011 8:33 pm
I have owned a BD-D5700 for a couple of weeks now, and just switched to Serviio from AllShare. I'm much happier that I was with AllShare. :) I'm not sure why but the player refuses to play Matroska video files that contain 6 channel AC3 audio. 2 channel files play well. Below are two examples, one file which plays (2 channel audio) and one that doesn't (6 channel audio). The 6 channel file stutters constantly. Has anyone else had this problem? Can I get Serviio to transcode the audio for me, or is there a better solution (or none)?
Thanks in advance...
[Example 1, no problem]
configuration: --enable-static --disable-shared --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --arch=x86 --enable-runtime-cpudetect --enable-w32threads --target-os=mingw32 --cross-prefix=i686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[matroska,webm @ 0175cb60] Estimating duration from bitrate, this may be inaccurate
Seems stream 1 codec frame rate differs from container frame rate: 47.95 (48000/1001) -> 23.98 (48000/2002)
Input #0, matroska,webm, from 'xyz3.mkv':
Duration: 00:58:42.24, start: 0.000000, bitrate: 384 kb/s
Stream #0.0: Audio: ac3, 48000 Hz, stereo, s16, 384 kb/s
Stream #0.1(eng): Video: h264, yuv420p, 1280x720, PAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
Unique ID : 0 (0x0)
Complete name : K:\Video\Television\xyz\xyz3.mkv
Format : Matroska
File size : 1.46 GiB
Duration : 58mn 42s
Overall bit rate : 3 555 Kbps
Encoded date : UTC 2010-02-22 21:41:29
Writing application : no_variable_data
Writing library : no_variable_data
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 58mn 42s
Bit rate : 3 162 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.143
Stream size : 1.27 GiB (87%)
Writing library : x264 core 85 r1442tw
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=30 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=6 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / wpredp=0 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3162 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 58mn 42s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 161 MiB (11%)
[Example 2, 'stuttering' playback]
[matroska,webm @ 0112cb60] Estimating duration from bitrate, this may be inaccurate
Input #0, matroska,webm, from 'xyz5.mkv':
Duration: 00:54:14.46, start: 0.000000, bitrate: 384 kb/s
Stream #0.0: Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
Unique ID : 0 (0x0)
Complete name : K:\Video\Television\xyz\xyz5.mkv
Format : Matroska
Duration : 54mn 14s
Overall bit rate : 3 847 Kbps
Format : AVC
Duration : 54mn 14s
Bit rate : 3 454 Kbps
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.156
Stream size : 1.28 GiB (88%)
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=30 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=6 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / wpredp=0 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3454 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Format : AC-3
Codec ID : A_AC3
Duration : 54mn 14s
Bit rate : 384 Kbps
Channel(s) : 6 channels
Bit depth : 16 bits
Stream size : 149 MiB (10%)
Post Wed Jun 22, 2011 7:58 am
Re: BD-D5700 stutters on mkv with 6 channel AC3 audio?
foobar wrote:... I'm not sure why but the player refuses to play Matroska video files that contain 6 channel AC3 audio. 2 channel files play well. Below are two examples, one file which plays (2 channel audio) and one that doesn't (6 channel audio).
You are right, seems the only difference were
foobar wrote: The 6 channel file stutters constantly. Has anyone else had this problem? Can I get Serviio to transcode the audio for me, or is there a better solution (or none)?
Could you confirm you sued "Samsung TV / player (C/D-series)" profile?
Could you check on Serviio Console if "Stereo" or "Keep Original" will be enabled on transcoding tab?
So this file must be delivered in native format, could you confirm by checking the serviio log file (before enable detailed logging, see my signature links)
Yes, Serviio could transcode audio, but that will be done for all your MKV/H264/AC3, not necessary.
foobar
Post Wed Jun 22, 2011 8:27 am
Thanks for responding!
I did use the "Samsung TV/player (C/D-series)" profile - although the status screen shows "unrecognized device" for the device name, but it works anyway.
"Downmix to stereo" is enabled.
I am not sure what to look for in the log file.
Post Wed Jun 22, 2011 9:00 am
foobar wrote:"Downmix to stereo" is enabled.
Could you try enable "Keep original", restart serviio service or reboot?
foobar wrote:I am not sure what to look for in the log file.
Just enable detailed logging (see signature) and post here the file.
Post Wed Jun 22, 2011 12:14 pm
The C/D profile transcodes hardly anything, so I doubt the Downmix to Stereo checkbox change will have any effect.
Post Wed Jun 22, 2011 1:30 pm
zip wrote:The C/D profile transcodes hardly anything, so I doubt the Downmix to Stereo checkbox change will have any effect.
Right, I had forgotten that this option is only used during transcoding. :roll:
