Samsung Series 6 LCD Profile Request
wookiebreath
Post Sun May 30, 2010 9:44 am
Hello I've got a Samsung Series 6 (C) LCD TV.
I've just got installed Serviio in preference to the Samsung PC Share software.
I'm just wondering if anyone out there has a working Transcoding profile that they would like to share.
Edit: I tried the Samsung Wiselink Pro profile, and the automatic profile, and some type of files work on one profile and not the other (and vice-versa). Also some files work via the Samsung software and not with the two serviio profiles I have tried (Specifically the AVI files produced with my canon camera - vlc shows video codec MJPG, Audio Codec: araw).
I'll continue to experiment, and will post my results here.
Post Sun May 30, 2010 10:04 am
Re: Samsung Series 6 LCD Profile Request
What 6 series it is exactly? If you select Samsung WiselinkPro profile you should be ok.
wookiebreath
Post Sun May 30, 2010 11:16 am
The model number is: LA40C650 - The user manual for this model is:
http://downloadcenter.samsung.com/content/UM/201003/20100315155442031/BN68-02730A-00Eng_0224.pdf
I'll try the WiseLink pro now, and report back. Great software, and awesome support!
wookiebreath
Post Sun May 30, 2010 11:28 am
Using the Samsung Wiselink Pro - I'm getting some 'codec' not support messages for files that play under the generic profile.
wmv files with
* Video Codec WMV3 - audio WMAP
* Video Codec WMV3 - audio WMA2
These two files just happen to be some old home videos that were the first two files that I tried with the new profile.
It seems like the other file types I have all play fine.
So my next question is:
Should I just re-encode these two old videos to a more recent format, or is there an easy tweak I can make to the Samsung Wiselink Pro config, to let it play the file like the generic profile does?
Post Sun May 30, 2010 12:16 pm
Can you provide ffmpeg -i <yourfile> output for those files?
wookiebreath
Post Sun May 30, 2010 1:02 pm
File 1:
"C:\Program Files\Serviio\lib\ffmpeg.exe" -i thredboPAL-2.wmv
FFmpeg version SVN-r23012, Copyright (c) 2000-2010 the FFmpeg developers
  built on May  3 2010 19:05:24 with gcc 3.4.5 (mingw-vista special r3)
erver --enable-memalign-hack --enable-libmp3lame --enable-w32threads --extra-ldf
lags=-L/static/lib --extra-cflags=-I/static/include
  libavutil     50.15. 0 / 50.15. 0
  libavcodec    52.66. 0 / 52.66. 0
  libavformat   52.62. 0 / 52.62. 0
  libavdevice   52. 2. 0 / 52. 2. 0
  libswscale     0.10. 0 /  0.10. 0
Seems stream 1 codec frame rate differs from container frame rate: 1000.00 (1000
/1) -> 25.00 (25/1)
Input #0, asf, from 'thredboPAL-2.wmv':
    title           :
    author          :
    copyright       :
    comment         :
    WMFSDKVersion   : 9.00.00.2980
    WMFSDKNeeded    : 0.0.0.0000
    VBR Peak        : 100
    IsVBR           : 1
    Buffer Average  : 168
  Duration: 00:03:24.04, start: 3.000000, bitrate: 5329 kb/s
    Stream #0.0(eng): Audio: wmapro, 44100 Hz, stereo, flt, 191 kb/s
    Stream #0.1(eng): Video: wmv3, yuv420p, 720x576, 5000 kb/s, PAR 16:15 DAR 4:
3, 25 tbr, 1k tbn, 1k tbc
File 2:
"C:\Program Files\Serviio\lib\ffmpeg.exe" -i IsaacOnTheMove.wmv
[wmv3 @ 013feaf0]Extra data: 8 bits left, value: 0
/1) -> 25.00 (25/1)
Input #0, asf, from 'IsaacOnTheMove.wmv':
    Application     : Windows Movie Maker 2.1.4026.0
    WM/ParentalRating:
    WMFSDKVersion   : 11.0.5721.5251
    IsVBR           : 0
    title           :
    author          :
    copyright       :
    comment         :
  Duration: 00:00:32.04, start: 2.000000, bitrate: 798 kb/s
    Stream #0.0(eng): Audio: wmav2, 44100 Hz, 2 channels, s16, 96 kb/s
    Stream #0.1(eng): Video: wmv3, yuv420p, 640x480, 768 kb/s, 25 tbr, 1k tbn, 1
k tbc
wookiebreath
Post Thu Sep 02, 2010 9:23 am
Thanks again!
Both these file types work with the latest release.
