Make the folder path editable
dq2112
Post Mon May 31, 2010 5:41 pm
This should be a simple fix. The library folder path needs to be editable. I have tried double clicking on it and nothing happens and I do not see a menu option for editing the path.
Why make it editable?
If a user enters the wrong path and wants to change it.
If you move your library how do you change the path?
Post Mon May 31, 2010 6:44 pm
Re: Make the folder path editable
Do you mean the shared folders? You can remove them.
dq2112
Post Tue Jun 01, 2010 12:35 am
yes you can remove them but part of the problem is you can't see the entire path to the folders in the Serviio console window. So let's say you have more than one path to different locations of libraries ( downloaded movies, home movies, DVDs,...). Now you move one of the folders on your computer and you want to make the change in Serviio to point to the new folder location. You have to remove all 3 paths because you can't tell which path is the one that needs to be changed. We need a way to see the entire path so the right path can be removed. Or a way to edit the paths.
By the way.... your software is awesome. I wish Samsung was smart enough to create something like this.
Post Tue Jun 01, 2010 8:20 am
OK, so a tooltip showing the entire path on mouse-over should do?
dq2112
Post Wed Jun 02, 2010 3:44 am
Yes, that would work.
Then we would know what each path is set to and know which one to remove.
Return to Feature requests
Users browsing this forum: No registered users and 61 guests
