Stuttering audio when streaming to 40EX503U
agaskell
Post Wed Jun 29, 2011 7:51 pm
Hi
I am streaming from serviio on Linux to Sony 40EX503U. The dialog is obviously out of sync with the video and there is stuttering. This is with my avi files shot on a digicam and also an mpeg4 file ripped from DVD using handbrake. I downloaded a test mpeg4 trailer and it streams OK. Both the avi and the ripped mpeg4 play perfectly on the laptop itself.
Any help with this appreciated.
For the mpeg4 file:
ffmpeg -i Panda.m4v
FFmpeg version 0.6.2-4:0.6.2-1ubuntu1, Copyright (c) 2000-2010 the Libav developers
built on Mar 22 2011 15:35:22 with gcc 4.5.2
configuration: --extra-version=4:0.6.2-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
WARNING: library configuration mismatch
libavutil configuration: --extra-version=4:0.6.2-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
libavcodec configuration: --extra-version=4:0.6.2-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
libavformat configuration: --extra-version=4:0.6.2-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
libavdevice configuration: --extra-version=4:0.6.2-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
libavfilter configuration: --extra-version=4:0.6.2-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
libswscale configuration: --extra-version=4:0.6.2-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
libpostproc configuration: --extra-version=4:0.6.2-1ubuntu1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
libavutil 50.15. 1 / 50.15. 1
libavcodec 52.72. 2 / 52.72. 2
libavformat 52.64. 2 / 52.64. 2
libavdevice 52. 2. 0 / 52. 2. 0
libavfilter 1.19. 0 / 1.19. 0
libswscale 0.11. 0 / 0.11. 0
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x9f7b420]max_analyze_duration reached
Seems stream 0 codec frame rate differs from container frame rate: 180000.00 (180000/1) -> 25.00 (25/1)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Panda.m4v':
major_brand : mp42
minor_version : 0
encoder : HandBrake 0.9.5 2011043000
Duration: 01:28:12.60, start: 0.000000, bitrate: 1221 kb/s
Chapter #0.0: start -0.080000, end 143.040000
title : Chapter 1
Chapter #0.1: start 143.040000, end 302.120000
title : Chapter 2
Chapter #0.2: start 302.120000, end 457.320000
title : Chapter 3
Chapter #0.3: start 457.320000, end 613.680000
title : Chapter 4
Chapter #0.4: start 613.680000, end 956.320000
title : Chapter 5
Chapter #0.5: start 956.320000, end 1118.720000
title : Chapter 6
Chapter #0.6: start 1118.720000, end 1303.920000
title : Chapter 7
Chapter #0.7: start 1303.920000, end 1513.200000
title : Chapter 8
Chapter #0.8: start 1513.200000, end 1795.160000
title : Chapter 9
Chapter #0.9: start 1795.160000, end 2037.000000
title : Chapter 10
Chapter #0.10: start 2037.000000, end 2218.880000
title : Chapter 11
Chapter #0.11: start 2218.880000, end 2448.160000
title : Chapter 12
Chapter #0.12: start 2448.160000, end 2631.360000
title : Chapter 13
Chapter #0.13: start 2631.360000, end 2961.120000
title : Chapter 14
Chapter #0.14: start 2961.120000, end 3248.320000
title : Chapter 15
Chapter #0.15: start 3248.320000, end 3381.920000
title : Chapter 16
Chapter #0.16: start 3381.920000, end 3571.680000
title : Chapter 17
Chapter #0.17: start 3571.680000, end 3846.560000
title : Chapter 18
Chapter #0.18: start 3846.560000, end 4019.240000
title : Chapter 19
Chapter #0.19: start 4019.240000, end 4261.440000
title : Chapter 20
Chapter #0.20: start 4261.440000, end 4605.560000
title : Chapter 21
Chapter #0.21: start 4605.560000, end 4785.600000
title : Chapter 22
Chapter #0.22: start 4785.600000, end 5292.600000
title : Chapter 23
Stream #0.0(und): Video: h264, yuv420p, 716x434 [PAR 64:45 DAR 22912:9765], 1057 kb/s, PAR 16288:8055 DAR 32576:9765, 25 fps, 25 tbr, 90k tbn, 180k tbc
Stream #0.1(eng): Audio: aac, 48000 Hz, stereo, s16, 159 kb/s
Stream #0.2(und): Subtitle: text / 0x74786574
Post Thu Jun 30, 2011 7:01 am
Re: Stuttering audio when streaming to 40EX503U
Try with changing the aBitrate option (from 384 to 192) on the Sony Bravia profile.
<Video targetContainer="mpegts" targetACodec="ac3" aBitrate="192">
Restart serviio service after modification on profile
Could you post ffmpeg -i result of your digicam avi file?
agaskell
Post Thu Jun 30, 2011 11:37 am
Changing the bitrate solved the problem with the avi files. However the problem persists with the mpeg4 file and has made no difference.
Here is the ffmpeg output for an avi file in case you still need it.
ffmpeg -i DSCF0002.AVI
Input #0, avi, from 'DSCF0002.AVI':
Duration: 00:00:37.99, start: 0.000000, bitrate: 9288 kb/s
Stream #0.0: Video: mjpeg, yuvj422p, 640x480, 30 tbr, 30 tbn, 30 tbc
strn : FUJIFILM AVI STREAM 0100
Stream #0.1: Audio: pcm_u8, 8000 Hz, 1 channels, u8, 64 kb/s
Post Thu Jun 30, 2011 11:48 am
Try by changing all others aBitrate option on Sony Bravia profile with : aBitrate="192"
agaskell
Post Thu Jun 30, 2011 1:25 pm
Unfortunately I already did that. I did a global search and replace in the profiles.xml file for 384 and I replaced it with 192. Anything else I can try?
Post Thu Jun 30, 2011 4:10 pm
agaskell wrote:Unfortunately I already did that. I did a global search and replace in the profiles.xml file for 384 and I replaced it with 192. Anything else I can try?
This is probably due to HandBrake 0.9.5 encoding settings. There were some similar problem with Handbrake:
viewtopic.php?f=11&t=2411&p=15809&hilit=HandBrake+0.9.5#p15809
viewtopic.php?f=10&t=2676&p=16417&hilit=HandBrake+0.9.5#p16417
viewtopic.php?f=10&t=2641&p=16211&hilit=HandBrake+0.9.5#p16211
agaskell
Post Fri Jul 01, 2011 10:38 pm
I ripped another disc. Same result under serviio. I then tried changing some settings in handbrake - no difference. I then copied all the rips to another machine running windows media player and all the videos stream flawlessly. No audio sync issues. It seems like handbrake is not to blame. I don't want to give up just yet, especially as I am running Ubuntu- do you have any more suggestions?
Thanks again!
Andrew.
Post Mon Jul 04, 2011 11:51 am
try removing aBitrate altogether
agaskell
Post Tue Jul 05, 2011 8:53 am
Didn't work. Thanks for trying. fyi PS3 media server on the same machine works OK. Not sure what the problem is.
Users browsing this forum: No registered users and 53 guests
