Problems playing 3D MKV on PN50C8000 TV and C5900 Bluray
Dandarebr
Post Mon Jun 27, 2011 10:53 am
I'm having problems playing some files on my Samsung TV and Bluray player and I need some help.
I have two different 3d mkv files. They are SBS files, so I can open them in normal players on my computer. When streaming it to the TV I just have to choose "side by Side" on 3D menu and bingo: 3D Video :D
Ok, here is the thing: One file I can play on both my Bluray Player and on my TV. The second file I can play only on my Bluray.
The deal is that I must play these videos from my TV because only the TV can correctly insert the .srt subtitles while playing 3D movies. The TV understands that it's a 3D video but with a “2D” subtitles, so when I turn the “Side by Side” 3D mode it changes the video image to 3D and but let the subtitles correctly centered.
If I play this same movie from my Bluray player, the TV receives the image with included subtitles and can't differentiate the movie from the inserted subtitles. When I turn the 3D mode on, the TV scrambles the subtitles.
So in order to get .srt subtitles showing correctly, I must play the 3D movie from the TV.
I already got the information about both videos. They are pretty much the same. Same codec, same library. The only differences (except from movie size) are these:
Video 1 - Runs on Bluplayer (BD-C5900) and Runs on TV (PN50C8000)
Overall bit rate : 6 022 Kbps
Bit rate : 5 838 Kbps
Frame rate : 23.976 fps
Bits/(Pixel*Frame) : 0.117
Video Stream size : 1.73 GiB (97%)
Audio Stream size : 19.4 MiB (1%)
Video 2 - Runs on Bluplayer (BD-C5900) - Doesn't run on TV (PN50C8000)
Overall bit rate : 6 819 Kbps
Bit rate : 6 619 Kbps
Frame rate : 47.952 fps
Bits/(Pixel*Frame) : 0.067
Video Stream size : 1.89 GiB (97%)
Audio Stream size : 18.7 MiB (1%)
I *think* that the problem may be the frame rate. The second movie has a 47.952 fps. I believe this is related to 3D, since 47.952 = 2x 23.976, so each eye would have 23.976 fps.
Note that the first video is also 3D but have a framerate of 23.976
Like I wrote, I need to play this file from the TV or else I won't have working subtitles. What can I do?
Some questions:
1) PN50C8000 TV and BP-C5900 both uses the "Samsung TV / Player (C/D-Series)" profile but, as shown above, they can play different videos files. Shouldn't they have different profiles to reflect that?
2) Is there a way to edit the TV Profile in order to transcode files with a framerate bigger than 29 fps (Like I said, I'm guessing this is the issue here)? Is it possible to serviio transcode and change the framerate on the fly?
3) How does Serviio deals with subtitle when transcoding? It keeps the subtitle and video information separated or it includes the .srt subtitle in the video like a "hard subtitle"? If it includes the subtitle image on the video (like a hardsub) I’ll have the same problem that I have when playing the video from my Bluray Player.
(Sorry about the poor english)
Jose Morais
Dandarebr
Post Mon Jun 27, 2011 11:07 am
Re: Problems playing 3D MKV on PN50C8000 TV and C5900 Bluray
Here is the FFmpeg info:
VIDEO 1 (The one that Runs on both TV and Bluray player)
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[matroska,webm @ 0156cd40] Invalid timestamps stream=1, pts=104, dts=61489146912
36517218, size=278
[matroska,webm @ 0156cd40] Invalid timestamps stream=0, pts=125, dts=30744573456
18258631, size=13
[matroska,webm @ 0156cd40] Invalid timestamps stream=0, pts=167, dts=30744573456
18258632, size=13
[matroska,webm @ 0156cd40] Invalid timestamps stream=0, pts=209, dts=30744573456
18258633, size=13
[matroska,webm @ 0156cd40] Invalid timestamps stream=0, pts=250, dts=30744573456
18258634, size=13
[matroska,webm @ 0156cd40] Invalid timestamps stream=0, pts=292, dts=30744573456
18258635, size=13
[matroska,webm @ 0156cd40] Invalid timestamps stream=0, pts=334, dts=30744573456
18258636, size=13
[matroska,webm @ 0156cd40] Invalid timestamps stream=0, pts=375, dts=30744573456
18258637, size=13
[matroska,webm @ 0156cd40] Invalid timestamps stream=0, pts=417, dts=30744573456
18258638, size=13
[matroska,webm @ 0156cd40] Invalid timestamps stream=0, pts=459, dts=30744573456
18258639, size=13
[matroska,webm @ 0156cd40] Invalid timestamps stream=0, pts=500, dts=30744573456
18258640, size=6168
[matroska,webm @ 0156cd40] Invalid timestamps stream=0, pts=542, dts=30744573456
18258641, size=13
[matroska,webm @ 0156cd40] Invalid timestamps stream=0, pts=584, dts=30744573456
18258642, size=13
[matroska,webm @ 0156cd40] Invalid timestamps stream=0, pts=626, dts=30744573456
18258643, size=13
[matroska,webm @ 0156cd40] Invalid timestamps stream=0, pts=667, dts=30744573456
18258644, size=13
[matroska,webm @ 0156cd40] Invalid timestamps stream=0, pts=709, dts=30744573456
18258645, size=13
[matroska,webm @ 0156cd40] Invalid timestamps stream=0, pts=751, dts=30744573456
18258646, size=13
[matroska,webm @ 0156cd40] Invalid timestamps stream=0, pts=792, dts=30744573456
18258647, size=13
[matroska,webm @ 0156cd40] Invalid timestamps stream=0, pts=834, dts=30744573456
18258648, size=13
[matroska,webm @ 0156cd40] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (7001/1
46) -> 23.98 (7001/292)
Input #0, matroska,webm, from 'video1.mkv':
Duration: 00:42:26.13, start: 0.000000, bitrate: 64 kb/s
Stream #0.0: Video: h264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 23.98 fps,
23.98 tbr, 1k tbn, 47.95 tbc
Stream #0.1(eng): Audio: ac3, 44100 Hz, stereo, s16, 64 kb/s
Video 2 (Runs only on Bluray)
686-mingw32-
[matroska,webm @ 0156cd50] Invalid timestamps stream=0, pts=63, dts=307445734561
8258617, size=77
[matroska,webm @ 0156cd50] Invalid timestamps stream=0, pts=83, dts=307445734561
8258618, size=545
[matroska,webm @ 0156cd50] Invalid timestamps stream=0, pts=104, dts=30744573456
18258619, size=67
[matroska,webm @ 0156cd50] Invalid timestamps stream=0, pts=125, dts=30744573456
18258620, size=1008
[matroska,webm @ 0156cd50] Invalid timestamps stream=0, pts=146, dts=30744573456
18258621, size=73
[matroska,webm @ 0156cd50] Invalid timestamps stream=0, pts=167, dts=30744573456
18258622, size=2029
[matroska,webm @ 0156cd50] Invalid timestamps stream=0, pts=188, dts=30744573456
18258623, size=48
[matroska,webm @ 0156cd50] Invalid timestamps stream=0, pts=209, dts=30744573456
18258624, size=4694
[matroska,webm @ 0156cd50] Invalid timestamps stream=0, pts=229, dts=30744573456
18258625, size=66
[matroska,webm @ 0156cd50] Invalid timestamps stream=0, pts=250, dts=30744573456
18258626, size=7509
[matroska,webm @ 0156cd50] Invalid timestamps stream=0, pts=271, dts=30744573456
18258627, size=883
[matroska,webm @ 0156cd50] Invalid timestamps stream=0, pts=292, dts=30744573456
18258628, size=3081
[matroska,webm @ 0156cd50] Invalid timestamps stream=0, pts=313, dts=30744573456
18258629, size=111
[matroska,webm @ 0156cd50] Invalid timestamps stream=0, pts=334, dts=30744573456
18258630, size=3390
[matroska,webm @ 0156cd50] Invalid timestamps stream=0, pts=355, dts=30744573456
18258631, size=124
[matroska,webm @ 0156cd50] Invalid timestamps stream=0, pts=375, dts=30744573456
18258632, size=6079
[matroska,webm @ 0156cd50] Invalid timestamps stream=0, pts=396, dts=30744573456
18258633, size=136
[matroska,webm @ 0156cd50] Invalid timestamps stream=0, pts=417, dts=30744573456
18258634, size=4097
[matroska,webm @ 0156cd50] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 95.90 (400000
00/417083) -> 47.95 (40000000/834166)
Input #0, matroska,webm, from 'video2.mkv':
Duration: 00:40:49.76, start: 0.000000, bitrate: 64 kb/s
Stream #0.0: Video: h264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 47.95 fps,
47.95 tbr, 1k tbn, 95.90 tbc
Stream #0.1: Audio: ac3, 44100 Hz, stereo, s16, 64 kb/s
Post Mon Jun 27, 2011 12:14 pm
can you post MediaInfo result for the files?
Dandarebr
Post Mon Jun 27, 2011 3:49 pm
No problem but I`ll only be able to post it when I get home (at work now). But the only differences between the two files (according to Mediainfo) are the ones that I posted in the first post. All other info (from Mediainfo) is exactly the same for the two files.
Dandarebr
Post Mon Jun 27, 2011 11:08 pm
VIDEO 1 (Run on both)
Format : Matroska
File size : 1.78 GiB
Duration : 42mn 26s
Writing application : Lavf51.12.1
Writing library : Lavf51.12.1
Format : AVC
Format profile : Baseline@L1.3
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=12
Codec ID : V_MPEG4/ISO/AVC
Duration : 42mn 26s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Language : English
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 42mn 26s
Bit rate mode : Constant
Bit rate : 64.0 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Bit depth : 16 bits
Compression mode : Lossy
Language : English / English
VIDEO 2 (RUNS ONLY ON THE BD-C5900)
Format : Matroska
File size : 1.94 GiB
Duration : 40mn 49s
Format : AVC
Duration : 40mn 49s
Color space : YUV
Bit depth : 8 bits
Language : English
Format : AC-3
Codec ID : A_AC3
Duration : 40mn 49s
Bit depth : 16 bits
Language : English
Post Tue Jun 28, 2011 7:26 am
Strange, files seems to be similar, same codec livrary, same settings...
Format profile is very low for an HD video: Baseline@L1.3
Usually, we found Main@4.0 for HD video with maximum 4 stored frames
Dandarebr
Post Tue Jun 28, 2011 7:47 pm
The only diference that I can think about it is the framerate, but I don't know if that would prevent the file from been played on the TV. Like I said the Bluray player plays the files with no problem and I think that the "c" series TV and "C" series bluray should play the same files.
Is there a way to serviio to change the framerate while transcoding? Is that even possible? Also, how subtitle works while serviio is transcoding a file?
Dandarebr
Post Fri Jul 01, 2011 1:24 am
Any ideas?
Users browsing this forum: Baidu [Spider] and 17 guests
