Playing MKV on Samsung C
swust
Post Sun Jun 26, 2011 5:48 am
I have been using serviio for a while and it used to play mkv without problem. I can still play some of the mkv in smaller size, but for some reason, I can't no longer play the large size mkv (4GB above). Whenever I tried to play it, it will say that file format is not supported and immediately, the serviio server will be disconnected from my tv. it will take a while before it connects again, which is strange.
anyone has experienced the same problem before?
thanks.
Post Mon Jun 27, 2011 8:51 am
Re: Playing MKV on Samsung C
Post Mon Jun 27, 2011 12:09 pm
If they are transcoded, make sure you have enough space in the transcoding temp folder
swust
Post Mon Jun 27, 2011 4:22 pm
I am using Windows 7 64-bit, here are the info
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
Post Mon Jun 27, 2011 6:08 pm
Something is missing.
ffmpeg -i "filepath"
swust
Post Tue Jun 28, 2011 1:17 pm
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Doelski>cd "\Program Files (x86)\Serviio\Lib
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "E:\New\What Just Happened - 10
80p.mkv
686-mingw32-
[matroska,webm @ 012ebcc0] max_analyze_duration reached
[matroska,webm @ 012ebcc0] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (500000
0/104271) -> 23.98 (5000000/208542)
Input #0, matroska,webm, from 'E:\New\What Just Happened - 1080p.mkv':
Duration: 01:43:59.27, start: 0.000000, bitrate: 1536 kb/s
Stream #0.0(eng): Video: h264, yuv420p, 1920x800, PAR 1:1 DAR 12:5, 23.98 fp
s, 23.98 tbr, 1k tbn, 47.95 tbc
Stream #0.1(eng): Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s
Stream #0.2(eng): Subtitle: [0][0][0][0] / 0x0000
Stream #0.3(bul): Subtitle: [0][0][0][0] / 0x0000
Stream #0.4(hrv): Subtitle: [0][0][0][0] / 0x0000
Stream #0.5(dut): Subtitle: [0][0][0][0] / 0x0000
Stream #0.6(por): Subtitle: [0][0][0][0] / 0x0000
Stream #0.7(rum): Subtitle: [0][0][0][0] / 0x0000
Stream #0.8(spa): Subtitle: [0][0][0][0] / 0x0000
Stream #0.9(tur): Subtitle: [0][0][0][0] / 0x0000
Post Tue Jun 28, 2011 4:21 pm
This file should play natively with the C profile, so no transcoding is going on. Not sure why it's not working - did this file play before?
swust
Post Wed Jun 29, 2011 2:10 pm
yes it played before... the weird thing is after it fails to play, the serviio server will be disconnected from my TV
Post Wed Jun 29, 2011 2:34 pm
Have you changed anything else on the computer? Did you change the location of serviio? What are the file systems on the drives involved.
Fat32 max file size 4 GB
NTFS up to 16 Exabyte which is 1 million terabytes
If you are using Fat32 maybe something is increasing the file size enough to hit the 4GB limit?
swust
Post Fri Jul 01, 2011 3:38 am
no didn't change anything... trying to copy to other drive and see if it works
TheNemic
Post Sun Jul 03, 2011 8:55 pm
I have the same problem with playing mkv files now, before i could play all mkv files, but now it not working anymore :/ and its the same files I have played before without Any problems, and i didnt change anything on the server at all
| Samsung UE40D5005 LED | DreamBox 800HD se | Windows 7 | Synology DS1515+ NAS |
YTMY
Post Wed Jul 13, 2011 4:13 pm
Hi, sometimes (for me) such things occur because of the router. I would try restarting the router. Also if Your TV is connected to the router wirelessly the signal may be too weak.
From my experience DLNA is very sensitive to the quality of the signal (and the router).
Good luck.
| Samsung UE32C6500 LED | Windows 7 x64 | 5Ghz wi-fi N 300Mbps setup |
Post Wed Jul 13, 2011 9:24 pm
YTMY wrote:Hi, sometimes (for me) such things occur because of the router. I would try restarting the router. Also if Your TV is connected to the router wirelessly the signal may be too weak.
Good luck.
that is so true.. you get what u pay for with routers :)
thingy
Post Sun Jul 24, 2011 9:36 am
I noticed that my Samsung C-series c5900 BD player will not play any mkv with chapter information.
Try to remove those, ie extract the video and audio tracks and remerge those in a new mkv file.
powerfuljackson
Post Mon Aug 15, 2011 5:21 am
i know a step by step guide on how to play any video format including AVI, MKV, WMV, RM, FLV, MOV, Xvid, DivX, 3GP, WebM, VP8 and more on Samsung at http://www.bigasoft.com/articles/how-to-convert-video-to-samsung-galaxy.html
Users browsing this forum: Baidu [Spider] and 32 guests
