DVD Videos don't take up the entire tv screen
dq2112
Post Wed Jun 02, 2010 3:50 am
Has anyone had a problem getting you DVD videos to use the entire TV screen when streamed with serviio? I have a 52 inch Samsung and it had two options when I stream these videos. "Original size" (which is too small) and "Fit" (it's bigger but still does not take up the entire screen.
I use DVDFab 7 to rip the DVD files and Shrink DVD to create one vob file. I have a Samsung LN52B750.
Gemdarwen
Post Wed Oct 27, 2010 10:58 am
Re: DVD Videos don't take up the entire tv screen
Yes, I have this same problem. I have a 46" Series B 7100 (UA46B7100) and have the profile set to "Samsung Series B". I really don't understand the technical terms here, but serviio has been working great for me - except that the entire screen is not being used.
Would welcome any help :-)
hennys
Post Wed Oct 27, 2010 11:15 am
I have a samsung LE40C650.
I can choose between Original, mode 1 and mode 2. for widescreen DVD's (vob files) I have too choose Mode 2. This works fine for widescreen dvd's (16:9) but still leaves a black bar for the Cinemascope Films (2.21:1).This is fine for me (if I want this filling the screen the tv would have to cut off the edges, which is something I wouldn't want.
Regards,
Hen
Return to User experiences
