Change priority of metadata extraction
bobbygee
Post Mon Jul 04, 2011 7:45 pm
If Local Poster had highest priority in the metadata extraction tree, it would be very easy to fix the issue of incorrect thumbnails for videos by simply adding a local thumbnail.
Post Mon Jul 04, 2011 11:23 pm
Re: Change priority of metadata extraction
that's the case and should work
bobbygee
Post Tue Jul 05, 2011 3:05 pm
Are you saying that I can already change the priority order? If so, how.
Post Tue Jul 05, 2011 4:45 pm
you can't change it, it's defined. embedded metadata < online metadata < local cover art
Return to Feature requests
Users browsing this forum: Baidu [Spider] and 21 guests
