mp4 wont play properly on sony bdp s370
maltmoose
Post Tue Jul 05, 2011 7:18 pm
All mp4 video file thats created by my sony camera dont play properly. Essential the mp4 starts to play and then freezes then trys to play some sound and then some video but cant seem to do it all at the same time in a stuttering fashion.
Heres the output of the file, any ideas?
C:\Program Files\Serviio\lib>ffmpeg.exe -i "G:\Video\Sony DSC-TX5\M4H00118.MP4"
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
Seems stream 0 codec frame rate differs from container frame rate: 30000.00 (300
00/1) -> 29.97 (30000/1001)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'G:\Video\Sony DSC-TX5\M4H00118.MP4':
major_brand : MSNV
minor_version : 19595353
compatible_brands: MSNVmp42isom
creation_time : 2011-06-07 12:49:21
Duration: 00:00:05.50, start: 0.000000, bitrate: 9307 kb/s
Stream #0.0(und): Video: mpeg4, yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 9238 k
b/s, 29.97 fps, 29.97 tbr, 30k tbn, 30k tbc
Stream #0.1(und): Audio: aac, 24000 Hz, mono, s16, 64 kb/s
Need any more info let me know, thanks mm
Post Wed Jul 06, 2011 1:09 pm
Re: mp4 wont play properly on sony bdp s370
check detailed log of when you play the file. If it's transcoded, try to run the ffmpeg command manually and play the resulting file (either in vlc or rename to .mpg and add to Serviio's library) to see if it's got the same problems.
maltmoose
Post Wed Jul 06, 2011 10:20 pm
Renamed the file to end in .mpg and it has the same problem.
dont think .mp4 or .mpg is being transcoded as the log says delivered in native format.
I think it might be to do with the average bit rate of the file, according to the bit rate viewer its average rate is higher than any other movie i have (average 9328kbps)
anyway to get serviio to reduce this or any way to confirm this theory?
Post Wed Jul 06, 2011 10:33 pm
you'd have to set up transcoding for mp4 and set maxVBitrate... but 900kb is not too high, it should go up to 20mbit (at least at peaks)
maltmoose
Post Fri Jul 08, 2011 5:24 pm
you might be right zip, i could be something else funny about the mp4, but i'd like to eliminate the rate for sure but i'm having a little trouble setting up a transcoding profile for mp4, not sure what target container and targetvcodec i should be using
maltmoose
Post Fri Jul 08, 2011 11:58 pm
OK did a bit more testing and have discovered that if i play the sony cameras mpeg4 files directly from a usb device pluged into the sony bdps370 the video plays fine.
I'm not sure what this means exactly, but maybe the s370 isnt powerful enough to both play and stream certain files via dlna at the same time? or maybe there are known limits of this technology.
Post Sat Jul 09, 2011 12:34 am
maltmoose wrote:OK did a bit more testing and have discovered that if i play the sony cameras mpeg4 files directly from a usb device pluged into the sony bdps370 the video plays fine.
USB and DLNA are two completely different systems and can not be compared..
