Installation Problems with D6500
Joerg2003
Post Tue Jul 05, 2011 6:51 pm
First I like to say, that I am new in this forum and I do hope you could help with my installation of Serviio. I was already reading a lot of postings, but they couldn't help me.
In the beginning I installed Allshare on my computer and it worked together with my new TC set, except that it took about 8 hrs to initialize the library (fairly acceptable),
but it also took about 2 hrs to modify the library, when I only added or modified a few pictures (NOT acceptable).
That is why I like to change to Serviio, but here I have problems with the installation:
I installed Servio Version 0.5.2 on my computer, running Windows XP. I also have a new Samsung UE55D6500. I am using a fixed IP address for the TV and for the computer.
The profile setting within Serviio is "Samsung TV (C/D series)".
My problem now is: On the TV I am getting the message "No device available".
Could somebody help me??? :cry: :cry:
Joerg
Post Wed Jul 06, 2011 11:28 am
Re: Installation Problems with D6500
Did you open the ports in your firewall for serviio? See the FAQ in the following link.
http://www.serviio.org/component/content/article/21#q1
Joerg2003
Post Wed Jul 06, 2011 4:01 pm
Sorry, but it didn't help: I opened the TCP port 8895, the UDP port 1900 was already opened by another program.
I also activated my AntiVir Guard.
Still get the TV message "No device available".
What else am I doing wrong???
Joerg
Post Wed Jul 06, 2011 4:07 pm
can you post the log? make sure the anivirus is deactivated
Joerg2003
Post Thu Jul 07, 2011 4:13 pm
Thank you for your response! Attached you find the pfirewall.log:
#Version: 1.5
#Software: Microsoft Windows Firewall
#Time Format: Local
#Fields: date time action protocol src-ip dst-ip src-port dst-port size tcpflags tcpsyn tcpack tcpwin icmptype icmpcode info path
2011-07-07 17:59:19 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 17:59:24 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 17:59:26 CLOSE TCP 192.168.1.11 192.168.1.6 1177 52235 - - - - - - - - -
2011-07-07 17:59:26 CLOSE TCP 192.168.1.11 192.168.1.6 1176 52235 - - - - - - - - -
2011-07-07 17:59:27 CLOSE TCP 192.168.1.11 192.168.1.29 2095 2066 - - - - - - - - -
2011-07-07 17:59:34 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 17:59:29 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 17:59:32 OPEN TCP 192.168.1.11 192.168.1.29 2096 2066 - - - - - - - - -
2011-07-07 17:59:39 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 17:59:44 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 17:59:47 CLOSE TCP 192.168.1.11 192.168.1.29 2096 2066 - - - - - - - - -
2011-07-07 17:59:49 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 17:59:54 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 17:59:56 OPEN TCP 192.168.1.11 192.168.1.1 1185 49000 - - - - - - - - -
2011-07-07 17:59:56 CLOSE TCP 192.168.1.11 192.168.1.1 1185 49000 - - - - - - - - -
2011-07-07 17:59:56 CLOSE TCP 192.168.1.11 192.168.1.1 1186 49000 - - - - - - - - -
2011-07-07 17:59:56 DROP UDP 192.168.1.11 239.255.255.250 1184 1900 181 - - - - - - - RECEIVE
2011-07-07 17:59:56 OPEN TCP 192.168.1.11 192.168.1.1 1186 49000 - - - - - - - - -
2011-07-07 18:00:07 CLOSE TCP 192.168.1.11 192.168.1.29 2097 2066 - - - - - - - - -
2011-07-07 18:00:12 OPEN TCP 192.168.1.11 192.168.1.29 2098 2066 - - - - - - - - -
2011-07-07 18:01:55 DROP ICMP 192.168.1.11 192.168.1.1 - - 153 - - - - 3 3 - SEND
2011-07-07 18:01:58 DROP UDP 192.168.1.11 255.255.255.255 1029 1947 68 - - - - - - - RECEIVE
2011-07-07 18:02:07 OPEN-INBOUND TCP 192.168.1.1 192.168.1.11 3040 2869 - - - - - - - - -
2011-07-07 18:02:07 OPEN-INBOUND TCP 192.168.1.1 192.168.1.11 3041 2869 - - - - - - - - -
2011-07-07 18:01:58 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:02:02 DROP UDP 192.168.1.11 239.255.255.250 1054 1900 161 - - - - - - - RECEIVE
2011-07-07 18:02:03 OPEN TCP 192.168.1.11 192.168.1.6 1065 52235 - - - - - - - - -
2011-07-07 18:02:05 DROP UDP 192.168.1.11 239.255.255.250 1057 1900 153 - - - - - - - RECEIVE
2011-07-07 18:02:06 OPEN TCP 192.168.1.11 192.168.1.29 2069 2066 - - - - - - - - -
2011-07-07 18:02:06 OPEN TCP 192.168.1.11 192.168.1.1 1068 49000 - - - - - - - - -
2011-07-07 18:02:06 CLOSE TCP 192.168.1.11 192.168.1.1 1068 49000 - - - - - - - - -
2011-07-07 18:02:08 DROP UDP 192.168.1.11 239.255.255.250 1057 1900 153 - - - - - - - RECEIVE
2011-07-07 18:02:08 CLOSE TCP 192.168.1.11 80.156.86.89 1070 80 - - - - - - - - -
2011-07-07 18:02:21 OPEN UDP 192.168.1.11 192.168.1.1 60864 53 - - - - - - - - -
2011-07-07 18:02:21 OPEN TCP 192.168.1.11 178.237.23.235 1080 80 - - - - - - - - -
2011-07-07 18:02:18 OPEN UDP 192.168.1.11 192.168.1.1 57779 53 - - - - - - - - -
2011-07-07 18:02:21 CLOSE TCP 192.168.1.11 192.168.1.29 2069 2066 - - - - - - - - -
2011-07-07 18:02:21 OPEN UDP 192.168.1.11 192.168.1.1 52533 53 - - - - - - - - -
2011-07-07 18:02:21 OPEN UDP 192.168.1.11 192.168.1.1 55090 53 - - - - - - - - -
2011-07-07 18:02:21 OPEN TCP 192.168.1.11 178.237.23.235 1081 80 - - - - - - - - -
2011-07-07 18:02:08 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:02:08 OPEN UDP 192.168.1.11 192.168.1.1 57637 53 - - - - - - - - -
2011-07-07 18:02:18 OPEN TCP 192.168.1.11 4.27.29.254 1075 80 - - - - - - - - -
2011-07-07 18:02:18 OPEN TCP 192.168.1.11 62.52.45.177 1076 80 - - - - - - - - -
2011-07-07 18:02:18 CLOSE TCP 192.168.1.11 62.52.45.177 1076 80 - - - - - - - - -
2011-07-07 18:02:18 OPEN TCP 192.168.1.11 62.52.45.177 1077 80 - - - - - - - - -
2011-07-07 18:02:21 OPEN UDP 192.168.1.11 192.168.1.1 52861 53 - - - - - - - - -
2011-07-07 18:02:21 OPEN TCP 192.168.1.11 178.237.25.51 1083 80 - - - - - - - - -
2011-07-07 18:02:24 CLOSE TCP 192.168.1.11 62.52.45.177 1077 80 - - - - - - - - -
2011-07-07 18:02:24 DROP ICMP 192.168.1.11 192.168.1.1 - - 153 - - - - 3 3 - SEND
2011-07-07 18:02:29 CLOSE TCP 192.168.1.11 4.27.29.254 1075 80 - - - - - - - - -
2011-07-07 18:02:29 OPEN TCP 192.168.1.11 205.188.27.205 1078 5190 - - - - - - - - -
2011-07-07 18:02:26 OPEN TCP 192.168.1.11 192.168.1.29 2070 2066 - - - - - - - - -
2011-07-07 18:02:41 OPEN TCP 192.168.1.11 178.237.25.51 1094 80 - - - - - - - - -
2011-07-07 18:02:41 OPEN TCP 192.168.1.11 178.237.25.51 1095 80 - - - - - - - - -
2011-07-07 18:02:41 CLOSE TCP 192.168.1.11 192.168.1.29 2070 2066 - - - - - - - - -
2011-07-07 18:02:43 OPEN UDP 192.168.1.11 192.168.1.4 1073 161 - - - - - - - - -
2011-07-07 18:02:56 OPEN UDP 192.168.1.11 192.168.1.1 60894 53 - - - - - - - - -
2011-07-07 18:02:57 CLOSE TCP 192.168.1.11 178.237.25.51 1095 80 - - - - - - - - -
2011-07-07 18:02:57 CLOSE TCP 192.168.1.11 178.237.25.51 1096 80 - - - - - - - - -
2011-07-07 18:02:57 CLOSE TCP 192.168.1.11 178.237.25.51 1097 80 - - - - - - - - -
2011-07-07 18:02:57 CLOSE TCP 192.168.1.11 178.237.25.51 1099 80 - - - - - - - - -
2011-07-07 18:02:57 CLOSE TCP 192.168.1.11 178.237.25.51 1094 80 - - - - - - - - -
2011-07-07 18:02:57 CLOSE TCP 192.168.1.11 178.237.25.51 1098 80 - - - - - - - - -
2011-07-07 18:02:58 OPEN UDP 192.168.1.11 192.168.1.1 49910 53 - - - - - - - - -
2011-07-07 18:02:58 OPEN TCP 192.168.1.11 205.188.95.46 1102 443 - - - - - - - - -
2011-07-07 18:02:58 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:03:00 OPEN UDP 192.168.1.11 192.168.1.1 60604 53 - - - - - - - - -
2011-07-07 18:02:53 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:02:58 OPEN UDP 192.168.1.11 192.168.1.1 57525 53 - - - - - - - - -
2011-07-07 18:03:01 OPEN TCP 192.168.1.11 81.22.38.99 1107 80 - - - - - - - - -
2011-07-07 18:03:08 CLOSE TCP 192.168.1.11 93.188.130.45 1103 80 - - - - - - - - -
2011-07-07 18:03:08 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:03:00 OPEN TCP 192.168.1.11 81.22.38.131 1106 80 - - - - - - - - -
2011-07-07 18:03:01 CLOSE TCP 192.168.1.11 192.168.1.29 2071 2066 - - - - - - - - -
2011-07-07 18:03:01 OPEN UDP 192.168.1.11 192.168.1.1 59342 53 - - - - - - - - -
2011-07-07 18:03:02 OPEN UDP 192.168.1.11 64.12.104.112 1093 3479 - - - - - - - - -
2011-07-07 18:03:02 OPEN TCP 192.168.1.11 92.123.68.34 1108 80 - - - - - - - - -
2011-07-07 18:03:06 OPEN TCP 192.168.1.11 192.168.1.29 2072 2066 - - - - - - - - -
2011-07-07 18:03:13 CLOSE TCP 192.168.1.11 81.22.38.99 1107 80 - - - - - - - - -
2011-07-07 18:03:22 OPEN TCP 192.168.1.11 192.168.1.3 1123 80 - - - - - - - - -
2011-07-07 18:03:23 CLOSE TCP 192.168.1.11 178.237.23.235 1082 80 - - - - - - - - -
2011-07-07 18:03:18 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:03:33 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:03:38 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:03:36 CLOSE TCP 192.168.1.11 192.168.1.1 1069 49000 - - - - - - - - -
2011-07-07 18:03:43 CLOSE TCP 192.168.1.11 178.237.23.235 1081 80 - - - - - - - - -
2011-07-07 18:03:41 CLOSE TCP 192.168.1.11 192.168.1.29 2073 2066 - - - - - - - - -
2011-07-07 18:03:43 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:03:46 OPEN TCP 192.168.1.11 192.168.1.29 2074 2066 - - - - - - - - -
2011-07-07 18:03:54 CLOSE TCP 192.168.1.11 79.170.44.115 1129 80 - - - - - - - - -
2011-07-07 18:04:03 CLOSE TCP 192.168.1.11 74.125.39.148 1105 80 - - - - - - - - -
2011-07-07 18:04:03 CLOSE TCP 192.168.1.11 64.12.249.113 1101 80 - - - - - - - - -
2011-07-07 18:04:05 OPEN TCP 192.168.1.11 192.168.1.3 1146 80 - - - - - - - - -
2011-07-07 18:03:58 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:04:01 CLOSE TCP 192.168.1.11 192.168.1.29 2074 2066 - - - - - - - - -
2011-07-07 18:04:16 OPEN UDP 192.168.1.11 192.168.1.1 60242 53 - - - - - - - - -
2011-07-07 18:04:16 OPEN TCP 192.168.1.11 65.55.12.249 1148 80 - - - - - - - - -
2011-07-07 18:04:06 OPEN TCP 192.168.1.11 192.168.1.29 2075 2066 - - - - - - - - -
2011-07-07 18:04:08 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:04:23 CLOSE TCP 192.168.1.11 178.237.23.235 1080 80 - - - - - - - - -
2011-07-07 18:04:21 CLOSE TCP 192.168.1.11 192.168.1.29 2075 2066 - - - - - - - - -
2011-07-07 18:04:23 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:04:26 CLOSE TCP 192.168.1.11 192.168.1.3 1146 80 - - - - - - - - -
2011-07-07 18:04:28 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:04:38 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:04:43 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:04:33 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:04:41 CLOSE TCP 192.168.1.11 192.168.1.29 2076 2066 - - - - - - - - -
2011-07-07 18:04:48 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:04:50 OPEN TCP 192.168.1.11 192.168.1.3 1150 80 - - - - - - - - -
2011-07-07 18:04:49 CLOSE TCP 192.168.1.11 192.168.1.3 1149 9220 - - - - - - - - -
2011-07-07 18:04:53 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:04:58 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:05:06 OPEN TCP 192.168.1.11 192.168.1.29 2078 2066 - - - - - - - - -
2011-07-07 18:05:03 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:05:11 CLOSE TCP 192.168.1.11 192.168.1.3 1150 80 - - - - - - - - -
2011-07-07 18:05:13 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:05:18 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:05:21 CLOSE TCP 192.168.1.11 192.168.1.29 2078 2066 - - - - - - - - -
2011-07-07 18:05:33 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:05:28 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:05:38 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:05:43 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:05:41 CLOSE TCP 192.168.1.11 192.168.1.29 2079 2066 - - - - - - - - -
2011-07-07 18:05:46 OPEN TCP 192.168.1.11 192.168.1.29 2080 2066 - - - - - - - - -
2011-07-07 18:05:53 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:05:58 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:06:01 CLOSE TCP 192.168.1.11 192.168.1.29 2080 2066 - - - - - - - - -
2011-07-07 18:06:06 OPEN TCP 192.168.1.11 192.168.1.29 2081 2066 - - - - - - - - -
2011-07-07 18:06:03 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:06:18 OPEN TCP 192.168.1.11 95.100.249.73 1157 80 - - - - - - - - -
2011-07-07 18:06:20 CLOSE TCP 192.168.1.11 95.100.249.73 1157 80 - - - - - - - - -
2011-07-07 18:06:20 OPEN TCP 192.168.1.11 95.100.249.73 1158 80 - - - - - - - - -
2011-07-07 18:06:20 CLOSE TCP 192.168.1.11 95.100.249.73 1158 80 - - - - - - - - -
2011-07-07 18:06:21 CLOSE TCP 192.168.1.11 192.168.1.29 2081 2066 - - - - - - - - -
2011-07-07 18:06:17 OPEN UDP 192.168.1.11 192.168.1.1 64430 53 - - - - - - - - -
2011-07-07 18:06:18 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:06:20 OPEN UDP 192.168.1.11 192.168.1.1 50041 53 - - - - - - - - -
2011-07-07 18:06:23 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:06:36 CLOSE TCP 192.168.1.11 192.168.1.29 2082 2066 - - - - - - - - -
2011-07-07 18:06:28 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:06:33 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:06:38 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:06:41 OPEN TCP 192.168.1.11 192.168.1.29 2083 2066 - - - - - - - - -
2011-07-07 18:06:53 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:06:43 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:06:48 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:07:01 OPEN TCP 192.168.1.11 192.168.1.29 2084 2066 - - - - - - - - -
2011-07-07 18:06:56 CLOSE TCP 192.168.1.11 192.168.1.29 2083 2066 - - - - - - - - -
2011-07-07 18:06:58 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:07:03 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:07:16 CLOSE TCP 192.168.1.11 192.168.1.29 2084 2066 - - - - - - - - -
2011-07-07 18:07:08 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:07:13 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:07:18 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:07:21 OPEN TCP 192.168.1.11 192.168.1.29 2085 2066 - - - - - - - - -
2011-07-07 18:07:23 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:07:28 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:07:36 CLOSE TCP 192.168.1.11 192.168.1.29 2085 2066 - - - - - - - - -
2011-07-07 18:07:38 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:07:43 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
2011-07-07 18:07:33 DROP UDP 192.168.1.11 192.168.1.255 1044 1341 34 - - - - - - - RECEIVE
I am not able to read this. I actually deinstalled my AntiVirus for a short period of time.
Joerg
Post Thu Jul 07, 2011 4:15 pm
can you deactivate firewall for a bit as well? then restart serviio and/or the TV
Post Thu Jul 07, 2011 4:33 pm
Run this command at a command prompt. If you are on a windows machine.
netstat -an |find /i "listening"
It will show the computers open ports.
Joerg2003
Post Thu Jul 07, 2011 6:43 pm
Ok,
I deactivated the AntiVirus Guard again and I deactivated the firewall as well; still the same message on my tv "No device available".
I also tried "netstat -an" on DOS prompt, it says:
TCP 0.0.0.0:8895 0.0.0.0:0 Listening
UDP 0.0.0.0:1900 *:*
UDP 127.0.0.1:1900 *:*
UDP 192.168.1.11:1900 *:*
Maybe that helps to analyze.
Joerg
Post Thu Jul 07, 2011 6:53 pm
put your computer's IP address in the serviio console (bind). Restart serviio and then run the netstat command again.
Joerg2003
Post Thu Jul 07, 2011 7:47 pm
Ok,
In the serviio console (bind) I had the IP Address of the TV (192.168.1.6); I changed it now to the computer (192.168.1.11).
Probably that was wrong.
But nothing changed:
It still says on my tv: "No device available".
I also tried "netstat -an" on DOS prompt again, it still says:
Joerg
Post Thu Jul 07, 2011 7:52 pm
Joerg2003 wrote:Ok,
Joerg
yer that was wrong now u have the correct ip set can u restart Serviio (completeklly and not just from console ) or restart the computer running serviio and then it should work.
Joerg2003
Post Sat Jul 09, 2011 9:14 am
Yes, it works now.
Thanks to everybody, who helped. It was my mistake and/or my misunderstanding!
In the mean time I initialized the media library, it took me 6,5 hours (Allshare more than 8 hrs),
an update of the media library needed 0,5 hrs (Allshare needed 2 hrs).
That means I will stick to Serviio.
Regards Joerg
Post Sat Jul 09, 2011 6:36 pm
Joerg2003 wrote:Yes, it works now.
Regards Joerg
:) glad to see you are sticking with serviio :)
