Re: LG BD-390
I will try provide you the packet sniff from the player.
Would be great, as I tried to look at it using Intel UPnP tools and cannot see anything interesting there. It might require the actual device.
zip wrote:Actually it looks like the player supports subtitles over DLNA, Nero 4 can apparently play it. Will have a look and try to implement it. Testers welcome
zip wrote:Will have a look and try to implement it. Testers welcome
2010-06-02 22:17:30,125 INFO [MediaServer] ------------------------------------------------------------------------
2010-06-02 22:17:30,125 INFO [MediaServer] Serviio DLNA media streaming server v 0.4
2010-06-02 22:17:30,125 INFO [MediaServer] Petr Nejedly 2009-2010
2010-06-02 22:17:30,125 INFO [MediaServer] http://www.serviio.org
2010-06-02 22:17:30,125 INFO [MediaServer] Java 1.6.0_20-Sun Microsystems Inc.
2010-06-02 22:17:30,125 INFO [MediaServer] OS Windows XP x86 5.1
2010-06-02 22:17:30,125 INFO [MediaServer] File encoding: windows-1252
2010-06-02 22:17:30,140 INFO [ORBServer] Starting Corba server exposed on localhost:23423
2010-06-02 22:17:30,140 INFO [NamingService] Starting Corba Naming service on port 23423
2010-06-02 22:17:30,140 DEBUG [NamingService] Executing: c:\archivos de programa\java\jre6\bin\tnameserv -ORBInitialPort 23423
2010-06-02 22:17:30,812 DEBUG [ORBServer] Registering objects with the ORB
2010-06-02 22:17:30,890 DEBUG [ORBServer] Starting ORB
2010-06-02 22:17:30,890 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2010-06-02 22:17:30,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2010-06-02 22:17:31,546 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2010-06-02 22:17:31,546 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2010-06-02 22:17:31,546 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2010-06-02 22:17:31,546 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2010-06-02 22:17:31,625 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2010-06-02 22:17:31,640 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2010-06-02 22:17:31,718 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2010-06-02 22:17:31,718 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2010-06-02 22:17:31,750 INFO [ProfilesDefinitionParser] Added profile 'Samsung WiselinkPro' (id=2)
2010-06-02 22:17:31,750 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2010-06-02 22:17:31,781 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2010-06-02 22:17:31,781 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2010-06-02 22:17:31,796 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2010-06-02 22:17:31,796 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2010-06-02 22:17:31,812 INFO [ProfilesDefinitionParser] Added profile 'Samsung WiselinkPro (TV A-series)' (id=5)
2010-06-02 22:17:31,812 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2010-06-02 22:17:31,828 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2010-06-02 22:17:31,828 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2010-06-02 22:17:31,843 DEBUG [RepositoryDAOImpl] Reading all Repositories
2010-06-02 22:17:31,859 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2010-06-02 22:17:31,875 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2010-06-02 22:17:31,875 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Archivos de programa\Serviio\bin\\..\lib/ffmpeg.exe
2010-06-02 22:17:31,875 DEBUG [ProcessExecutor] Starting C:\Archivos de programa\Serviio\bin\\..\lib/ffmpeg.exe
2010-06-02 22:17:31,906 INFO [VideoDeliveryEngine] Cleaning transcode engine and its data
2010-06-02 22:17:31,921 INFO [WebServer] WebServer starting on port 8895
2010-06-02 22:17:32,078 INFO [Device] Created UPnP Device with UUID: 589e9dd0-b928-3c1d-8dbf-f6f400f8f8d8, bound address: 10.0.1.4
2010-06-02 22:17:32,093 DEBUG [DiscoveryManager] UPNP device 589e9dd0-b928-3c1d-8dbf-f6f400f8f8d8 is available
2010-06-02 22:17:32,093 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2010-06-02 22:17:32,093 INFO [DiscoverySearchListener] Starting DiscoverySearchListener using interface 10.0.1.4
2010-06-02 22:17:32,093 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2010-06-02 22:17:32,093 INFO [EventDispatcher] Starting EventDispatcher
2010-06-02 22:17:32,125 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface 10.0.1.4
2010-06-02 22:17:32,125 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 589e9dd0-b928-3c1d-8dbf-f6f400f8f8d8
2010-06-02 22:17:32,125 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 1428189 ms
2010-06-02 22:17:32,156 DEBUG [WebServer] Incoming connection from /10.0.1.4:1166
2010-06-02 22:17:32,156 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 589e9dd0-b928-3c1d-8dbf-f6f400f8f8d8 from null
2010-06-02 22:17:32,296 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2010-06-02 22:17:32,359 DEBUG [WebServer] Incoming connection from /10.0.1.4:1170
2010-06-02 22:17:32,359 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2010-06-02 22:17:32,359 DEBUG [WebServer] Incoming connection from /10.0.1.4:1171
2010-06-02 22:17:32,359 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2010-06-02 22:17:32,359 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2010-06-02 22:17:52,093 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2010-06-02 22:17:52,093 DEBUG [RepositoryDAOImpl] Reading all Repositories
2010-06-02 22:17:52,093 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2010-06-02 22:17:52,093 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: C:\Documents and Settings\Palma\Escritorio\prueba
2010-06-02 22:17:52,093 DEBUG [LibraryUpdatesCheckerThread] Looking for removed files in repository: C:\Documents and Settings\Palma\Escritorio\prueba
2010-06-02 22:17:52,093 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 1)
2010-06-02 22:17:52,125 DEBUG [LibraryAdditionsCheckerThread] Found file 'HIMYM_S05E24.avi', checking if it's already in the Library
2010-06-02 22:17:52,125 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item HIMYM_S05E24.avi
2010-06-02 22:17:52,171 DEBUG [MediaItemDAOImpl] Media item HIMYM_S05E24.avi already exists in DB
2010-06-02 22:17:52,250 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2010-06-02 22:17:52,265 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2010-06-02 22:17:52,265 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2010-06-02 22:17:52,265 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type IMAGE
2010-06-02 22:17:52,265 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1) and extractor EMBEDDED
2010-06-02 22:17:52,281 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1) and extractor COVER_IMAGE_IN_FOLDER
2010-06-02 22:17:52,281 DEBUG [LibraryUpdatesCheckerThread] Updating dirty metadata
2010-06-02 22:17:52,281 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 1)
2010-06-02 22:17:58,640 DEBUG [WebServer] Socket closed
2010-06-02 22:17:58,640 INFO [WebServer] WebServer shutting down
2010-06-02 22:17:58,640 DEBUG [DiscoveryManager] UPNP device 589e9dd0-b928-3c1d-8dbf-f6f400f8f8d8 is unavailable
2010-06-02 22:17:58,640 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2010-06-02 22:17:58,640 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2010-06-02 22:17:58,640 INFO [EventDispatcher] Leaving EventDispatcher
2010-06-02 22:17:58,640 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP byebye using interface 10.0.1.4
2010-06-02 22:17:58,656 INFO [DiscoverySearchListener] Leaving DiscoverySearchListener
2010-06-02 22:17:58,656 INFO [DatabaseManager] Shutting down database
2010-06-02 22:17:58,656 DEBUG [DBConnectionPool] Closed connection for pool Serviio DB Pool
2010-06-02 22:17:58,750 DEBUG [DatabaseManager] DB shutdown returned: Derby system shutdown.
2010-06-02 22:17:58,750 INFO [ORBServer] Stopped Corba server
2010-06-02 22:17:58,750 INFO [VideoDeliveryEngine] Cleaning transcode engine and its data
2010-06-02 22:18:06,765 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2010-06-02 22:18:06,781 INFO [MediaServer] ------------------------------------------------------------------------
2010-06-02 22:18:06,781 INFO [MediaServer] Serviio DLNA media streaming server v 0.4
2010-06-02 22:18:06,781 INFO [MediaServer] Petr Nejedly 2009-2010
2010-06-02 22:18:06,781 INFO [MediaServer] http://www.serviio.org
2010-06-02 22:18:06,781 INFO [MediaServer] Java 1.6.0_20-Sun Microsystems Inc.
2010-06-02 22:18:06,781 INFO [MediaServer] OS Windows XP x86 5.1
2010-06-02 22:18:06,781 INFO [MediaServer] File encoding: windows-1252
2010-06-02 22:18:06,796 INFO [ORBServer] Starting Corba server exposed on localhost:23423
2010-06-02 22:18:06,796 INFO [NamingService] Starting Corba Naming service on port 23423
2010-06-02 22:18:06,796 DEBUG [NamingService] Executing: c:\archivos de programa\java\jre6\bin\tnameserv -ORBInitialPort 23423
2010-06-02 22:18:07,453 DEBUG [ORBServer] Registering objects with the ORB
2010-06-02 22:18:07,531 DEBUG [ORBServer] Starting ORB
2010-06-02 22:18:07,531 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2010-06-02 22:18:07,531 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2010-06-02 22:18:08,234 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2010-06-02 22:18:08,234 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2010-06-02 22:18:08,234 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2010-06-02 22:18:08,234 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2010-06-02 22:18:08,312 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2010-06-02 22:18:08,312 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2010-06-02 22:18:08,406 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2010-06-02 22:18:08,406 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2010-06-02 22:18:08,437 INFO [ProfilesDefinitionParser] Added profile 'Samsung WiselinkPro' (id=2)
2010-06-02 22:18:08,437 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2010-06-02 22:18:08,453 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2010-06-02 22:18:08,453 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2010-06-02 22:18:08,468 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2010-06-02 22:18:08,468 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2010-06-02 22:18:08,500 INFO [ProfilesDefinitionParser] Added profile 'Samsung WiselinkPro (TV A-series)' (id=5)
2010-06-02 22:18:08,500 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2010-06-02 22:18:08,515 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2010-06-02 22:18:08,515 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2010-06-02 22:18:08,515 DEBUG [RepositoryDAOImpl] Reading all Repositories
2010-06-02 22:18:08,546 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2010-06-02 22:18:08,562 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2010-06-02 22:18:08,562 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Archivos de programa\Serviio\bin\\..\lib/ffmpeg.exe
2010-06-02 22:18:08,562 DEBUG [ProcessExecutor] Starting C:\Archivos de programa\Serviio\bin\\..\lib/ffmpeg.exe
2010-06-02 22:18:08,593 INFO [VideoDeliveryEngine] Cleaning transcode engine and its data
2010-06-02 22:18:08,609 INFO [WebServer] WebServer starting on port 8895
2010-06-02 22:18:08,765 INFO [Device] Created UPnP Device with UUID: 589e9dd0-b928-3c1d-8dbf-f6f400f8f8d8, bound address: 10.0.1.4
2010-06-02 22:18:08,781 DEBUG [DiscoveryManager] UPNP device 589e9dd0-b928-3c1d-8dbf-f6f400f8f8d8 is available
2010-06-02 22:18:08,781 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2010-06-02 22:18:08,781 INFO [DiscoverySearchListener] Starting DiscoverySearchListener using interface 10.0.1.4
2010-06-02 22:18:08,781 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2010-06-02 22:18:08,781 INFO [EventDispatcher] Starting EventDispatcher
2010-06-02 22:18:08,843 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface 10.0.1.4
2010-06-02 22:18:08,843 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 589e9dd0-b928-3c1d-8dbf-f6f400f8f8d8
2010-06-02 22:18:08,843 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 1221379 ms
2010-06-02 22:18:08,890 DEBUG [WebServer] Incoming connection from /10.0.1.4:1182
2010-06-02 22:18:08,890 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 589e9dd0-b928-3c1d-8dbf-f6f400f8f8d8 from null
2010-06-02 22:18:09,031 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2010-06-02 22:18:09,093 DEBUG [WebServer] Incoming connection from /10.0.1.4:1186
2010-06-02 22:18:09,093 DEBUG [WebServer] Incoming connection from /10.0.1.4:1187
2010-06-02 22:18:09,093 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2010-06-02 22:18:09,093 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2010-06-02 22:18:09,093 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2010-06-02 22:18:09,156 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2010-06-02 22:18:28,781 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2010-06-02 22:18:28,781 DEBUG [RepositoryDAOImpl] Reading all Repositories
2010-06-02 22:18:28,781 DEBUG [LibraryUpdatesCheckerThread] Looking for removed files in repository: C:\Documents and Settings\Palma\Escritorio\prueba
2010-06-02 22:18:28,781 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 1)
2010-06-02 22:18:28,796 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2010-06-02 22:18:28,796 DEBUG [RepositoryDAOImpl] Reading all Repositories
2010-06-02 22:18:28,796 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: C:\Documents and Settings\Palma\Escritorio\prueba
2010-06-02 22:18:28,812 DEBUG [LibraryAdditionsCheckerThread] Found file 'HIMYM_S05E24.avi', checking if it's already in the Library
2010-06-02 22:18:28,812 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item HIMYM_S05E24.avi
2010-06-02 22:18:28,875 DEBUG [MediaItemDAOImpl] Media item HIMYM_S05E24.avi already exists in DB
2010-06-02 22:18:28,953 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2010-06-02 22:18:28,968 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2010-06-02 22:18:28,968 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2010-06-02 22:18:28,968 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type IMAGE
2010-06-02 22:18:28,984 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1) and extractor EMBEDDED
2010-06-02 22:18:28,984 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1) and extractor COVER_IMAGE_IN_FOLDER
2010-06-02 22:18:28,984 DEBUG [LibraryUpdatesCheckerThread] Updating dirty metadata
2010-06-02 22:18:28,984 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 1)
2010-06-02 22:20:23,046 DEBUG [DiscoverySearchListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /10.0.1.4:1193
2010-06-02 22:20:23,046 DEBUG [DiscoverySearchListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /10.0.1.5:1194
2010-06-02 22:20:23,046 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-06-02 22:20:23,046 DEBUG [DiscoverySearchListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /127.0.0.1:1195
2010-06-02 22:20:23,109 DEBUG [WebServer] Incoming connection from /10.0.1.4:1196
2010-06-02 22:20:23,109 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 589e9dd0-b928-3c1d-8dbf-f6f400f8f8d8 from null
2010-06-02 22:20:23,109 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2010-06-02 22:20:23,187 DEBUG [WebServer] Incoming connection from /10.0.1.4:1203
2010-06-02 22:20:23,187 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2010-06-02 22:20:23,187 DEBUG [WebServer] Incoming connection from /10.0.1.4:1204
2010-06-02 22:20:23,187 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2010-06-02 22:20:23,187 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2010-06-02 22:20:23,250 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2010-06-02 22:20:56,203 DEBUG [DiscoverySearchListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /10.0.1.2:50906
2010-06-02 22:20:56,203 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-06-02 22:20:56,296 DEBUG [DiscoverySearchListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /10.0.1.2:50906
2010-06-02 22:20:56,312 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-06-02 22:20:56,406 DEBUG [DiscoverySearchListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /10.0.1.2:50906
2010-06-02 22:20:56,406 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-06-02 22:20:56,484 DEBUG [DiscoverySearchListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /10.0.1.2:50906
2010-06-02 22:20:56,484 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-06-02 22:20:59,000 DEBUG [WebServer] Incoming connection from /10.0.1.2:59863
2010-06-02 22:20:59,000 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 589e9dd0-b928-3c1d-8dbf-f6f400f8f8d8 from Linux/2.6.24.7.0909171-REL UPnP/1.0 DLNADOC/1.50 INTEL_NMPR/2.0 LG_DLNA_SDK/1.5.0
2010-06-02 22:20:59,000 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2010-06-02 22:20:59,062 DEBUG [WebServer] Incoming connection from /10.0.1.2:59864
2010-06-02 22:20:59,062 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2010-06-02 22:20:59,062 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2010-06-02 22:20:59,125 DEBUG [WebServer] Incoming connection from /10.0.1.2:59865
2010-06-02 22:20:59,125 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2010-06-02 22:20:59,125 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2010-06-02 22:21:02,937 DEBUG [WebServer] Incoming connection from /10.0.1.2:59866
2010-06-02 22:21:02,937 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service ConnectionManager
2010-06-02 22:21:02,937 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=172f815c-e75b-4f33-9e9b-1c08fe6b02e7) for service urn:upnp-org:serviceId:ConnectionManager reporting to http://10.0.1.2:43777/
2010-06-02 22:21:02,953 DEBUG [WebServer] Incoming connection from /10.0.1.2:59867
2010-06-02 22:21:02,953 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service ContentDirectory
2010-06-02 22:21:02,953 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=55721c52-533a-422d-a14a-84252f1b59d2) for service urn:upnp-org:serviceId:ContentDirectory reporting to http://10.0.1.2:43777/
2010-06-02 22:21:03,312 DEBUG [EventDispatcher] Sending event notification #0 for subscription 55721c52-533a-422d-a14a-84252f1b59d2 to endpoint http://10.0.1.2:43777/
2010-06-02 22:21:03,328 DEBUG [RequestExecutor] Sending HTTP request to 10.0.1.2:43777
2010-06-02 22:21:03,343 DEBUG [EventDispatcher] Event notification sent and received successfully
2010-06-02 22:21:03,343 DEBUG [EventDispatcher] Sending event notification #0 for subscription 172f815c-e75b-4f33-9e9b-1c08fe6b02e7 to endpoint http://10.0.1.2:43777/
2010-06-02 22:21:03,343 DEBUG [RequestExecutor] Sending HTTP request to 10.0.1.2:43777
2010-06-02 22:21:03,375 DEBUG [EventDispatcher] Event notification sent and received successfully
2010-06-02 22:21:03,859 DEBUG [WebServer] Incoming connection from /10.0.1.2:59868
2010-06-02 22:21:03,859 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from Linux/2.6.24.7.0909171-REL UPnP/1.0 DLNADOC/1.50 INTEL_NMPR/2.0 LG_DLNA_SDK/1.5.0:
2010-06-02 22:21:03,906 DEBUG [ContentDirectory] Browse() called for profile Generic DLNA profile with parameters: objectID = V_F#FOL_R1, browseFlag = BrowseMetadata, filter = *, startIndex = 0, count = 0, sortCriteria =
2010-06-02 22:21:03,906 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2010-06-02 22:21:03,906 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=0, title=Serviio Media Library, class=CONTAINER
2010-06-02 22:21:03,921 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A, title=Audio, class=CONTAINER
2010-06-02 22:21:03,921 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_A, title=Artists, class=CONTAINER
2010-06-02 22:21:03,937 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsByNameCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false
2010-06-02 22:21:03,937 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false
2010-06-02 22:21:03,937 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false
2010-06-02 22:21:03,937 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_F, title=Folders, class=CONTAINER
2010-06-02 22:21:03,937 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true
2010-06-02 22:21:03,953 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_G, title=Genres, class=CONTAINER
2010-06-02 22:21:03,953 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioGenresByNameCommand, containerClass=MUSIC_GENRE, itemClass=null, idPrefix=GEN, recursive=false
2010-06-02 22:21:03,953 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForGenreCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false
2010-06-02 22:21:03,953 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_T, title=Titles, class=CONTAINER
2010-06-02 22:21:03,953 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false
2010-06-02 22:21:03,953 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForInitialCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false
2010-06-02 22:21:03,968 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_S, title=All songs, class=CONTAINER
2010-06-02 22:21:03,968 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false
2010-06-02 22:21:03,968 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_AS, title=Artist Songs, class=CONTAINER
2010-06-02 22:21:03,968 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsByNameCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART_S, recursive=false
2010-06-02 22:21:03,968 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false
2010-06-02 22:21:03,968 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_ALB, title=All albums, class=CONTAINER
2010-06-02 22:21:03,984 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false
2010-06-02 22:21:03,984 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false
2010-06-02 22:21:03,984 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I, title=Image, class=CONTAINER
2010-06-02 22:21:03,984 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_A, title=Albums, class=CONTAINER
2010-06-02 22:21:03,984 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListFlatImageFoldersByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=ALB, recursive=false
2010-06-02 22:21:04,000 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForFolderCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false
2010-06-02 22:21:04,000 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_F, title=Folders, class=CONTAINER
2010-06-02 22:21:04,000 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true
2010-06-02 22:21:04,000 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_Y, title=Year, class=CONTAINER
2010-06-02 22:21:04,000 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false
2010-06-02 22:21:04,000 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false
2010-06-02 22:21:04,015 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_T, title=Timeline, class=CONTAINER
2010-06-02 22:21:04,015 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false
2010-06-02 22:21:04,015 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationMonthsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=MON, recursive=false
2010-06-02 22:21:04,015 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationMonthAndYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false
2010-06-02 22:21:04,015 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_AI, title=All images, class=CONTAINER
2010-06-02 22:21:04,015 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListAllImagesCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false
2010-06-02 22:21:04,031 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V, title=Video, class=CONTAINER
2010-06-02 22:21:04,031 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_T, title=All titles, class=CONTAINER
2010-06-02 22:21:04,031 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false
2010-06-02 22:21:04,031 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForInitialCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false
2010-06-02 22:21:04,031 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_M, title=Movies, class=CONTAINER
2010-06-02 22:21:04,031 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListMovieVideosByNameCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false
2010-06-02 22:21:04,031 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_S, title=Series, class=CONTAINER
2010-06-02 22:21:04,046 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeriesByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SER, recursive=false
2010-06-02 22:21:04,046 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeasonsForSeriesCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SSN, recursive=false
2010-06-02 22:21:04,046 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListEpisodesForSeriesSeasonCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false
2010-06-02 22:21:04,046 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_F, title=Folders, class=CONTAINER
2010-06-02 22:21:04,046 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true
2010-06-02 22:21:04,062 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LV, title=Last viewed, class=CONTAINER
2010-06-02 22:21:04,062 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastViewedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false
2010-06-02 22:21:04,062 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LA, title=Last added, class=CONTAINER
2010-06-02 22:21:04,062 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastAddedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false
2010-06-02 22:21:04,062 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_G, title=Genres, class=CONTAINER
2010-06-02 22:21:04,062 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoGenresByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=GEN, recursive=false
2010-06-02 22:21:04,078 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForGenreCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false
2010-06-02 22:21:04,078 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_A, title=Actors, class=CONTAINER
2010-06-02 22:21:04,078 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false
2010-06-02 22:21:04,078 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false
2010-06-02 22:21:04,078 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForActorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false
2010-06-02 22:21:04,078 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_D, title=Directors, class=CONTAINER
2010-06-02 22:21:04,093 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false
2010-06-02 22:21:04,093 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false
2010-06-02 22:21:04,093 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForDirectorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false
2010-06-02 22:21:04,093 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_P, title=Producers, class=CONTAINER
2010-06-02 22:21:04,093 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false
2010-06-02 22:21:04,109 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducersForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false
2010-06-02 22:21:04,109 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForProducerCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false
2010-06-02 22:21:04,109 DEBUG [RepositoryDAOImpl] Reading a Repository (id = 1)
2010-06-02 22:21:04,125 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder null
2010-06-02 22:21:04,156 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-06-02 22:21:04,218 DEBUG [WebServer] Incoming connection from /10.0.1.2:59869
2010-06-02 22:21:04,218 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from Linux/2.6.24.7.0909171-REL UPnP/1.0 DLNADOC/1.50 INTEL_NMPR/2.0 LG_DLNA_SDK/1.5.0:
2010-06-02 22:21:04,218 DEBUG [ContentDirectory] Browse() called for profile Generic DLNA profile with parameters: objectID = V_F#FOL_R1, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 10, sortCriteria =
2010-06-02 22:21:04,218 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder null
2010-06-02 22:21:04,234 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 1 (from=0, count=10)
2010-06-02 22:21:04,250 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2010-06-02 22:21:04,250 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2010-06-02 22:21:04,265 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2010-06-02 22:21:04,265 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2010-06-02 22:21:04,265 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1 and profile Generic DLNA profile
2010-06-02 22:21:04,265 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1)
2010-06-02 22:21:04,281 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder null
2010-06-02 22:21:04,281 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-06-02 22:21:05,390 DEBUG [WebServer] Incoming connection from /10.0.1.2:59870
2010-06-02 22:21:05,390 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from Linux/2.6.24.7.0909171-REL UPnP/1.0 DLNADOC/1.50 INTEL_NMPR/2.0 LG_DLNA_SDK/1.5.0:
2010-06-02 22:21:05,406 DEBUG [ContentDirectory] Browse() called for profile Generic DLNA profile with parameters: objectID = V_F, browseFlag = BrowseMetadata, filter = *, startIndex = 0, count = 0, sortCriteria =
2010-06-02 22:21:05,406 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO
2010-06-02 22:21:05,406 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-06-02 22:21:05,484 DEBUG [WebServer] Incoming connection from /10.0.1.2:59871
2010-06-02 22:21:05,484 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from Linux/2.6.24.7.0909171-REL UPnP/1.0 DLNADOC/1.50 INTEL_NMPR/2.0 LG_DLNA_SDK/1.5.0:
2010-06-02 22:21:05,484 DEBUG [ContentDirectory] Browse() called for profile Generic DLNA profile with parameters: objectID = V_F, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 10, sortCriteria =
2010-06-02 22:21:05,484 DEBUG [RepositoryDAOImpl] Retrieving list of Repositories for VIDEO (from=0, count=10)
2010-06-02 22:21:05,484 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder null
2010-06-02 22:21:05,484 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO
2010-06-02 22:21:05,484 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2010-06-02 22:21:06,312 DEBUG [WebServer] Incoming connection from /10.0.1.2:59872
2010-06-02 22:21:06,312 DEBUG [ResourceTransportRequestHandler] GET /resource/1/COVER_IMAGE HTTP/1.1, headers = [Host: 10.0.1.4:8895, Accept: */*, ]
2010-06-02 22:21:06,312 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.0.1.2, Profile=Generic DLNA profile'
2010-06-02 22:21:06,312 DEBUG [ResourceTransportRequestHandler] Request for resource 1 and type 'COVER_IMAGE' received
2010-06-02 22:21:06,328 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1)
2010-06-02 22:21:06,328 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 1
2010-06-02 22:21:06,328 DEBUG [ResourceTransportRequestHandler] Stream length required: false
2010-06-02 22:21:06,328 DEBUG [ResourceTransportRequestHandler] Creating stream entity with chunked transfer
2010-06-02 22:21:06,328 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-06-02 22:21:06,328 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [Content-Type: image/jpeg, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.4, transferMode.dlna.org: Interactive, ]
2010-06-02 22:21:21,937 DEBUG [DiscoverySearchListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /10.0.1.4:1193
2010-06-02 22:21:21,937 DEBUG [DiscoverySearchListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /10.0.1.5:1194
2010-06-02 22:21:21,937 DEBUG [DiscoverySearchListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /127.0.0.1:1195
2010-06-02 22:21:21,937 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-06-02 22:21:21,984 DEBUG [DiscoverySearchListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /10.0.1.5:1194
2010-06-02 22:21:21,984 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-06-02 22:21:27,046 DEBUG [DiscoverySearchListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /10.0.1.4:1193
2010-06-02 22:21:27,046 DEBUG [DiscoverySearchListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /10.0.1.5:1194
2010-06-02 22:21:27,046 DEBUG [DiscoverySearchListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /127.0.0.1:1195
2010-06-02 22:21:27,046 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-06-02 22:21:27,203 DEBUG [DiscoverySearchListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /10.0.1.5:1194
2010-06-02 22:21:27,203 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s)
2010-06-02 22:22:06,828 DEBUG [WebServer] Incoming connection from /10.0.1.2:59876
2010-06-02 22:22:06,843 DEBUG [ResourceTransportRequestHandler] GET /resource/1/MEDIA_ITEM HTTP/1.1, headers = [Range: bytes=0-15, Host: 10.0.1.4:8895, Accept: */*, ]
2010-06-02 22:22:06,843 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.0.1.2, Profile=Generic DLNA profile'
2010-06-02 22:22:06,843 DEBUG [ResourceTransportRequestHandler] Request for resource 1 and type 'MEDIA_ITEM' received
2010-06-02 22:22:06,843 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2010-06-02 22:22:06,843 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2010-06-02 22:22:06,843 DEBUG [VideoDeliveryEngine] Delivering item '1' for client 'IPAddress=/10.0.1.2, Profile=Generic DLNA profile'
2010-06-02 22:22:06,843 DEBUG [VideoDeliveryEngine] Delivering file 'HIMYM_S05E24.avi' in native format
2010-06-02 22:22:06,843 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2010-06-02 22:22:06,843 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1) as read
2010-06-02 22:22:06,875 DEBUG [ResourceTransportRequestHandler] Stream length required: true
2010-06-02 22:22:06,875 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 16
2010-06-02 22:22:06,875 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-06-02 22:22:06,875 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-msvideo, Content-Range: bytes 0-15/183268710, Content-Length: 16, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.4, transferMode.dlna.org: Streaming, ]
2010-06-02 22:22:07,234 DEBUG [WebServer] Incoming connection from /10.0.1.2:59877
2010-06-02 22:22:07,250 DEBUG [ResourceTransportRequestHandler] GET /resource/1/MEDIA_ITEM HTTP/1.1, headers = [Range: bytes=0-51199, Host: 10.0.1.4:8895, Accept: */*, ]
2010-06-02 22:22:07,250 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.0.1.2, Profile=Generic DLNA profile'
2010-06-02 22:22:07,250 DEBUG [ResourceTransportRequestHandler] Request for resource 1 and type 'MEDIA_ITEM' received
2010-06-02 22:22:07,250 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2010-06-02 22:22:07,250 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2010-06-02 22:22:07,250 DEBUG [VideoDeliveryEngine] Delivering item '1' for client 'IPAddress=/10.0.1.2, Profile=Generic DLNA profile'
2010-06-02 22:22:07,250 DEBUG [VideoDeliveryEngine] Delivering file 'HIMYM_S05E24.avi' in native format
2010-06-02 22:22:07,250 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2010-06-02 22:22:07,250 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1) as read
2010-06-02 22:22:07,250 DEBUG [ResourceTransportRequestHandler] Stream length required: true
2010-06-02 22:22:07,250 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 51200
2010-06-02 22:22:07,250 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-06-02 22:22:07,250 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-msvideo, Content-Range: bytes 0-51199/183268710, Content-Length: 51200, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.4, transferMode.dlna.org: Streaming, ]
2010-06-02 22:22:07,359 DEBUG [ResourceTransportRequestHandler] GET /resource/1/MEDIA_ITEM HTTP/1.1, headers = [Range: bytes=326-409, Host: 10.0.1.4:8895, Accept: */*, ]
2010-06-02 22:22:07,359 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.0.1.2, Profile=Generic DLNA profile'
2010-06-02 22:22:07,359 DEBUG [ResourceTransportRequestHandler] Request for resource 1 and type 'MEDIA_ITEM' received
2010-06-02 22:22:07,359 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2010-06-02 22:22:07,359 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2010-06-02 22:22:07,359 DEBUG [VideoDeliveryEngine] Delivering item '1' for client 'IPAddress=/10.0.1.2, Profile=Generic DLNA profile'
2010-06-02 22:22:07,359 DEBUG [VideoDeliveryEngine] Delivering file 'HIMYM_S05E24.avi' in native format
2010-06-02 22:22:07,359 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2010-06-02 22:22:07,359 DEBUG [ResourceTransportRequestHandler] Stream length required: true
2010-06-02 22:22:07,359 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 84
2010-06-02 22:22:07,359 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-06-02 22:22:07,359 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-msvideo, Content-Range: bytes 326-409/183268710, Content-Length: 84, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.4, transferMode.dlna.org: Streaming, ]
2010-06-02 22:22:07,421 DEBUG [ResourceTransportRequestHandler] GET /resource/1/MEDIA_ITEM HTTP/1.1, headers = [Range: bytes=362-445, Host: 10.0.1.4:8895, Accept: */*, ]
2010-06-02 22:22:07,421 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.0.1.2, Profile=Generic DLNA profile'
2010-06-02 22:22:07,421 DEBUG [ResourceTransportRequestHandler] Request for resource 1 and type 'MEDIA_ITEM' received
2010-06-02 22:22:07,421 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2010-06-02 22:22:07,421 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2010-06-02 22:22:07,421 DEBUG [VideoDeliveryEngine] Delivering item '1' for client 'IPAddress=/10.0.1.2, Profile=Generic DLNA profile'
2010-06-02 22:22:07,421 DEBUG [VideoDeliveryEngine] Delivering file 'HIMYM_S05E24.avi' in native format
2010-06-02 22:22:07,421 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2010-06-02 22:22:07,421 DEBUG [ResourceTransportRequestHandler] Stream length required: true
2010-06-02 22:22:07,421 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 84
2010-06-02 22:22:07,421 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-06-02 22:22:07,421 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-msvideo, Content-Range: bytes 362-445/183268710, Content-Length: 84, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.4, transferMode.dlna.org: Streaming, ]
2010-06-02 22:22:07,484 DEBUG [ResourceTransportRequestHandler] GET /resource/1/MEDIA_ITEM HTTP/1.1, headers = [Range: bytes=24-35, Host: 10.0.1.4:8895, Accept: */*, ]
2010-06-02 22:22:07,484 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/10.0.1.2, Profile=Generic DLNA profile'
2010-06-02 22:22:07,484 DEBUG [ResourceTransportRequestHandler] Request for resource 1 and type 'MEDIA_ITEM' received
2010-06-02 22:22:07,484 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2010-06-02 22:22:07,484 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2010-06-02 22:22:07,484 DEBUG [VideoDeliveryEngine] Delivering item '1' for client 'IPAddress=/10.0.1.2, Profile=Generic DLNA profile'
2010-06-02 22:22:07,484 DEBUG [VideoDeliveryEngine] Delivering file 'HIMYM_S05E24.avi' in native format
2010-06-02 22:22:07,484 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2010-06-02 22:22:07,484 DEBUG [ResourceTransportRequestHandler] Stream length required: true
2010-06-02 22:22:07,484 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 12
2010-06-02 22:22:07,484 DEBUG [ResourceTransportRequestHandler] Sending file back
2010-06-02 22:22:07,484 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [Content-Type: video/x-msvideo, Content-Range: bytes 24-35/183268710, Content-Length: 12, Cache-control: no-cache, Pragma: no-cache, Server: Windows XP UPnP/1.0 Serviio 0.4, transferMode.dlna.org: Streaming, ]zip wrote:I presume you have selected LG profile. That doesn't have any transcoding setup, so it's not transcoding issue. Is it just MKV's you have problems with? Also can you run ffmpeg -i <yourfile> and check what is the duration and if it matches the actual file duration?
<profile id="2f626312-b3cf-4a69-b22f-694f4b8ddd01">
<friendlyName>LG BD390</friendlyName>
<manufacturerName>LG</manufacturerName>
<modelName>LG BD Player</modelName>
<HTTPHeader inUASubstr="Linux/2.6.24.7.0909171-REL UPnP/1.0 DLNADOC/1.50 INTEL_NMPR/2.0 LG_DLNA_SDK/1.5.0"/>
<!-- The Name of the media serverdevice description file that should be used in conjunction with a player that
corresponds to this profile -->
<deviceDescription name="UPNP_AV_MediaServer_1.0.default.xml"/>
<!-- The container identifier media players of this profile expect
<contentDirectory shortUrl="true" friendlyFilename="false"/>
<!-- When transcoding is needed to which format should we transcode -->
<transcodeTarget audio="audio/mpeg" video="video/vob" photo="image/jpeg"
onlineAudio="audio/mpeg" onlineVideo="video/vob" onlinePhoto="image/jpeg" />
<maxVideoInfo width="1920" height="1080" bitrate="20000000" fps="60000/1001"></maxVideoInfo>
<minVideoInfo width="0" height="0" bitrate="0" fps="24"></minVideoInfo>
<maxImageInfo width="1920" height="1080"></maxImageInfo>
<minImageInfo width="0" height="0"></minImageInfo>
<maxAudioInfo sampleRate="48000" bitsperSample="16" nchannels="6" bitrate="1536000"></maxAudioInfo>
<minAudioInfo sampleRate="44100" bitsperSample="8" nchannels="1" bitrate="20000"></minAudioInfo>
<fileInfo maxSize="9223372036854775807"/>
<mimetypeList>
<mimetype value="audio/L16"/><!--PCM audio format-->
<mimetype value="audio/wav"/><!-- WAV audio format-->
<mimetype value="audio/x-wav" rename="audio/wav"/><!-- Another mume type used for WAV audio format-->
<mimetype value="audio/wave" rename="audio/wav"/><!-- Another mume type used for WAV audio format-->
<mimetype value="audio/x-pn-wav" rename="audio/wav"/><!-- Another mume type used for WAV audio format-->
<mimetype value="audio/mpeg"/><!-- MP3 audio format-->
<mimetype value="audio/x-mpeg" rename="audio/mpeg"/><!-- MP3 audio format-->
<mimetype value="audio/mp3" rename="audio/mpeg"/><!-- MP3 audio format-->
<mimetype value="audio/x-mp3" rename="audio/mpeg"/><!-- MP3 audio format-->
<mimetype value="audio/mpeg3" rename="audio/mpeg"/><!-- MP3 audio format-->
<mimetype value="audio/x-mpeg3" rename="audio/mpeg"/><!-- MP3 audio format-->
<mimetype value="audio/mpg" rename="audio/mpeg"/><!-- MP3 audio format-->
<mimetype value="audio/x-mpg" rename="audio/mpeg"/><!-- MP3 audio format-->
<mimetype value="audio/x-mpegaudio" rename="audio/mpeg"/><!-- MP3 audio format-->
<mimetype value="image/jpeg"/><!-- jpeg image format-->
<mimetype value="image/jp2"/><!--JPEG2000 image format-->
<mimetype value="video/mpeg"><!-- MPEG (1 or 2 program or transport stream) video format -->
<codec name="MPEG2VIDEO" />
<codec name="MP2" />
<codec name="MP3" />
</mimetype>
<mimetype value="video/mpeg2" rename="video/mpeg"/><!-- MPEG2 (program or transport stream) video format-->
<mimetype value="video/mp2p" rename="video/mpeg"/><!-- MPEG2 program stream (VOB) video format-->
<mimetype value="video/dvd" rename="video/mpeg"/><!-- MPEG2 program stream (VOB) video format-->
<mimetype value="video/mp2t" rename="video/mpeg"/><!-- MPEG2 transport stream video format-->
<mimetype value="video/MP4V-ES"><!-- MPEG4 video format-->
<codec name="H264"/><!-- H264, AKA MPEG4 AVC or MPEG4 layer 10 or MPEG4.10 -->
<codec name="AC3"/><!-- Dolby Digital AC3 Audio-->
</mimetype>
<mimetype value="video/mp4" rename="video/MP4V-ES"/><!-- MPEG4 video format-->
<mimetype value="video/x-matroska" rename="video/MP4V-ES"/>
</mimetypeList>
</profile>zip wrote:Regarding the log: yes, that's what I need. All the way up to a file being played. You can zip it up and/or upload to 4shared.com or attach here.
Count :
267
Count of stream of this kind :
1
Kind of stream :
Kind of stream :
Stream identifier :
0
Inform :
Matroska: 1.09 GiB, 43mn 13s
Count of video streams :
1
Count of audio streams :
1
Video_Format_List :
AVC
Video_Format_WithHint_List :
AVC
Codecs Video :
AVC
Audio_Format_List :
AC-3
Audio_Format_WithHint_List :
AC-3
Audio codecs :
AC3
Audio_Language_List :
English
Complete name :
Eureka.S04E05.720p.HDTV.x264-IMMERSE/eureka.s04e05.720p.hdtv.x264-immerse.mkv
Folder name :
File name :
File extension :
mkv
Format :
Matroska
Format :
Matroska
Format/Url :
http://packs.matroska.org/
Format/Extensions usually used :
mkv mka mks
Format_Commercial :
Matroska
Codec :
Matroska
Codec :
Matroska
Codec/Url :
Codec/Extensions usually used :
mkv mka mks
File size :
1174142956
File size :
1.09 GiB
File size :
1 GiB
File size :
1.1 GiB
File size :
1.09 GiB
File size :
1.094 GiB
Duration :
2593000
Duration :
43mn 13s
Duration :
43mn 13s 0ms
Duration :
43mn 13s
Duration :
00:43:13.000
Overall bit rate :
3622500
Overall bit rate :
3 622 Kbps
Stream size :
23361627
Stream size :
22.3 MiB (2%)
Stream size :
22 MiB
Stream size :
22 MiB
Stream size :
22.3 MiB
Stream size :
22.28 MiB
Stream size :
22.3 MiB (2%)
Proportion of this stream :
0.01990
File last modification date :
UTC 2010-08-07 10:11:18
File last modification date (local) :
2010-08-07 03:11:18
Writing application :
x264.exe
Writing library :
mkv2rls x264-tv version built on 2010 jul 11
Writing library :
mkv2rls x264-tv version built on 2010 jul 11Users browsing this forum: No registered users and 14 guests
