Database backup?
Scoty
Post Fri Jul 08, 2011 5:28 pm
Database backup?
I have all my Video and Audio index but how can i backup this ? Whene i make a new install i will not make a new Index.
Post Fri Jul 08, 2011 6:05 pm
Re: Database backup?
Just copy everything in the library folder.
From the FAQ
http://www.serviio.org/component/content/article/21#q8
How to upgrade Serviio to the latest version?
If you are upgrading to the latest version and want to keep all your settings and media library entries, do not uninstall your current Serviio version - a simple installation over the current one will do.
Windows
Simply run the installer and use the same installation location of your current version
Linux
Stop Serviio server and console
Overwrite all files in the current Serviio location with the new ones but keep folder library intact
OSX
Make a backup copy of your current library folder inside Serviio.app/Contents/Resources/Java
uninstall Serviio and install the latest version
copy backed up library folder into its location in the newly installed Serviio.app
Post Fri Jul 08, 2011 7:40 pm
moltra wrote:Just copy everything in the library folder.
From the FAQ
Windows
Linux
OSX
There will be changes made to the database for next release of serviio so doing this may not work for linux, and you will more than likely have to start from scratch.If you are running under window then by just running the upgrade wont affect your database it will just add the sections needed for the new release.
if your talking just doing a fesh install of the current version of serviio then Motra is correct just save the LIBRARY folder under serviio's installation do your reinstall and then copy the library folder back to your new installation, and provied the paths to the media have not change it will work. :)
Scoty
Post Fri Jul 08, 2011 8:06 pm
Whene comes the next Version?
Post Fri Jul 08, 2011 8:08 pm
Scoty wrote:Whene comes the next Version?
it is currently under closed beta testing with the tester group and will be released to public when it ready.
wprime
Post Sun Mar 16, 2014 6:57 pm
I am trying to upgrade from V1.4 to 1.4.1 and I am unable to find any folders inside Serviio.app. What do I do?
Post Sun Mar 16, 2014 10:08 pm
wprime wrote:Make a backup copy of your current library folder inside Serviio.app/Contents/Resources/Java
That particular instruction was for Mac OS X installations. Is yours installed on Windows?
wprime
Post Mon Mar 17, 2014 1:11 am
Yes I have a Mac running V10.6.8
Return to General discussion
