New gen Sony BDP-S780 player and 55HX923 tv
Rempstone
Post Sun Jul 10, 2011 12:43 pm
I have serviio installed on my Qnap. Managed to get the server up and running and can see my video and music folders but both the tv and blu-ray player report "there is no playable files". I am trying to switch over to serviio from twonky (I know wash my mouth out) because Sony claim they are compatible with serviio. But right now twonky can see files and play them albeit stuttering as they go, so no real use, so I want serviio to come to the rescue.
The files are m2ts and mp3 so suspect this is nothing to do with transcoding.
Has anyone had any success with any of the latest gen Sony kit and qnap servers they would like to share?
Thanks, Rob
Sony KDL-55HX923
Sony BDP-S780
Sony STA-3700ES
Dune TV301
Qnap TS 419P+
Post Sun Jul 10, 2011 2:20 pm
Re: New gen Sony BDP-S780 player and 55HX923 tv
make sure you're in Audio category in the Sony's media cross menu if you want to play Audio. The same for video.
Rempstone
Post Sun Jul 10, 2011 7:07 pm
Yeah I do that as a matter of course.
Sony KDL-55HX923
Sony BDP-S780
Sony STA-3700ES
Dune TV301
Qnap TS 419P+
Post Mon Jul 11, 2011 12:52 pm
Could you see these files with INTEL TOOL (see signature)?
Rempstone
Post Mon Jul 11, 2011 1:57 pm
Installed device spy if that is what you mean?
Installed it on my desktop and clicked invoke. Nothing came back into the Sink field box, so wondering what this means?
Sony KDL-55HX923
Sony BDP-S780
Sony STA-3700ES
Dune TV301
Qnap TS 419P+
Post Mon Jul 11, 2011 2:19 pm
Try AV Media Controller from the package.
Rempstone
Post Mon Jul 11, 2011 2:40 pm
Handy tool! I can see my test folder but no files in it. Which I guess means that it is not an issue with the Sony or popcorn kit cos they are showing the same.
Also, when I try to change categories i.e. "disable" then save I notice they immediately revert back to "display category"
Sony KDL-55HX923
Sony BDP-S780
Sony STA-3700ES
Dune TV301
Qnap TS 419P+
Post Mon Jul 11, 2011 2:48 pm
post ffmpeg -i for the files
also make sure the user running serviio has access to the shared folders
Rempstone
Post Tue Jul 12, 2011 8:25 am
Hmm. Will do once I've figured out how to get ffmpeg running. I have installed this via an optware QPKG from the Qnap site. But nothing happens when I run it so there must be something else I need to do to make ffmpeg work.
Sony KDL-55HX923
Sony BDP-S780
Sony STA-3700ES
Dune TV301
Qnap TS 419P+
Rempstone
Post Tue Jul 12, 2011 1:56 pm
Its taken a while to get ffmpeg working (with help) and not just exit out with a messahe saying "killed". This is what I get now.
[~] # /root/.serviio/opt/bin/ffmpeg -i /share/MD0_DATA/Multimedia/movies/mymovie.m2ts
/root/.serviio/opt/bin/ffmpeg: error while loading shared libraries: libasound.so.2: cannot open shared object file: No such file or directory
Sony KDL-55HX923
Sony BDP-S780
Sony STA-3700ES
Dune TV301
Qnap TS 419P+
Post Tue Jul 12, 2011 2:09 pm
it's still not properly installed
Rempstone
Post Wed Jul 13, 2011 11:54 am
We have fixed the install problem and some movies now work (all m2ts). But Serviio seems to ignore or skip some m2ts files resulting in them 1) not showing in folder listing when using the Sony S780 or 2) tagged with a "!" (won't play) under the popcorn. And it is the same movies missing or won't play on each media player. So serviio appears to have rejected some of my movies if this makes sense. I don't see this with twonky.
Also, using serviio audio (mp3s) are not showing on the Sony S780 but do play on the popcorn. Twonky works fine on the S780 and popcorn.
Sony KDL-55HX923
Sony BDP-S780
Sony STA-3700ES
Dune TV301
Qnap TS 419P+
Post Wed Jul 13, 2011 12:39 pm
Rempstone
Post Wed Jul 13, 2011 2:06 pm
Here is what ffmpeg -i produces.
  built on Jun 19 2011 01:00:22 with gcc 4.2.3
  configuration: --prefix=/share/Public/serviio/opt --extra-cflags=-I/opt/include --extra-ldflags=-L/opt/lib --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-libmp3lame
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 0 /  0.16. 0
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.92. 0 / 52.92. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.72. 0 /  1.72. 0
  libswscale     0.12. 0 /  0.12. 0
[mpegts @ 0xb90cf0] max_analyze_duration reached
[NULL @ 0xb99140] start time is not set in av_estimate_timings_from_pts
Input #0, mpegts, from 'cott.m2ts':
  Duration: 01:46:07.56, start: 600.000000, bitrate: 25878 kb/s
  Program 1
    Stream #0.0[0x1011]: Video: vc1, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 90k tbn, 23.98 tbc
    Stream #0.1[0x1100](eng): Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s
    Stream #0.2[0x1200](eng): Subtitle: pgssub
Sony KDL-55HX923
Sony BDP-S780
Sony STA-3700ES
Dune TV301
Qnap TS 419P+
Post Wed Jul 13, 2011 2:19 pm
Rempstone wrote:Input #0, mpegts, from 'cott.m2ts':
MPEG2TS / VC1 / DTS is a strange format:
With Sony Bravia TV, you need to transcode this file not supported in native format:
Edit Profiles.xml "Sony Bravia TV" section, and add "<Matches container="mpegts" vCodec="vc1" />" on the last <video> section
            <Matches container="asf" />
            <Matches container="avi" />
            <Matches container="mp4" />
            <Matches container="flv" />
Rempstone
Post Wed Jul 13, 2011 3:19 pm
Thanks Illico for the suggested fix.
Is this the same for Sony Blu-ray players which is what I'm primarily using to render the files? Blur-ray players play blu-ray disks that contain these files and hence must be able to process them?
Sony KDL-55HX923
Sony BDP-S780
Sony STA-3700ES
Dune TV301
Qnap TS 419P+
Post Wed Jul 13, 2011 3:33 pm
Rempstone wrote:Thanks Illico for the suggested fix.
Not exactly, because it seems that Sony BDP player could support VC1_TS_AP_L1_AC3_ISO, VC1_TS_AP_L2_AC3_ISO.
MPEG2TS / VC1 / AC3
So only audio need to be transcoded.
So on Sony BDP section on profiles.xml you could add this line "<Matches container="mpegts" vCodec="vc1" aCodec="dca" />" on the first <video> section
            <!-- FFmpeg cannot currently remux dts audio properly so it must be transcoded, but all other audio is left alone -->
But could you try the suggested fix for Sony Bravia TV too, please...we could add this into the next serviio release.
Rempstone
Post Wed Jul 13, 2011 4:30 pm
Results after edits.
Sony BDP S780: Files are now visible but when try to play says they are "unsupported or currupt".
Sony Bravia HX923: Files dont show up as before.
Popcorn A110: still get "!" yet I know this unit will play these files via twonky.
Sony KDL-55HX923
Sony BDP-S780
Sony STA-3700ES
Dune TV301
Qnap TS 419P+
Rempstone
Post Wed Jul 13, 2011 6:03 pm
Device spy Sink reports for my three players
Sony HX923 Bravia tv
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,http-get:*:audio/L16:DLNA.ORG_PN=LPCM;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_60_AC3_T;SONY.COM_PN=DTCP_AVC_TS_HD_60_AC3_T;DLNA.ORG_FLAGS=8d710000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3_T;SONY.COM_PN=AVC_TS_HD_60_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_50_AC3_T;SONY.COM_PN=AVC_TS_HD_50_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_60_AC3;SONY.COM_PN=DTCP_AVC_TS_HD_60_AC3;DLNA.ORG_FLAGS=8d710000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3;SONY.COM_PN=AVC_TS_HD_60_AC3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_50_AC3;SONY.COM_PN=AVC_TS_HD_50_AC3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_AVC_TS_HD_60_AC3_ISO;SONY.COM_PN=DTCP_AVC_TS_HD_60_AC3_ISO;DLNA.ORG_FLAGS=8d710000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_60_AC3_ISO;SONY.COM_PN=AVC_TS_HD_60_AC3_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_50_AC3_ISO;SONY.COM_PN=AVC_TS_HD_50_AC3_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_EU_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_EU;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_EU_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_JP_T;ARIB.OR.JP_PN=MPEG_TTS_CP;DLNA.ORG_FLAGS=8d710000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_JP_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_MPEG1_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_60_L2_T;SONY.COM_PN=HD2_60_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_50_L2_T;SONY.COM_PN=HD2_50_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_MPEG1_L2_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_60_L2_ISO;SONY.COM_PN=HD2_60_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_50_L2_ISO;SONY.COM_PN=HD2_50_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_60_AC3_T;SONY.COM_PN=DTCP_SESF_60_AC3_T;DLNA.ORG_FLAGS=8d710000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_60_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_50_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_JP_MPEG1_L2_T;DLNA.ORG_FLAGS=8d710000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_JP_MPEG1_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_MPEG1_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_MPEG_TS_SD_60_L2_T;SONY.COM_PN=DTCP_SESF_60_L2_T;DLNA.ORG_FLAGS=8d710000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_60_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_50_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_MPEG1_L2_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG1;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPLL_BASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_BASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-asf:DLNA.ORG_PN=VC1_ASF_AP_L1_WMA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-asf:DLNA.ORG_PN=VC1_ASF_AP_L2_WMA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_24_AC3_T;SONY.COM_PN=DTCP_AVC_TS_HD_24_AC3_T;DLNA.ORG_FLAGS=8d710000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3_T;SONY.COM_PN=AVC_TS_HD_24_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_HD_24_AC3;SONY.COM_PN=DTCP_AVC_TS_HD_24_AC3;DLNA.ORG_FLAGS=8d710000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3;SONY.COM_PN=AVC_TS_HD_24_AC3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/mpeg":DLNA.ORG_PN=DTCP_AVC_TS_HD_24_AC3_ISO;SONY.COM_PN=DTCP_AVC_TS_HD_24_AC3_ISO;DLNA.ORG_FLAGS=8d710000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;SONY.COM_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:application/x-dtcp1;CONTENTFORMAT="video/vnd.dlna.mpeg-tts":DLNA.ORG_PN=DTCP_AVC_TS_JP_AAC_T;DLNA.ORG_FLAGS=8d710000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_JP_AAC_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-mp2t-mphl-188:*,http-get:*:image/jpeg:*,http-get:*:audio/mpeg:*,http-get:*:audio/L16:*,http-get:*:audio/x-ms-wma:*,http-get:*:video/mpeg:*,http-get:*:video/vnd.dlna.mpeg-tts:*,http-get:*:video/mp4:*,http-get:*:video/x-msvideo:*,http-get:*:video/x-divx:*,http-get:*:video/divx:*,http-get:*:video/avi:*,http-get:*:video/x-ms-wmv:*,http-get:*:video/x-ms-asf:*
For the Sony BDP S780 player
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,http-get:*:image/png:DLNA.ORG_PN=PNG_LRG;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,http-get:*:image/png:DLNA.ORG_PN=PNG_TN;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,http-get:*:image/gif:DLNA.ORG_PN=GIF_LRG;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,http-get:*:audio/L16:DLNA.ORG_PN=LPCM;DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:audio/mpeg:DLNA.ORG_PN=MP3X;DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE;DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS;DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320;DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO;DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO;DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_320;DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO_320;DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_MULT5_ADTS;DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_MULT5_ISO;DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_MULT5_ISO;DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAAC_L2_ADTS;DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_L2_ISO;DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:audio/3gpp:DLNA.ORG_PN=HEAAC_L2_ISO;DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAAC_L2_ADTS_320;DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_L2_ISO_320;DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:audio/3gpp:DLNA.ORG_PN=HEAAC_L2_ISO_320;DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_L2_ISO_128;DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:audio/3gpp:DLNA.ORG_PN=HEAAC_L2_ISO_128;DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:audio/vnd.dts:DLNA.ORG_PN=DTS;DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:audio/vnd.dts.hd:DLNA.ORG_PN=DTSHD_HRA;DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:audio/vnd.dts.hd:DLNA.ORG_PN=DTSHD_MA;DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:audio/vnd.dts.hd:DLNA.ORG_PN=DTSHD_LBR;DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG1;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_50_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPLL_BASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_MP3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_BASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHM_BASE;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L31_HD_AAC;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L32_HD_AAC;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L3_SD_AAC;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L3L_SD_AAC;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_L2_CIF30_AAC;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_BL_CIF15_AAC_350;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_LC;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_HD_720P_AAC;DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/divx:DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-divx:DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-xvid:DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-msvideo:DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/avi:DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-matroska:DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/x-mp2t-mphl-188:DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_FLAGS=8cf00000000000000000000000000000,http-get:*:image/png:DLNA.ORG_FLAGS=8cf00000000000000000000000000000,http-get:*:image/gif:DLNA.ORG_FLAGS=8cf00000000000000000000000000000,http-get:*:audio/wav:DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:audio/x-wav:DLNA.ORG_FLAGS=9d700000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_FLAGS=8d700000000000000000000000000000,http-get:*:video/mpeg4:DLNA.ORG_FLAGS=8d700000000000000000000000000000
For the Popcorn A110
http-get:*:audio/x-mpegurl:*,http-get:*:video/x-mpegurl:*,http-get:*:audio/x-aac:*,http-get:*:audio/x-ac3:*,http-get:*:audio/lpcm:*,http-get:*:audio/x-quicktime:*,http-get:*:audio/m4a:*,http-get:*:audio/mp1:*,http-get:*:audio/mp2:*,http-get:*:audio/mpeg:*,http-get:*:audio/x-ogg:*,http-get:*:audio/wav:*,http-get:*:audio/x-ms-wma:*,http-get:*:audio/x-matroska:*,http-get:*:video/x-ms-asf:*,http-get:*:video/avi:*,http-get:*:video/quicktime:*,http-get:*:video/m4v:*,http-get:*:video/mp4:*,http-get:*:video/MP1S:*,http-get:*:video/MP2P:*,http-get:*:video/MP2T:*,http-get:*:video/MP4V-ES:*,http-get:*:video/mpeg2:*,http-get:*:video/mpeg:*,http-get:*:video/x-ms-avi:*,http-get:*:video/x-ms-wmv:*,http-get:*:video/x-msvideo:*,http-get:*:video/x-matroxka:*,http-get:*:image/jpeg:*,http-get:*:image/png:*
Sony KDL-55HX923
Sony BDP-S780
Sony STA-3700ES
Dune TV301
Qnap TS 419P+
Post Wed Jul 13, 2011 6:47 pm
Rempstone wrote:Results after edits.
Do you restart serviio service after profile modification?
Rempstone wrote:Sony BDP S780: Files are now visible but when try to play says they are "unsupported or currupt".
According to the previous GetInfoProtocol from your S780 device, this device doesn't support VC1_TS_AP_L1_AC3_ISO,
so as Sony Bravia TV, your movie must be transcoded into MPEG2 video and AC3 audio in a transport stream container.
so try this "<Matches container="mpegts" vCodec="vc1" aCodec="dca"/>" on latest <video> section ( aCodec="dca" could probably been omit)
            <!-- digital camera video formats -->
Could you check into the detailed logging file the ffmpeg command line used for transcoding this file and post here?
Rempstone wrote:Sony Bravia HX923: Files dont show up as before.
Do you mean, not appears when you browse folder tree, or no video displayed during transcoding?
