transcoding TRP files
jacobel
Post Mon Jul 11, 2011 1:23 pm
Can some one advise me HOW TO transcode TRP files.
The TRP file is the recording output (PVR) from a Clarke-tech 3100HD satellite Decorder.
thanks.
Post Mon Jul 11, 2011 1:39 pm
Re: transcoding TRP files
post ffmpeg -i of a file
jacobel
Post Mon Jul 11, 2011 5:34 pm
C:\Program Files\Serviio\lib>ffmpeg.exe -i 'D:/NED3HD.TRP'
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
'D:/NED3HD.TRP': Invalid data found when processing input
Details from other program - AVS Video Converter 8-
VideoCodec : H.264/AVC
Frame 1920x1080 pixels
Bitrate 8275 Kbps
fps 25
AudioCodec : AC3
Sample : 48 Kc 16 bits
Bitrate : 384 Kbps
Kanalen : 6
Will this help?
Post Tue Jul 12, 2011 8:22 am
looks like ffmpeg doesn't recognize it so won't be able to support this file, sorry
jacobel
Post Tue Jul 12, 2011 9:44 am
OK. But is this then the END of the story?
Post Tue Jul 12, 2011 10:01 am
You could ask at ffmpeg mailinglist. Otherwise transcode the files manually into a 'normal' format using a tool that supports it and then play as the other files.
Post Tue Jul 12, 2011 10:24 am
zip wrote:You could ask at ffmpeg mailinglist. Otherwise transcode the files manually into a 'normal' format using a tool that supports it and then play as the other files.
Or check if the latest ffmpeg release support this format, in this case in the next serviio release that will be ok.
jacobel
Post Tue Jul 12, 2011 11:15 am
OK, Thanks.
jacobel
Post Tue Jul 12, 2011 12:03 pm
I did some homework at the ffmpeg site and it seems to me that I need to build the ffmpeg with the external libx264 LIBRARY. Has the Serviio implementation such a possibility?
jacobel
Post Tue Jul 12, 2011 12:08 pm
you only need the library if you want to encode h264, so it's not needed for Serviio. Just download a latest WIndows build.
Post Tue Jul 12, 2011 12:13 pm
