I've been trying to sync my Toshiba TV with my PC
eyaloo
Post Thu Jul 14, 2011 2:13 pm
But it doesnt recognize it. what do I have to do? 10x
Post Thu Jul 14, 2011 2:34 pm
Re: I've been trying to sync my Toshiba TV with my PC
Can you post your serviio log? It is under the serviio install folder under the log folder.
eyaloo
Post Thu Jul 14, 2011 3:10 pm
I cant paste it all. its too long. but here are the last 20 rows:
2011-07-14 17:32:21,475 INFO [LibraryAdditionsCheckerThread] Added file 'MVI_2318.AVI' (title: 2010: The Year We Make Contact) to Library
2011-07-14 17:32:25,165 INFO [LibraryAdditionsCheckerThread] Added file 'MVI_2319.AVI' (title: 2010: The Year We Make Contact) to Library
2011-07-14 17:32:29,216 INFO [LibraryAdditionsCheckerThread] Added file 'MVI_2320.AVI' (title: 2010: The Year We Make Contact) to Library
2011-07-14 17:32:34,383 INFO [LibraryAdditionsCheckerThread] Added file 'MVI_2321.AVI' (title: 2010: The Year We Make Contact) to Library
2011-07-14 17:32:40,193 INFO [LibraryAdditionsCheckerThread] Added file 'MVI_2322.AVI' (title: 2010: The Year We Make Contact) to Library
2011-07-14 17:32:43,402 INFO [LibraryAdditionsCheckerThread] Added file 'MVI_2323.AVI' (title: 2010: The Year We Make Contact) to Library
2011-07-14 17:32:46,955 INFO [LibraryAdditionsCheckerThread] Added file 'MVI_2324.AVI' (title: 2010: The Year We Make Contact) to Library
2011-07-14 17:32:53,229 INFO [LibraryAdditionsCheckerThread] Added file 'MVI_2325.AVI' (title: 2010: The Year We Make Contact) to Library
2011-07-14 17:32:58,605 INFO [LibraryAdditionsCheckerThread] Added file 'MVI_2336.AVI' (title: 2010: The Year We Make Contact) to Library
2011-07-14 17:33:02,372 INFO [LibraryAdditionsCheckerThread] Added file 'MVI_2337.AVI' (title: 2010: The Year We Make Contact) to Library
2011-07-14 17:33:05,385 INFO [LibraryAdditionsCheckerThread] Added file 'MVI_2343.AVI' (title: 2010: The Year We Make Contact) to Library
2011-07-14 17:33:08,635 INFO [LibraryAdditionsCheckerThread] Added file 'MVI_2364.AVI' (title: 2010: The Year We Make Contact) to Library
2011-07-14 17:33:12,313 INFO [LibraryAdditionsCheckerThread] Added file 'MVI_2395.AVI' (title: 2010: The Year We Make Contact) to Library
2011-07-14 17:33:15,598 INFO [LibraryAdditionsCheckerThread] Added file 'MVI_2396.AVI' (title: 2010: The Year We Make Contact) to Library
2011-07-14 17:33:19,814 INFO [LibraryAdditionsCheckerThread] Added file 'MVI_2456.AVI' (title: 2010: The Year We Make Contact) to Library
2011-07-14 17:33:26,190 INFO [LibraryAdditionsCheckerThread] Added file 'MVI_2524.AVI' (title: 2010: The Year We Make Contact) to Library
2011-07-14 17:33:30,119 INFO [LibraryAdditionsCheckerThread] Added file 'MVI_2525.AVI' (title: 2010: The Year We Make Contact) to Library
2011-07-14 17:33:35,132 INFO [LibraryAdditionsCheckerThread] Added file 'MVI_2533.AVI' (title: 2010: The Year We Make Contact) to Library
2011-07-14 17:33:41,465 INFO [LibraryAdditionsCheckerThread] Added file 'MVI_2551.AVI' (title: 2010: The Year We Make Contact) to Library
2011-07-14 17:35:08,856 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://169.254.247.51:20000/description.xml
2011-07-14 17:35:28,857 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://169.254.247.51:20000/description.xml
2011-07-14 17:35:48,858 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://169.254.247.51:20000/description.xml
2011-07-14 17:37:39,852 INFO [RendererManager] Stored a new renderer: uuid='78b96482-9179-458d-998d-d02ec511c564', name = 'Unrecognized device', ipAddress='192.168.1.88', profile = '1'
2011-07-14 17:49:39,864 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://169.254.247.51:20000/description.xml
2011-07-14 17:49:59,865 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://169.254.247.51:20000/description.xml
2011-07-14 17:50:19,866 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://169.254.247.51:20000/description.xml
Post Thu Jul 14, 2011 3:40 pm
you can either stop serviio and delete the current log and then restart the log or you can zip the log and post it and someone will look at the whole log. What we need to see is not in the area that you posted. It is spread out in the log. it talkes about render and shows IP addresses.
Have you read the FAQ and made sure your ports was open?
You run the following command from the command line and it will show the computers open ports.
netstat -an |find /i "listening"
eyaloo
Post Thu Jul 14, 2011 5:10 pm
Mark hi, I'wanna attach the log file but cant find any "attach" button here. do u hava an email that I can send it to u?
Post Thu Jul 14, 2011 5:41 pm
At the bottom of the "post a reply" screen is a tab that says "upload attachment"
or if it small enough you can cut and paste it in the reply.
eyaloo
Post Thu Jul 14, 2011 5:51 pm
Ohhh...there u go
Post Thu Jul 14, 2011 5:55 pm
did you try and attach it? if so it did not work.
eyaloo
Post Thu Jul 14, 2011 6:18 pm
(237.57 KiB) Downloaded 953 times
yes. here once again.
Post Thu Jul 14, 2011 7:03 pm
What is the IP address of your TV? Serviio is not seeing any render. Make sure that your TV network is configured correctly. Also make sure that your ports are opened as mentioned in the FAQ.
My device doesn't see Serviio
This could be caused by you having multiple IP addresses on the machine and Serviio binding to a wrong one. Insert IP address of the machine running Serviio into 'Bound IP address' field in Network Settings section in the console or pass system variable serviio.boundAddr including the IP address when starting the server.
Also make sure that TCP port 8895 and UDP 1900 are open in your firewall.
If you are on a Linux based OS, make sure you set up multicast routes properly.
If on Windows, you can push Serviio service down in starting order.
You can check and see if your ports are open by using the following command in a command window.
ports. netstat -an |find /i "listening"
Return to Toshiba
