Certain files won't play on S370, and file title question
JaeDMC
Post Thu Jul 14, 2011 6:53 pm
I recently bought a SONY BDP-S370 and installed Serviio 5.2 on my Windows XP PC. I'm also using the correct profile "Sony BD Player"
I've got a couple of questions:
1)I have several files that have Japanese letters in their file titles, and Serviio doesn't want to add those. Do I just need to rename my files to all english in order for it to recognize it, or is there an "easier" way?
2) Some of my files are coming up as unplayable. They look like plain old DIVX .avi's to me, so I ran ffmpeg on a some and was hoping maybe you'd know what's going on and if it's something I can fix.
Here's four of them. There's several others but I figured maybe fixing one or two of these would be able to help fix them all.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Owner>cd "\Program Files\Serviio\lib
C:\Program Files\Serviio\lib>ffmpeg.exe -i "F:\WRESTLING\Japanese\2010\NOAH\NOAH
 11.9.2010 .All.For.One.One.For.All 1st half.avi"
686-mingw32-
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 0 /  0.16. 0
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.92. 0 / 52.92. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.72. 0 /  1.72. 0
  libswscale     0.12. 0 /  0.12. 0
Seems stream 0 codec frame rate differs from container frame rate: 30000.00 (300
00/1) -> 29.97 (30000/1001)
Input #0, avi, from 'F:\WRESTLING\Japanese\2010\NOAH\NOAH 11.9.2010 .All.For.One
.One.For.All 1st half.avi':
  Duration: 01:18:56.40, start: 0.000000, bitrate: 1642 kb/s
    Stream #0.0: Video: mpeg4, yuv420p, 624x352 [PAR 1:1 DAR 39:22], 29.97 fps,
29.97 tbr, 29.97 tbn, 30k tbc
    Stream #0.1: Audio: mp3, 48000 Hz, 2 channels, s16, 128 kb/s
C:\Program Files\Serviio\lib>ffmpeg.exe -i "F:\WRESTLING\Japanese\2010\K-OFFICE\
Kensuke Office 17. & 19.7.2010 2nd half.avi"
686-mingw32-
[mp3 @ 01080050] Header missing
[mpeg4 @ 016ad590] Invalid and inefficient vfw-avi packed B frames detected
Input #0, avi, from 'F:\WRESTLING\Japanese\2010\K-OFFICE\Kensuke Office 17. & 19
.7.2010 2nd half.avi':
  Duration: 00:54:41.77, start: 0.000000, bitrate: 1351 kb/s
    Stream #0.0: Video: mpeg4, yuv420p, 640x480 [PAR 1:1 DAR 4:3], 29.97 fps, 29
Kensuke Office 17. & 19.7.2010 1st half .avi"
686-mingw32-
[mpeg4 @ 016ad590] frame skip 8
    Last message repeated 1 times
.7.2010 1st half .avi':
  Duration: 01:04:32.96, start: 0.000000, bitrate: 1422 kb/s
C:\Program Files\Serviio\lib>ffmpeg.exe -i "F:\WRESTLING\Japanese\2010\NOAH\Koji
 Kanemoto & Tiger Mask IV vs Taiji Ishimori & Ricky Marvin - GHC Jr. Tag Team Ch
ampionships - NOAH 22.08.2010.avi"
686-mingw32-
[avi @ 016ac3f0] non-interleaved AVI
Input #0, avi, from 'F:\WRESTLING\Japanese\2010\NOAH\Koji Kanemoto & Tiger Mask
IV vs Taiji Ishimori & Ricky Marvin - GHC Jr. Tag Team Championships - NOAH 22.0
8.2010.avi':
    IDFV            : DMF 2.0.0
    encoder         : DivX 0.0.0.0000
  Duration: 00:32:54.94, start: 0.000000, bitrate: 1635 kb/s
      title           : Video
      title           : Audio
Anyway, thanks for any help, and I'm sorry if these kinds of things were answered I did try searching for stuff first.
Post Thu Jul 14, 2011 7:06 pm
Re: Certain files won't play on S370, and file title questio
I have not heard anything about trouble with japanese lettering for file name. If you do decide to do a rename, under the third party tools forum is a good renamer that will let you rename alot of files fast and is pretty flexible.
JaeDMC
Post Thu Jul 14, 2011 11:11 pm
Honestly, I thought the first time I set it all up the files with Japanese characters in the file name showed up. But since then I've had to do a reinstall and get things kosher with my firewall, and now they're not there. (Or maybe they never were - my memory is shoddy)
JaeDMC
Post Fri Jul 15, 2011 12:24 am
Okay, so I renamed some to english and they started to show up on my S370. Not one of them plays though. They all get a corrupted or unsupported error.
I grabbed one and ran ffmpeg on it and got:
C:\Program Files\Serviio\lib>ffmpeg.exe -i "F:\WRESTLING\Japanese\2010\AJPW\ALL
JAPAN B-Banquet 258 2010-4-18.avi"
686-mingw32-
Input #0, avi, from 'F:\WRESTLING\Japanese\2010\AJPW\ALL JAPAN B-Banquet 258 201
0-4-18.avi':
  Duration: 00:51:00.02, start: 0.000000, bitrate: 1390 kb/s
- which looks similar to one of the other messages I got in my original post, though I'm not really sure what any of it means.
Post Fri Jul 15, 2011 11:02 am
non-latin file names should be fixed in 0.6
the file might not be playing because of
JaeDMC
Post Fri Jul 15, 2011 3:47 pm
Any ideas on how to fix that? I've been googling the error and found a lot of people with that in their logs, but none of them seem to have the same problem I do, nor do they really get any answers as to what the problem means.
