Panasonic DMP-BD75
Kewl
Post Thu Jul 14, 2011 10:01 pm
Panasonic DMP-BD75
Here's the ffmpeg -i of two files that won't play with the Generic profile:
[matroska,webm @ 0x101807c00] Estimating duration from bitrate, this may be inaccurate
Input #0, matroska,webm, from '/Users/daniel/Desktop/TV/the.daily.show.2011.07.13.matthew.richardson.720p.hdtv.x264-momentum.mkv':
  Duration: 00:20:45.61, start: 0.000000, bitrate: 384 kb/s
    Stream #0.0(eng): Video: h264 (High), yuv420p, 1280x720, PAR 1:1 DAR 16:9, 59.94 fps, 59.94 tbr, 1k tbn, 119.88 tbc (default)
    Stream #0.1: Audio: ac3, 48000 Hz, stereo, s16, 384 kb/s (default)
Input #0, matroska,webm, from '/Users/daniel/Desktop/TV/the.colbert.report.2011.07.11.michael.shermer.720p.hdtv.x264-momentum.mkv':
  Duration: 00:20:56.98, start: 0.000000, bitrate: 384 kb/s
MacBook Pro • macOS 10.13 -> Oppo UDP-203 -> Sony XBR-65X750D
Post Fri Jul 15, 2011 12:16 pm
Re: Panasonic DMP-BD75
Did you try the Viera profile?
Kewl
Post Fri Jul 15, 2011 5:11 pm
For the sake of pinpointing exactly what plays or not, I'll do my test with the generic profile.
This will play:
Input #0, matroska,webm, from '/Users/daniel/Desktop/TV/futurama.s06e18.720p.hdtv.x264-immerse.mkv':
  Duration: 00:21:01.01, start: 0.000000, bitrate: 384 kb/s
    Stream #0.0(eng): Video: h264 (High), yuv420p, 1280x720, PAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s (default)
But this won't:
Input #0, matroska,webm, from '/Users/daniel/Desktop/TV/the.daily.show.2011.07.14.sgt.1st.class.leroy.petry.720p.hdtv.x264-momentum.mkv':
  Duration: 00:21:28.08, start: 0.000000, bitrate: 384 kb/s
Kewl
Post Fri Jul 15, 2011 5:15 pm
This will play:
[matroska,webm @ 0x101807c00] max_analyze_duration 5000000 reached at 5002000
Input #0, matroska,webm, from '/Users/daniel/Desktop/TV/miral.2010.1080p.bluray.x264-brmp.mkv':
  Duration: 01:45:37.95, start: 0.000000, bitrate: 1536 kb/s
    Stream #0.0(eng): Video: h264 (High), yuv420p, 1920x800 [PAR 1:1 DAR 12:5], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0.1(eng): Audio: dca (DTS), 48000 Hz, 5.1, s16, 1536 kb/s (default)
But this won't:
Input #0, matroska,webm, from '/Volumes/USB HD 2/rio.1080p.bluray.x264-honorblu.mkv':
  Duration: 01:35:57.81, start: 0.000000, bitrate: 1536 kb/s
    Stream #0.0(eng): Video: h264 (High), yuv420p, 1920x800 [PAR 1:1 DAR 12:5], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) (forced)
    Stream #0.1(eng): Audio: dca (DTS), 48000 Hz, 5.1, s16, 1536 kb/s (default) (forced)
Kewl
Post Fri Jul 15, 2011 5:27 pm
Apart from a couple of MKVs with DTS that won't play, most of the problematic files are with AC3, so I made this little profile for DMP-BD75:
   <Profile id="16" name="Panasonic BD Player" extendsProfileId="1">
            <Matches container="matroska" aCodec="ac3" />
It's more a profile that fits my MKVs consumption, rather than truly identifying and addressing the problem per se, but from the attributes available, this profile circumvent most of my playback problems.
Post Fri Jul 15, 2011 7:03 pm
Kewl wrote:For the sake of pinpointing exactly what plays or not, I'll do my test with the generic profile.
ok then good luck cause your wasting your time, unless you follow zips instruction and test with viera profile, the profiles aint there for the fun of it theres a reason. ;)
Kewl
Post Fri Jul 15, 2011 7:53 pm
You know, there's actually a polite way to say this.
If you look at the Viera profile, it "Remux all h264 video to MPEG-TS stream", but then again "FFmpeg cannot currently remux dts audio properly so it must be transcoded".
Since the Panasonic DMP-BD75 plays directly MKVs with H264 and DTS, I'd like to avoid transcoding, hence my little profile.
Post Sat Jul 16, 2011 6:31 am
trust me better than just completely ignoring the thread ;)
Post Sun Jul 17, 2011 4:27 pm
the files that play and that don't look pretty similar. Can you run MediaInfo on those (pick 2) and post the result here?
Kewl
Post Sun Jul 17, 2011 11:06 pm
With the generic profile, this file with AC3 will play:
Unique ID                        : 201996688025094940412225835588701963237 (0x97F725A2AC88DCE59B83B12C18A8C3E5)
Complete name                    : /Users/daniel/Desktop/TV/Torchwood.S04E02.720p.HDTV.X264-DIMENSION.mkv
Format                           : Matroska
Format version                   : Version 2
File size                        : 1.44 GiB
Duration                         : 53mn 43s
Overall bit rate                 : 3 835 Kbps
Encoded date                     : UTC 2011-07-15 21:33:00
Writing application              : mkvmerge v3.1.0 ('Happy up here') built on Jan 19 2010 12:09:24
Writing library                  : libebml v0.7.9 + libmatroska v0.8.1
Format profile                   : High@L4.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 8 frames
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 53mn 43s
Bit rate                         : 3 375 Kbps
Width                            : 1 280 pixels
Height                           : 720 pixels
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.153
Stream size                      : 1.27 GiB (88%)
Writing library                  : x264 core 115 r2008 4c552d8
Encoding settings                : cabac=1 / ref=8 / deblock=1:2:2 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language                         : English
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Codec ID                         : A_AC3
Duration                         : 53mn 43s
Bit rate                         : 384 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 16 bits
Stream size                      : 148 MiB (10%)
But this one will not:
Unique ID                        : 191275043405767990505900013818025306699 (0x8FE63BBE323A1F8C26EB34BBD65B6A4B)
Complete name                    : /Users/daniel/Desktop/TV/the.daily.show.2011.07.14.sgt.1st.class.leroy.petry.720p.hdtv.x264-momentum.mkv
Format                           : Matroska
File size                        : 441 MiB
Duration                         : 21mn 28s
Overall bit rate                 : 2 873 Kbps
Encoded date                     : UTC 2011-07-15 09:00:17
Writing application              : mkvmerge v4.8.0 ('I Got The...') built on Jun 13 2011 20:36:23
Writing library                  : libebml v1.2.0 + libmatroska v1.1.0
Format settings, ReFrames        : 5 frames
Muxing mode                      : Header stripping
Duration                         : 21mn 28s
Bit rate                         : 2 432 Kbps
Height                           : 720 pixels
Frame rate                       : 59.940 fps
Bits/(Pixel*Frame)               : 0.044
Stream size                      : 373 MiB (85%)
Writing library                  : x264 core 116 r2019 9cc407d
Encoding settings                : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=14 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language                         : English
Format                           : AC-3
Codec ID                         : A_AC3
Duration                         : 21mn 28s
Bit rate                         : 384 Kbps
Channel(s)                       : 2 channels
Channel positions                : Front: L R
Bit depth                        : 16 bits
Stream size                      : 59.0 MiB (13%)
One obvious difference is the frame rate.
As for files with DTS, this one will play:
Unique ID                        : 221529558880474874102622854542287181005 (0xA6A90A85A06937D3AF0D2A71D5DC14CD)
Complete name                    : /Users/daniel/Desktop/TV/Black.Swan.2010.BluRay.1080p.DTS.x264-CHD.mkv
Format                           : Matroska
File size                        : 14.0 GiB
Duration                         : 1h 48mn
Overall bit rate                 : 18.5 Mbps
Encoded date                     : UTC 2011-03-02 05:22:57
Writing application              : mkvmerge v3.2.0 ('Beginnings') 编译于 Feb 12 2010 16:46:17
Format settings, GOP             : M=1, N=51
Duration                         : 1h 48mn
Bit rate                         : 17.0 Mbps
Width                            : 1 920 pixels
Height                           : 800 pixels
Display aspect ratio             : 2.40:1
Bits/(Pixel*Frame)               : 0.462
Stream size                      : 12.6 GiB (90%)
Title                            : Black.Swan.2010
Writing library                  : x264 core 107 r1766 f9f0035
Encoding settings                : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.05:0.10 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=2 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=17025 / ratetol=1.0 / qcomp=0.70 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=30000 / ip_ratio=1.40 / aq=1:0.80 / nal_hrd=none
Language                         : English
Format                           : DTS
Format/Info                      : Digital Theater Systems
Codec ID                         : A_DTS
Duration                         : 1h 48mn
Bit rate                         : 1 510 Kbps
Bit depth                        : 24 bits
Stream size                      : 1.14 GiB (8%)
Title                            : DTS-CORE 1536K
Language                         : English
Unique ID                        : 42114409264251276477601666041833976031 (0x1FAEF0B03DA0464135973C470DC1F0DF)
Complete name                    : /Volumes/USB HD 2/Rio 2011 1080p Blu-ray Remux AVC DTS-HD MA 5.1 - KRaLiMaRKo.mkv
Format                           : Matroska
File size                        : 16.6 GiB
Duration                         : 1h 35mn
Overall bit rate                 : 24.8 Mbps
Encoded date                     : UTC 2011-07-17 18:14:10
Writing application              : mkvmerge v4.9.1 ('Ich will') built on Jul 16 2011 01:34:58
Writing library                  : libebml v1.2.1 + libmatroska v1.2.0
Format settings, ReFrames        : 4 frames
Duration                         : 1h 35mn
Bit rate mode                    : Variable
Bit rate                         : 22.7 Mbps
Maximum bit rate                 : 31.5 Mbps
Height                           : 1 080 pixels
Bits/(Pixel*Frame)               : 0.457
Stream size                      : 15.2 GiB (92%)
Language                         : English
Format                           : DTS
Format profile                   : MA / Core
Codec ID                         : A_DTS
Duration                         : 1h 35mn
Bit rate                         : 1 561 Kbps / 1 510 Kbps
Bit depth                        : 24 bits
Compression mode                 : Lossless / Lossy
Language                         : English
Post Mon Jul 18, 2011 6:47 am
With mkvmerge v4.9.1 and mkvmerge v3.1.0 have a look at this: viewtopic.php?f=6&t=1132
Kewl
Post Mon Jul 18, 2011 3:48 pm
Illico wrote:With mkvmerge v4.9.1 and mkvmerge v3.1.0 have a look at this: viewtopic.php?f=6&t=1132
Yes, that did the trick on the MKV/H264/AC3 at 59.94 fps. Thanks.
I'm left with one MKV/H264/DTS that won't play (the big 17 GB Rio), but I suspect there's a problem with the video encoding itself.
While testing, I stumbled on a file that will play fine (transcoded) on the Sony BDP-S370, but not on the Panasonic DMP-BD75. The Panny is able to play it (either transcoded or not), but it can't adequately decompress the video. I can see the keyframes go by, but between them, it becomes all blocky, as if the decompression can't make sense of the data between keyframes.
Here the MediaInfo on the file:
Unique ID                        : 200017267549201052049209797562387506611 (0x9679ECABD1B2F3647B44FB05707DA5B3)
Complete name                    : /Volumes/USB HD/Starship.Troopers.1997.1080p.BluRay.x264-hV.mkv
Format                           : Matroska
File size                        : 10.1 GiB
Duration                         : 2h 9mn
Overall bit rate                 : 11.2 Mbps
Encoded date                     : UTC 2011-07-18 13:28:24
Format profile                   : High@L5.1
Duration                         : 2h 9mn
Bit rate                         : 9 677 Kbps
Height                           : 1 040 pixels
Bits/(Pixel*Frame)               : 0.202
Stream size                      : 8.56 GiB (85%)
Writing library                  : x264 core 56 svn-667C
Encoding settings                : cabac=1 / ref=5 / deblock=1:-4:-4 / analyse=0x3:0x133 / me=umh / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=4,6 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=9677 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / zones=171650,186472,b=0.15 / aq=1:0.3:15.0
Language                         : English
Format                           : DTS
Codec ID                         : A_DTS
Duration                         : 2h 9mn
Bit depth                        : 24 bits
Stream size                      : 1.37 GiB (13%)
Language                         : English
Could it be because of this?
Post Mon Jul 18, 2011 7:35 pm
Kewl wrote:Could it be because of this?[code]Format profile : High@L5.1
Yes at 80%
20% ( libebml v1.2.1 used, x264 Encoding settings used, if DTS is remuxed into MPEGTS this is not supported yet with current ffmpeg version)
Kewl
Post Mon Jul 18, 2011 8:53 pm
Illico wrote:if DTS is remuxed into MPEGTS this is not supported yet with current ffmpeg version)
When I transcode anything with DTS, it's always to AC3 at 640 kbps.
Users browsing this forum: No registered users and 64 guests
