ffmpeg 0.8 "Love" released - works with 0.52
pc5dczc_nz
Post Sat Jun 25, 2011 12:56 am
Interestingly, the new stable release of ffmpeg, 0.8 "Love", appears to work properly with serviio 0.52.
It is able to "see" all of the movie files in my share and decode them appropriately. This was in contrast to the previous version (see here for more details: viewtopic.php?f=13&t=2530)
rrutkows
Post Fri Jul 15, 2011 9:42 pm
Re: ffmpeg 0.8 "Love" released - works with 0.52
There is something wrong with the ffmpeg 0.8, at least the one at debian-multimedia.org. The problem occurs if I pause or fast forward a video being transcoded to mpegts. Every time I try to do that, the video starts from the beginning. I have found a message "Unsupported time range request because bitrate is not available" in the log. Fortunately I was able to revert ffmpeg to version 0.6 from debian-testing and now pausing, fast forward and rewind of transcoded videos work fine again. I'm using serviio 0.52 with the default Panasonic profile. My client is a G20 Panasonic tv.
2011-07-15 22:56:16,796 DEBUG [WebServer] Incoming connection from /192.168.1.137:53690
2011-07-15 22:56:16,798 DEBUG [ResourceTransportRequestHandler] GET /resource/15/MEDIA_ITEM/AVC_TS_MP_HD_AAC_MULT5_ISO$0 HTTP/1.1, headers = [Host: 192.168.1.100:8895,TimeSeekRange.dlna.org: npt=00:01:15.040-00:01:16.040,transferMode.dlna.org: Streaming,Connection: keep-alive]]
2011-07-15 22:56:16,798 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.137
2011-07-15 22:56:16,800 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.137, Profile=Panasonic Viera'
2011-07-15 22:56:16,802 DEBUG [ResourceTransportRequestHandler] Request for resource 15 and type 'MEDIA_ITEM' received
2011-07-15 22:56:16,802 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 15)
2011-07-15 22:56:16,804 DEBUG [VideoDAOImpl] Reading a Video (id = 15)
2011-07-15 22:56:16,807 DEBUG [VideoDeliveryEngine] Delivering item '15' for client 'IPAddress=/192.168.1.137, Profile=Panasonic Viera'
2011-07-15 22:56:16,808 DEBUG [VideoDeliveryEngine] Delivering file 'Magnus.mp4' using transcoding
2011-07-15 22:56:16,808 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.137, Profile=Panasonic Viera'
2011-07-15 22:56:16,809 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Magnus.mp4: AVC_TS_MP_HD_AAC_MULT5_ISO
2011-07-15 22:56:16,809 DEBUG [AbstractTranscodingDeliveryEngine] Transcoded file '/tmp/Serviio/transcoding-temp-15-MPEG2TS.stf' is complete, sending simple stream
2011-07-15 22:56:16,810 DEBUG [ResourceTransportRequestHandler] Unsupported time range request because bitrate is not available, sending back 406
2011-07-15 22:56:16,810 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 406 Not Acceptable, headers = [[Content-Type: video/mpeg]]
I'll be happy to provide more info required to investigate this problem.
Post Fri Jul 15, 2011 10:59 pm
yes, they changed some text that Serviio looks for. Fixed for 0.6
macro_man
Post Tue Aug 23, 2011 4:32 pm
aahh haaa...... :o
i have been having the same issue.
now i know.
thanks a bunch will make the changes now.
sharif
pc5dczc_nz
Post Fri Aug 26, 2011 10:24 pm
Roll on v0.6!
Return to Panasonic
