Mpeg 4 not playing on Panasonic Vierra TV
andyleo77
Post Sat Jul 16, 2011 10:25 pm
Firstly, thanks for Serviio, its the most useful software I have used in many years.
I am not a big techie, and managed to play all my media files using Serviio on my Panasonic TV. That is until I changed my PC and re-installed the latest version of Serviio.
Not my panasonic wont play any MP4 files. I am adding the media info for one of the files which wont play.
Complete name : V:\English Movies\Mission Impossible Trilogy\Mission Impossible III 2006.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 1.75 GiB
Duration : 2h 5mn
Overall bit rate : 2 002 Kbps
Encoded date : UTC 2011-01-02 07:57:35
Tagged date : UTC 2011-01-02 07:57:35
Writing application : Yamb 2.1.0.0 [http://yamb.unite-video.com]
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 2h 5mn
Bit rate : 1 578 Kbps
Maximum bit rate : 12.5 Mbps
Width : 1 280 pixels
Height : 544 pixels
Display aspect ratio : 2.35:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.095
Stream size : 1.38 GiB (79%)
Writing library : x264 core 98 r1649 c54c47d
Encoding settings : cabac=1 / ref=3 / deblock=1:1:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=1578 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=25000 / vbv_bufsize=25000 / ip_ratio=1.40 / aq=1:1.10 / nal_hrd=none
Tagged date : UTC 2011-01-02 07:59:25
Audio #1
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 2h 5mn
Bit rate mode : Variable
Bit rate : 124 Kbps
Maximum bit rate : 143 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 111 MiB (6%)
Encoded date : UTC 2011-01-02 07:59:04
Audio #2
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 2h 5mn
Bit rate : 296 Kbps
Maximum bit rate : 328 Kbps
Channel(s) : 6 channels
Stream size : 265 MiB (15%)
Encoded date : UTC 2011-01-02 07:59:12
Also adding the transcoding profile for panasonic, I made a few tweaks and could have over-engineered here with my limited knowledge. The renderer profile is set to Panasoinc Vierra in the Console.
<Profile id="12" name="Panasonic Viera" extendsProfileId="1">
<ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.PanasonicDLNAMessageBuilder</ContentDirectoryMessageBuilder>
<MediaFormatProfiles>
</MediaFormatProfiles>
<!-- remux DTS in MKV to AC3 -->
<Matches container="matroska" vCodec="h264" aCodec="dca" />
<Matches container="avi" vCodec="h264" aCodec="dca" />
<Matches container="mp4" vCodec="h264" aCodec="dca" />
<!-- Remux all h264 video to MPEG-TS stream -->
<Matches container="mp4" />
<Matches container="flv" />
<Audio targetContainer="mp3">
<Matches container="flac" />
<Matches container="ogg" />
</Audio>
Post Sun Jul 17, 2011 7:18 am
Re: Mpeg 4 not playing on Panasonic Vierra TV
andyleo77 wrote:Hi,
<Matches container="mp4" /> <----- DUPLICATE remove me
</Audio>
Follow the instruction i have added and try again, remember to restart serviio COMPLETELY after editing the profile....
Post Sun Jul 17, 2011 4:53 pm
do you have the profile selected for the device? Is it just this one file not playing and was it playing before?
andyleo77
Post Sun Jul 17, 2011 5:12 pm
zip wrote:do you have the profile selected for the device? Is it just this one file not playing and was it playing before?
Yes, I have selected Panasonic Vierra as the renderer profile.
None of the MP4 files play. I have tried all of them.
I have followed Phil's instructions too, no luck even after re-starting the PC.
I even tried to reset the TV to factory defaults, still nothing.
Is there a way I can download the 0.5 version, all my MP4 files worked like a charm on that version.
Appreciate all the help.
andyleo77
Post Sun Jul 17, 2011 5:14 pm
Sorry zip...didnt answer the complete question. Yes this file was playing earlier and so were all the other MP4 files I have. None of the MP4's play now.
Serviio is able to generate thumbnails for the files but wont play them.
Post Mon Jul 18, 2011 10:49 am
http://download.serviio.org/releases/se ... -setup.exe (you'll have to uninstall first)
You could also post detailed log of when you're trying to play something.
Users browsing this forum: No registered users and 55 guests
