Playing HDC-TM700 .m2ts 1080/50p files
handsaw
Post Mon Jul 18, 2011 10:56 pm
Hi, Let me explain my problem. I Have a Panasonic HDC-TM700 camcorder and I recorded some videos on full HD 1080/50p and I would like watch it on my Samsung UE46C8000 using serveiio. The problem is that I can watch "normal AVCHD files" 1080/50i, but not the FULL Progressive 1080/50p Files. This .m2ts files use the codec H264 - MPEG-4 AVC 1920x1080 Frame Rate 100. I would like to know if will be possible on the new releases play these .m2ts files recorded on 1080/50p.
Thanks in Advance.
Post Tue Jul 19, 2011 6:43 am
Re: Playing HDC-TM700 .m2ts 1080/50p files
First, could you provide details of this file (see signature), "ffmpeg -i" result and MediaInfo result?
handsaw
Post Sat Jul 30, 2011 5:58 pm
Well I don't use ffmpeg never, but I will study it...about the Media Info, using VLC player I can see like,
Stream 0
Type:Video
Orignal: ID:4113
Codec:H264 - MPEG-4 AVC (part 10) (h264)
Resolution: 1920x1080
Frame rate: 100
Stream 1
Type:Audio
Orignal: ID:4352
Codec:A52 Audio (aka AC3)(a52)
Channels: 3F2R/LFE
Frame rate: 48000Hz
Bitrate:348 kb/s
Stream 2
Type: Subtitle
Original ID: 4608
Codec: BD subtitles (bdpg)
Post Sat Jul 30, 2011 6:01 pm
handsaw wrote:Well I don't use ffmpeg never, but I will study it...about the Media Info, using VLC player I can see like,
Stream 0
Type:Video
Orignal: ID:4113
Frame rate: 100
Stream 1
Type:Audio
Orignal: ID:4352
Channels: 3F2R/LFE
Frame rate: 48000Hz
Bitrate:348 kb/s
Stream 2
Type: Subtitle
Original ID: 4608
with full progressive file the profile level will be TO high, that why the file fails to play..
handsaw
Post Sat Jul 30, 2011 6:17 pm
Using FFmpeg I get:
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "c:\new\20110710_122059.m2ts
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
Input #0, mpegts, from 'c:\new\20110710_122059.m2ts':
Duration: 00:00:32.65, start:0.355411, bitrate:25602 kb/s
Program 1
Stream #0.0[0x1011]: Video h264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 50
fps, 50tbr, 90k tbn, 100 tbc
Stream #0.1[0x1100]: Audio: ac3, 48000 Hz, 5.1, s16, 384kb/s
Stream #0.2[0x1200]: Subtitle: pgssub
Return to Panasonic
