Error Code 7
Joerg2003
Post Thu Jul 21, 2011 7:39 pm
Error Code 7
now I have a new problem:
After starting my computer I am getting the following message from Serviio: "An internal error occured (error code 7)" and the serviio process does not start.
When I reinstall serviio again, it works fine; but next time I reboot my computer same message and procedure again.
What means error code 7 and how to avoid it?
Joerg
Post Thu Jul 21, 2011 7:49 pm
Re: Error Code 7
Can you post your serviio.log it is in your serviio directory in the Log folder.
We also need the following info:
Operating system:
Post Fri Jul 22, 2011 8:20 pm
Re: Error Code 7
Joerg2003 wrote:Hello,
Joerg
something running on your pc is corrupting the serviio installation, and with otu a bit mroe information on exactly what your setup is i am unabelt o tell exactly what program it is at this time.
Joerg2003
Post Fri Jul 22, 2011 10:45 pm
Re: Error Code 7
Sorry,
since yesterday I am not receiving the error code 7 message anymore and I have no idea what changed.
I believe it makes no sense to post the serviio.log file.
As soon as I'll receive the message again, I let you know.
Thank you for trying to help me.
Sorry Joerg
Joerg2003
Post Tue Jul 26, 2011 3:51 pm
Re: Error Code 7
Now I am getting the message "error code 7" again, while booting the PC.
I believe the log-File does not help much, because the file is not updated during the message.
After several attempts to start the serviio service and then starting the console, the log-file shows the following:
2011-07-26 17:42:02,984 INFO [MediaServer] ------------------------------------------------------------------------
2011-07-26 17:42:02,984 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-07-26 17:42:02,984 INFO [MediaServer] Petr Nejedly 2009-2011
2011-07-26 17:42:02,984 INFO [MediaServer] http://www.serviio.org
2011-07-26 17:42:02,984 INFO [MediaServer] Java 1.6.0_26-Sun Microsystems Inc.
2011-07-26 17:42:02,984 INFO [MediaServer] OS Windows XP x86 5.1
2011-07-26 17:42:02,984 INFO [MediaServer] File encoding: windows-1252
2011-07-26 17:42:03,125 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-07-26 17:42:03,187 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-07-26 17:42:04,890 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-07-26 17:42:05,171 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-07-26 17:42:05,312 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-07-26 17:42:05,453 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-07-26 17:42:05,515 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-07-26 17:42:05,593 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-07-26 17:42:05,656 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-07-26 17:42:05,781 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-07-26 17:42:05,812 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-07-26 17:42:06,000 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-07-26 17:42:06,343 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-07-26 17:42:06,421 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-07-26 17:42:06,500 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-07-26 17:42:06,703 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-07-26 17:42:06,734 INFO [WebServer] Socket buffer set to 65535 bytes
2011-07-26 17:42:06,781 INFO [WebServer] WebServer starting on port 8895
2011-07-26 17:42:06,796 INFO [Device] Created UPnP Device with UUID: 61cd396e-1894-3da9-91a2-e8090bcf4e54, bound address: 192.168.1.11
2011-07-26 17:42:06,828 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-07-26 17:42:06,828 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-07-26 17:42:06,843 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-07-26 17:42:06,843 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-07-26 17:42:06,843 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-26 17:42:06,843 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-07-26 17:42:06,843 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1311694926843, LastAccessTime = 1311694926843, getTimeToLiveSeconds() = -1, createTime = 1311694926843 ]
2011-07-26 17:42:06,843 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-07-26 17:42:06,859 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-07-26 17:42:06,859 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-26 17:42:06,859 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-07-26 17:42:06,859 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-07-26 17:42:06,859 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-26 17:42:06,859 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-07-26 17:42:06,859 INFO [CompositeCacheConfigurator] Finished configuration in 16 ms.
2011-07-26 17:42:06,859 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-26 17:42:06,859 INFO [EventDispatcher] Starting EventDispatcher
2011-07-26 17:42:06,859 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-26 17:42:06,859 INFO [RendererSearchSender] Searching for Renderer devices
2011-07-26 17:42:06,859 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-07-26 17:42:06,890 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (NVIDIA nForce Networking Controller - Paketplaner-Miniport) and address 192.168.1.11, timeout = 0
2011-07-26 17:42:27,140 INFO [ServiioConsole] Starting Serviio Console
2011-07-26 17:42:27,250 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-07-26 17:42:28,328 INFO [Messages] Loaded console message bundle for locale: en
2011-07-26 17:42:29,203 INFO [Messages] Loaded console message bundle for locale: de
2011-07-26 17:42:29,312 INFO [UpdateChecker] Checking if a new version is available
2011-07-26 17:42:35,828 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-07-26 17:42:36,187 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: de
I have no idea, what changed before I received the error message again.
Joerg
Users browsing this forum: Baidu [Spider] and 8 guests
