Doesn't show JPG by Adobe Lightroom
TV will not display JPGs coverted from RAW (Nikon SLR) by Adobe lightroom. Mediainfo says chroma subsampling of 4:4:4
Bravias only support JPEG YCbCr 4:2:2 or 4:2:0 formats.
JPEG YCbCr 4:4:4 is not supported.
After chatting with SONY's support, I was pointed in the direction of a technical spec. listed on the TV model's details:
"- JPEG (JPEG format files with the extension “.jpg” and conforming to DCF 2.0 or Exif 2.21)"
nzboi wrote:Apparently any high quality JPG's generated with Adobe Photoshop or lightroom won't play on sony's.
nzboi wrote:Bravias only support JPEG YCbCr 4:2:2 or 4:2:0 formats, and conforming to DCF 2.0 or Exif 2.21. JPEG YCbCr 4:4:4 is not supported.
