serviio won't start after pasting in code for Samsung
markymark
Post Fri Jul 22, 2011 4:23 am
hey guys,
I'm using the profile code for my new Samsung blu ray HTC 5500 that I found on the site (pasted below). And after I paste it in, Servioo wil not start so I can never choose this profile and finally get it working. I've also pasted the logs below. Any ideas on how to fix it?
CODE:
<Profile id="7" name="Samsung WiselinkPro - Blu-ray Player" extendsProfileId="2">
<!-- transcode MKV with DST audio to AC3, remux into mpeg2ts -->
<!-- transcode H264 MP4 files with LPCM audio -->
<Matches container="matroska" vCodec="h264" aCodec="dca"/>
<Matches container="mp4" vCodec="h264" aCodec="pcm_s16le" />
<Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video">
<Matches container="asf" vCodec="wmv2" />
<!-- transcode MKV with MPEG2 video, remux into mpeg2ts -->
<Matches container="matroska" vCodec="mpeg2video"/>
<!-- transcode AVI with AVC video -->
LOG:
<!DOCTYPE log4j:configuration SYSTEM "log4j.dtd">
<!-- Log4j Configuration -->
<log4j:configuration xmlns:log4j="http://jakarta.apache.org/log4j/" debug="false">
<appender name="FILE" class="org.apache.log4j.RollingFileAppender">
<param name="Threshold" value="DEBUG"/>
<param name="Append" value="true" />
<param name="File" value="${serviio.home}/log/serviio.log" />
<param name="MaxFileSize" value="500KB" />
<param name="MaxBackupIndex" value="5" />
<param name="Encoding" value="UTF-8" />
<layout class="org.apache.log4j.PatternLayout">
<param name="ConversionPattern" value="%d{ISO8601} %-5p [%c{1}] %m%n"/>
</layout>
</appender>
<category name="org.serviio">
<priority value="INFO"/>
</category>
<category name="org.jaudiotagger">
<priority value="ERROR"/>
</category>
<category name="org.restlet">
</category>
<root>
<appender-ref ref="FILE"/>
</root>
Post Fri Jul 22, 2011 7:15 am
Re: serviio won't start after pasting in code for Samsung
Suppose that <Profile id="7"> already exist, so there were in conflict.
Try with another id number after the latest 14 (for Version 0.5.2)
<Profile id="14"
This is not the good log file, provide ...\Serviio\log\serviio.log
Post Fri Jul 22, 2011 7:16 am
Why do you want to change the Samsung BDP profile?
markymark
Post Fri Jul 22, 2011 10:33 am
I would like to change the BPD profile because I thought that the Samsung blu ray home theatre is not included and needs to be added in order to work. Also, tried adding it as profile 14, no luck, crashes again.
Post Fri Jul 22, 2011 10:54 am
And what about log file?
pizzaguy541
Post Fri Jul 22, 2011 10:56 am
Try changing this line: <Matches container="mp4" vCodec="h264" aCodec="pcm_s16le" />
to
<Matches container="mp4" vCodec="h264" aCodec="lpcm" />
An entry towards the bottom of your log file should have said that there was a schema error with your profiles file.
markymark
Post Sat Jul 23, 2011 11:12 am
tried changing it, still no luck.
Post Sat Jul 23, 2011 3:36 pm
We need you to post your serviio.lg file or look through it for why serviio will not run.
