ffw, rew, jump problem bd-c5900 certain mkv files
thingy
Post Sun Jul 24, 2011 11:02 am
Hello.
I have this problem with certain mkv files, I do not know if the problem exist with other filetypes because 99% of my videos are mkv.
However, some of those mkv files when I try to fast forward, rewind or skip to a point in the movie, it starts over from the beginning.
It does not resume either if stop, and start to play it again, but that might be unrelated.
I even tried to remove compression of mkv headers, but no change in behaviour.
*edit: I have added the Samsung C profile in Serviio Console for this connection. Server running on W2008S. And no library updating at the time.
ffmpeg -i
686-mingw32-
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 0 /  0.16. 0
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.92. 0 / 52.92. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.72. 0 /  1.72. 0
  libswscale     0.12. 0 /  0.12. 0
[matroska,webm @ 0034bdf0] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/
1001) -> 23.98 (48000/2002)
Input #0, matroska,webm, from 'Limitless.2011.1080p.dts.mkv':
  Duration: 01:45:33.79, start: 0.000000, bitrate: 1536 kb/s
    Stream #0.0: Video: h264, yuv420p, 1920x800 [PAR 1:1 DAR 12:5], 23.98 fps, 2
3.98 tbr, 1k tbn, 47.95 tbc
    Stream #0.1(eng): Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s
Servioo log output:
2011-07-24 11:57:57,000 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:57:57,001 DEBUG [ResourceTransportRequestHandler] Request for resource 7848 and type 'MEDIA_ITEM' received
2011-07-24 11:57:57,001 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7848)
2011-07-24 11:57:57,002 DEBUG [VideoDAOImpl] Reading a Video (id = 7848)
2011-07-24 11:57:57,003 DEBUG [VideoDeliveryEngine] Delivering item '7848' for client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:57:57,003 DEBUG [VideoDeliveryEngine] Delivering file 'Limitless.2011.1080p.dts.mkv' in native format
2011-07-24 11:57:57,003 DEBUG [MediaItemDAOImpl] Getting file of media item 7848
2011-07-24 11:57:57,192 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 7848) as read
2011-07-24 11:57:57,390 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-07-24 11:57:57,441 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 8531642780
2011-07-24 11:57:57,441 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-07-24 11:57:57,441 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Range: bytes 0-8531642779/8531642780,Content-Length: 8531642780,Date: Sun, 24 Jul 2011 09:57:57 GMT,Server: Windows Server 2008, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,MediaInfo.sec: SEC_Duration=6333000;]]
2011-07-24 11:57:57,641 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-07-24 11:57:57,645 DEBUG [WebServer] Incoming connection from /192.168.0.59:54892
2011-07-24 11:57:57,646 DEBUG [ResourceTransportRequestHandler] GET /resource/7848/MEDIA_ITEM/MATROSKA$0 HTTP/1.0, headers = [Range: bytes=196608-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.0.42:8895]]
2011-07-24 11:57:57,646 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.59
2011-07-24 11:57:57,650 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:57:57,650 DEBUG [ResourceTransportRequestHandler] Request for resource 7848 and type 'MEDIA_ITEM' received
2011-07-24 11:57:57,650 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7848)
2011-07-24 11:57:57,651 DEBUG [VideoDAOImpl] Reading a Video (id = 7848)
2011-07-24 11:57:57,651 DEBUG [VideoDeliveryEngine] Delivering item '7848' for client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:57:57,651 DEBUG [VideoDeliveryEngine] Delivering file 'Limitless.2011.1080p.dts.mkv' in native format
2011-07-24 11:57:57,651 DEBUG [MediaItemDAOImpl] Getting file of media item 7848
2011-07-24 11:57:57,652 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 8531446172
2011-07-24 11:57:57,652 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-07-24 11:57:57,652 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Range: bytes 196608-8531642779/8531642780,Content-Length: 8531446172,Date: Sun, 24 Jul 2011 09:57:57 GMT,Server: Windows Server 2008, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-07-24 11:57:57,723 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-07-24 11:57:57,727 DEBUG [WebServer] Incoming connection from /192.168.0.59:43339
2011-07-24 11:57:57,730 DEBUG [ResourceTransportRequestHandler] HEAD /resource/7848/MEDIA_ITEM/MATROSKA$0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 192.168.0.42:8895]]
2011-07-24 11:57:57,731 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.59
2011-07-24 11:57:57,731 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:57:57,731 DEBUG [ResourceTransportRequestHandler] Request for resource 7848 and type 'MEDIA_ITEM' received
2011-07-24 11:57:57,731 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7848)
2011-07-24 11:57:57,732 DEBUG [VideoDAOImpl] Reading a Video (id = 7848)
2011-07-24 11:57:57,732 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 7848, format MATROSKA and profile Samsung TV / player (C/D-series)
2011-07-24 11:57:57,732 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-07-24 11:57:57,733 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-mkv,Content-Length: 8531642780,Date: Sun, 24 Jul 2011 09:57:57 GMT,Server: Windows Server 2008, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-07-24 11:57:57,742 DEBUG [WebServer] Incoming connection from /192.168.0.59:34572
2011-07-24 11:57:57,746 DEBUG [ResourceTransportRequestHandler] GET /resource/7848/MEDIA_ITEM/MATROSKA$0 HTTP/1.0, headers = [Range: bytes=0-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,Host: 192.168.0.42:8895]]
2011-07-24 11:57:57,746 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.59
2011-07-24 11:57:57,747 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:57:57,747 DEBUG [ResourceTransportRequestHandler] Request for resource 7848 and type 'MEDIA_ITEM' received
2011-07-24 11:57:57,747 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7848)
2011-07-24 11:57:57,747 DEBUG [VideoDAOImpl] Reading a Video (id = 7848)
2011-07-24 11:57:57,748 DEBUG [VideoDeliveryEngine] Delivering item '7848' for client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:57:57,748 DEBUG [VideoDeliveryEngine] Delivering file 'Limitless.2011.1080p.dts.mkv' in native format
2011-07-24 11:57:57,748 DEBUG [MediaItemDAOImpl] Getting file of media item 7848
2011-07-24 11:57:57,749 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 7848) as read
2011-07-24 11:57:57,764 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-07-24 11:57:57,764 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 8531642780
2011-07-24 11:57:57,765 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-07-24 11:57:57,765 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Range: bytes 0-8531642779/8531642780,Content-Length: 8531642780,Date: Sun, 24 Jul 2011 09:57:57 GMT,Server: Windows Server 2008, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,MediaInfo.sec: SEC_Duration=6333000;]]
2011-07-24 11:57:57,813 DEBUG [WebServer] Incoming connection from /192.168.0.59:50470
2011-07-24 11:57:57,814 DEBUG [ResourceTransportRequestHandler] HEAD /resource/7848/MEDIA_ITEM/MATROSKA$0 HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2011-07-24 11:57:57,814 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.59
2011-07-24 11:57:57,815 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:57:57,815 DEBUG [ResourceTransportRequestHandler] Request for resource 7848 and type 'MEDIA_ITEM' received
2011-07-24 11:57:57,815 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7848)
2011-07-24 11:57:57,818 DEBUG [VideoDAOImpl] Reading a Video (id = 7848)
2011-07-24 11:57:57,819 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 7848, format MATROSKA and profile Samsung TV / player (C/D-series)
2011-07-24 11:57:57,819 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7848)
2011-07-24 11:57:57,820 DEBUG [MediaItemDAOImpl] Getting file of media item 7848
2011-07-24 11:57:57,821 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-07-24 11:57:57,821 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-mkv,Content-Length: 8531642780,Date: Sun, 24 Jul 2011 09:57:57 GMT,Server: Windows Server 2008, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,transferMode.dlna.org: Streaming,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2011-07-24 11:57:58,186 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-07-24 11:57:58,192 DEBUG [WebServer] Incoming connection from /192.168.0.59:59921
2011-07-24 11:57:58,193 DEBUG [ResourceTransportRequestHandler] GET /resource/7848/MEDIA_ITEM/MATROSKA$0 HTTP/1.0, headers = [Range: bytes=196608-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.0.42:8895]]
2011-07-24 11:57:58,193 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.59
2011-07-24 11:57:58,193 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:57:58,194 DEBUG [ResourceTransportRequestHandler] Request for resource 7848 and type 'MEDIA_ITEM' received
2011-07-24 11:57:58,194 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7848)
2011-07-24 11:57:58,194 DEBUG [VideoDAOImpl] Reading a Video (id = 7848)
2011-07-24 11:57:58,194 DEBUG [VideoDeliveryEngine] Delivering item '7848' for client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:57:58,195 DEBUG [VideoDeliveryEngine] Delivering file 'Limitless.2011.1080p.dts.mkv' in native format
2011-07-24 11:57:58,195 DEBUG [MediaItemDAOImpl] Getting file of media item 7848
2011-07-24 11:57:58,195 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 8531446172
2011-07-24 11:57:58,195 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-07-24 11:57:58,196 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Range: bytes 196608-8531642779/8531642780,Content-Length: 8531446172,Date: Sun, 24 Jul 2011 09:57:58 GMT,Server: Windows Server 2008, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-07-24 11:57:58,208 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-07-24 11:57:58,210 DEBUG [WebServer] Incoming connection from /192.168.0.59:58229
2011-07-24 11:57:58,210 DEBUG [ResourceTransportRequestHandler] GET /resource/7848/MEDIA_ITEM/MATROSKA$0 HTTP/1.0, headers = [Range: bytes=196608-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.0.42:8895]]
2011-07-24 11:57:58,210 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.59
2011-07-24 11:57:58,215 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:57:58,215 DEBUG [ResourceTransportRequestHandler] Request for resource 7848 and type 'MEDIA_ITEM' received
2011-07-24 11:57:58,215 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7848)
2011-07-24 11:57:58,216 DEBUG [VideoDAOImpl] Reading a Video (id = 7848)
2011-07-24 11:57:58,216 DEBUG [VideoDeliveryEngine] Delivering item '7848' for client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:57:58,216 DEBUG [VideoDeliveryEngine] Delivering file 'Limitless.2011.1080p.dts.mkv' in native format
2011-07-24 11:57:58,216 DEBUG [MediaItemDAOImpl] Getting file of media item 7848
2011-07-24 11:57:58,217 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 8531446172
2011-07-24 11:57:58,217 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-07-24 11:57:58,217 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Range: bytes 196608-8531642779/8531642780,Content-Length: 8531446172,Date: Sun, 24 Jul 2011 09:57:58 GMT,Server: Windows Server 2008, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-07-24 11:57:58,229 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-07-24 11:57:58,231 DEBUG [WebServer] Incoming connection from /192.168.0.59:56769
2011-07-24 11:57:58,234 DEBUG [ResourceTransportRequestHandler] GET /resource/7848/MEDIA_ITEM/MATROSKA$0 HTTP/1.0, headers = [Range: bytes=16384-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.0.42:8895]]
2011-07-24 11:57:58,234 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.59
2011-07-24 11:57:58,235 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:57:58,235 DEBUG [ResourceTransportRequestHandler] Request for resource 7848 and type 'MEDIA_ITEM' received
2011-07-24 11:57:58,235 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7848)
2011-07-24 11:57:58,236 DEBUG [VideoDAOImpl] Reading a Video (id = 7848)
2011-07-24 11:57:58,236 DEBUG [VideoDeliveryEngine] Delivering item '7848' for client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:57:58,236 DEBUG [VideoDeliveryEngine] Delivering file 'Limitless.2011.1080p.dts.mkv' in native format
2011-07-24 11:57:58,236 DEBUG [MediaItemDAOImpl] Getting file of media item 7848
2011-07-24 11:57:58,237 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 8531626396
2011-07-24 11:57:58,237 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-07-24 11:57:58,237 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Range: bytes 16384-8531642779/8531642780,Content-Length: 8531626396,Date: Sun, 24 Jul 2011 09:57:58 GMT,Server: Windows Server 2008, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-07-24 11:58:02,530 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-07-24 11:58:02,535 DEBUG [WebServer] Incoming connection from /192.168.0.59:60918
2011-07-24 11:58:02,536 DEBUG [ResourceTransportRequestHandler] GET /resource/7848/MEDIA_ITEM/MATROSKA$0 HTTP/1.0, headers = [Range: bytes=196608-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.0.42:8895]]
2011-07-24 11:58:02,536 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.59
2011-07-24 11:58:02,536 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:58:02,537 DEBUG [ResourceTransportRequestHandler] Request for resource 7848 and type 'MEDIA_ITEM' received
2011-07-24 11:58:02,537 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7848)
2011-07-24 11:58:02,537 DEBUG [VideoDAOImpl] Reading a Video (id = 7848)
2011-07-24 11:58:02,538 DEBUG [VideoDeliveryEngine] Delivering item '7848' for client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:58:02,538 DEBUG [VideoDeliveryEngine] Delivering file 'Limitless.2011.1080p.dts.mkv' in native format
2011-07-24 11:58:02,538 DEBUG [MediaItemDAOImpl] Getting file of media item 7848
2011-07-24 11:58:02,539 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 8531446172
2011-07-24 11:58:02,539 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-07-24 11:58:02,539 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Range: bytes 196608-8531642779/8531642780,Content-Length: 8531446172,Date: Sun, 24 Jul 2011 09:58:02 GMT,Server: Windows Server 2008, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-07-24 11:58:02,553 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-07-24 11:58:02,554 DEBUG [WebServer] Incoming connection from /192.168.0.59:59932
2011-07-24 11:58:02,555 DEBUG [ResourceTransportRequestHandler] GET /resource/7848/MEDIA_ITEM/MATROSKA$0 HTTP/1.0, headers = [Range: bytes=196608-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.0.42:8895]]
2011-07-24 11:58:02,555 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.59
2011-07-24 11:58:02,555 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:58:02,556 DEBUG [ResourceTransportRequestHandler] Request for resource 7848 and type 'MEDIA_ITEM' received
2011-07-24 11:58:02,556 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7848)
2011-07-24 11:58:02,556 DEBUG [VideoDAOImpl] Reading a Video (id = 7848)
2011-07-24 11:58:02,556 DEBUG [VideoDeliveryEngine] Delivering item '7848' for client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:58:02,557 DEBUG [VideoDeliveryEngine] Delivering file 'Limitless.2011.1080p.dts.mkv' in native format
2011-07-24 11:58:02,557 DEBUG [MediaItemDAOImpl] Getting file of media item 7848
2011-07-24 11:58:02,557 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 8531446172
2011-07-24 11:58:02,558 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-07-24 11:58:02,558 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Range: bytes 196608-8531642779/8531642780,Content-Length: 8531446172,Date: Sun, 24 Jul 2011 09:58:02 GMT,Server: Windows Server 2008, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-07-24 11:58:02,570 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-07-24 11:58:02,571 DEBUG [WebServer] Incoming connection from /192.168.0.59:38165
2011-07-24 11:58:02,572 DEBUG [ResourceTransportRequestHandler] GET /resource/7848/MEDIA_ITEM/MATROSKA$0 HTTP/1.0, headers = [Range: bytes=16384-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.0.42:8895]]
2011-07-24 11:58:02,572 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.59
2011-07-24 11:58:02,572 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:58:02,573 DEBUG [ResourceTransportRequestHandler] Request for resource 7848 and type 'MEDIA_ITEM' received
2011-07-24 11:58:02,573 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7848)
2011-07-24 11:58:02,573 DEBUG [VideoDAOImpl] Reading a Video (id = 7848)
2011-07-24 11:58:02,574 DEBUG [VideoDeliveryEngine] Delivering item '7848' for client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:58:02,574 DEBUG [VideoDeliveryEngine] Delivering file 'Limitless.2011.1080p.dts.mkv' in native format
2011-07-24 11:58:02,574 DEBUG [MediaItemDAOImpl] Getting file of media item 7848
2011-07-24 11:58:02,574 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 8531626396
2011-07-24 11:58:02,575 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-07-24 11:58:02,575 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Range: bytes 16384-8531642779/8531642780,Content-Length: 8531626396,Date: Sun, 24 Jul 2011 09:58:02 GMT,Server: Windows Server 2008, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-07-24 11:58:05,025 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:1a16184a-7576-37cf-b4be-b37fc8c133cf from address /192.168.0.59:1025
2011-07-24 11:58:05,028 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.59:1025
2011-07-24 11:58:05,325 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:1a16184a-7576-37cf-b4be-b37fc8c133cf from address /192.168.0.59:1025
2011-07-24 11:58:05,326 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.59:1025
2011-07-24 11:58:05,625 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:1a16184a-7576-37cf-b4be-b37fc8c133cf from address /192.168.0.59:1025
2011-07-24 11:58:05,628 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.59:1025
2011-07-24 11:58:12,024 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:7b46d10f-a4a9-4962-91e9-0f52ad827d2a from address /192.168.0.59:1025
2011-07-24 11:58:12,026 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:af066bff-fc3f-4dc3-802f-82526696e8e9 from address /192.168.0.59:1026
2011-07-24 11:58:12,324 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:7b46d10f-a4a9-4962-91e9-0f52ad827d2a from address /192.168.0.59:1025
2011-07-24 11:58:12,327 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:af066bff-fc3f-4dc3-802f-82526696e8e9 from address /192.168.0.59:1026
2011-07-24 11:58:12,624 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:7b46d10f-a4a9-4962-91e9-0f52ad827d2a from address /192.168.0.59:1025
2011-07-24 11:58:12,627 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:af066bff-fc3f-4dc3-802f-82526696e8e9 from address /192.168.0.59:1026
2011-07-24 11:58:19,327 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-07-24 11:58:19,334 DEBUG [WebServer] Incoming connection from /192.168.0.59:41155
2011-07-24 11:58:19,334 DEBUG [ResourceTransportRequestHandler] GET /resource/7848/MEDIA_ITEM/MATROSKA$0 HTTP/1.0, headers = [Range: bytes=196608-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.0.42:8895]]
2011-07-24 11:58:19,335 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.59
2011-07-24 11:58:19,336 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:58:19,336 DEBUG [ResourceTransportRequestHandler] Request for resource 7848 and type 'MEDIA_ITEM' received
2011-07-24 11:58:19,336 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7848)
2011-07-24 11:58:19,336 DEBUG [VideoDAOImpl] Reading a Video (id = 7848)
2011-07-24 11:58:19,337 DEBUG [VideoDeliveryEngine] Delivering item '7848' for client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:58:19,337 DEBUG [VideoDeliveryEngine] Delivering file 'Limitless.2011.1080p.dts.mkv' in native format
2011-07-24 11:58:19,337 DEBUG [MediaItemDAOImpl] Getting file of media item 7848
2011-07-24 11:58:19,338 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 8531446172
2011-07-24 11:58:19,338 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-07-24 11:58:19,338 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Range: bytes 196608-8531642779/8531642780,Content-Length: 8531446172,Date: Sun, 24 Jul 2011 09:58:19 GMT,Server: Windows Server 2008, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-07-24 11:58:19,351 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-07-24 11:58:19,353 DEBUG [WebServer] Incoming connection from /192.168.0.59:53601
2011-07-24 11:58:19,353 DEBUG [ResourceTransportRequestHandler] GET /resource/7848/MEDIA_ITEM/MATROSKA$0 HTTP/1.0, headers = [Range: bytes=196608-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.0.42:8895]]
2011-07-24 11:58:19,353 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.59
2011-07-24 11:58:19,354 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:58:19,354 DEBUG [ResourceTransportRequestHandler] Request for resource 7848 and type 'MEDIA_ITEM' received
2011-07-24 11:58:19,354 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7848)
2011-07-24 11:58:19,354 DEBUG [VideoDAOImpl] Reading a Video (id = 7848)
2011-07-24 11:58:19,355 DEBUG [VideoDeliveryEngine] Delivering item '7848' for client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:58:19,355 DEBUG [VideoDeliveryEngine] Delivering file 'Limitless.2011.1080p.dts.mkv' in native format
2011-07-24 11:58:19,355 DEBUG [MediaItemDAOImpl] Getting file of media item 7848
2011-07-24 11:58:19,356 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 8531446172
2011-07-24 11:58:19,356 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-07-24 11:58:19,356 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Range: bytes 196608-8531642779/8531642780,Content-Length: 8531446172,Date: Sun, 24 Jul 2011 09:58:19 GMT,Server: Windows Server 2008, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-07-24 11:58:19,369 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2011-07-24 11:58:19,370 DEBUG [WebServer] Incoming connection from /192.168.0.59:48804
2011-07-24 11:58:19,370 DEBUG [ResourceTransportRequestHandler] GET /resource/7848/MEDIA_ITEM/MATROSKA$0 HTTP/1.0, headers = [Range: bytes=16384-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.0.42:8895]]
2011-07-24 11:58:19,371 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.59
2011-07-24 11:58:19,371 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:58:19,371 DEBUG [ResourceTransportRequestHandler] Request for resource 7848 and type 'MEDIA_ITEM' received
2011-07-24 11:58:19,371 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7848)
2011-07-24 11:58:19,372 DEBUG [VideoDAOImpl] Reading a Video (id = 7848)
2011-07-24 11:58:19,372 DEBUG [VideoDeliveryEngine] Delivering item '7848' for client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:58:19,372 DEBUG [VideoDeliveryEngine] Delivering file 'Limitless.2011.1080p.dts.mkv' in native format
2011-07-24 11:58:19,372 DEBUG [MediaItemDAOImpl] Getting file of media item 7848
2011-07-24 11:58:19,373 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 8531626396
2011-07-24 11:58:19,374 DEBUG [ResourceTransportRequestHandler] Sending file back
2011-07-24 11:58:19,374 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Range: bytes 16384-8531642779/8531642780,Content-Length: 8531626396,Date: Sun, 24 Jul 2011 09:58:19 GMT,Server: Windows Server 2008, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-07-24 11:58:21,023 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:1a16184a-7576-37cf-b4be-b37fc8c133cf from address /192.168.0.59:1025
2011-07-24 11:58:21,045 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.59:1025
2011-07-24 11:58:21,323 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:1a16184a-7576-37cf-b4be-b37fc8c133cf from address /192.168.0.59:1025
2011-07-24 11:58:21,324 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.59:1025
2011-07-24 11:58:21,624 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target uuid:1a16184a-7576-37cf-b4be-b37fc8c133cf from address /192.168.0.59:1025
2011-07-24 11:58:21,624 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.59:1025
2011-07-24 11:58:22,751 DEBUG [WebServer] Incoming connection from /192.168.0.59:58367
2011-07-24 11:58:22,751 DEBUG [ResourceTransportRequestHandler] HEAD /resource/7848/MEDIA_ITEM/MATROSKA$0 HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2011-07-24 11:58:22,752 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.59
2011-07-24 11:58:22,752 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.59, Profile=Samsung TV / player (C/D-series)'
2011-07-24 11:58:22,752 DEBUG [ResourceTransportRequestHandler] Request for resource 7848 and type 'MEDIA_ITEM' received
2011-07-24 11:58:22,752 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7848)
2011-07-24 11:58:22,753 DEBUG [VideoDAOImpl] Reading a Video (id = 7848)
2011-07-24 11:58:22,753 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 7848, format MATROSKA and profile Samsung TV / player (C/D-series)
2011-07-24 11:58:22,754 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 7848)
2011-07-24 11:58:22,754 DEBUG [MediaItemDAOImpl] Getting file of media item 7848
2011-07-24 11:58:22,755 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-07-24 11:58:22,755 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-mkv,Content-Length: 8531642780,Date: Sun, 24 Jul 2011 09:58:22 GMT,Server: Windows Server 2008, UPnP/1.0 DLNADOC/1.50, Serviio/0.5.2,Cache-control: no-cache,transferMode.dlna.org: Streaming,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2011-07-24 11:58:22,766 DEBUG [WebServer] Incoming connection from /192.168.0.59:42461
2011-07-24 11:58:22,768 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_SetBookmark"' from 192.168.0.59:
2011-07-24 11:58:22,769 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.59
Thanks for a great dlna server.
thingy
Post Sun Jul 24, 2011 12:05 pm
Re: ffw, rew, jump problem bd-c5900 certain mkv files
Hrrm...
Seems I had forgot to update the library after decompressing the mkv headers with mkvmerge.
After doing that and trying to play the new file, ffw and rew and jumping works.
So that seems to have been the problem.
A new problem occurred however, jumping into the file introduces audio out of sync.
More out of sync the longer the jump.
thingy
Post Sun Jul 24, 2011 12:42 pm
Sync Problem because of bad Framerate in mkv header, when changed to 24000/1001 it went away.
Which is odd since the h264 framerate is reported by ffmpeg as being 23.98 fps. Which I had first put the remerged file to have.
Post Sun Jul 24, 2011 3:48 pm
thingy wrote:Sync Problem because of bad Framerate in mkv header, when changed to 24000/1001 it went away.
So to recap once you fix the broken mkv file ( header compression/bad frame rate ) file plays fine and ffwd/rwd work ??
Users browsing this forum: Google [Bot] and 11 guests
