Audio channel // Codec not supported
libreus
Post Sun Jul 24, 2011 11:02 am
Hello!
I have an issue. When I playback a *.mkv movie through Serviio on the
Samsung C652 the sound is from the second channel and it plays german
audio, while I play it on my mac on Vlc player it plays in english.
I also have an issue playing just one *.mkv movie, on my tv it says
that the codec it's not supported. If you need more details let me
know.
Thank for your help,
Gregor
Post Sun Jul 24, 2011 1:28 pm
Re: Audio channel // Codec not supported
libreus wrote:Hello!
If the mkv movie is delivered in native format, Samsung device could see all audio track, so select in the TV menu the proper audio track
If the mkv movie is transcoded, serviio delivered only the first audio track.
You can use mkvmerge tools to remove no needed audio track.
libreus wrote:I also have an issue playing just one *.mkv movie, on my tv it says
that the codec it's not supported. If you need more details let me know.
Could you provide movies information with "ffmpeg -i" result and MediaInfo tool (see signature link)?
libreus
Post Sun Jul 24, 2011 4:26 pm
Thanks for you reply!
Is this the info you need?
Unique ID : 224203476517238919223068599913504032166 (0xA8AC04D706800B89ADEFED7C3A83C5A6)
Complete name : /Volumes/My Book I/Movies/The American/The American 2010.mkv
Format : Matroska
Format version : Version 2
File size : 9.71 GiB
Duration : 1h 40mn
Overall bit rate : 13.8 Mbps
Movie name : DNL
Encoded date : UTC 2010-12-08 17:20:10
Writing application : mkvmerge v3.2.0 ('Beginnings') built on Feb 12 2010 16:46:17
Writing library : libebml v0.7.9 + libmatroska v0.8.1
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 40mn
Bit rate : 11.8 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Original frame rate : 24.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.228
Stream size : 8.45 GiB (87%)
Writing library : x264 core 79 r1342kMod e8501ef
Encoding settings : cabac=1 / ref=8 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.0:0.1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-3 / threads=6 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=11814 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Format : DTS
Codec ID : A_DTS
Duration : 1h 40mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.06 GiB (11%)
Language : English
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : Bulgarian
Text #2
Format : UTF-8
Language : Croatian
Text #3
Format : UTF-8
Language : Spanish
Text #4
Format : UTF-8
Language : English
libreus
Post Sun Jul 24, 2011 4:50 pm
The sound WORKS!! Thank you!!
libreus
Post Mon Jul 25, 2011 1:34 pm
Anything new?
Post Mon Jul 25, 2011 1:45 pm
libreus
Post Thu Jul 28, 2011 4:35 am
Illico wrote:Look at this: viewtopic.php?f=6&t=1132
It still fails to play... :/
libreus
Post Sat Jul 30, 2011 7:38 pm
Now, two more movies do not play. Any help?
Post Sat Jul 30, 2011 7:40 pm
i dont think AVC video codec is supported by serviio yet so that would be why they dont play..
Post Sun Jul 31, 2011 2:10 am
Cerberus wrote:i dont think AVC video codec is supported by serviio yet so that would be why they dont play..
AVC is H264, so it's supported
staffann
Post Tue Aug 02, 2011 7:49 pm
Maybe the samsung is like my Panasonic tv and doesn't support DTS audio? Then you need to setup a transcoding rule to convert DTS audio to something else (I use ac3).
libreus
Post Sun Aug 07, 2011 4:15 pm
No, it supports Dolby and DTS, so that's not the issue. Well, anyone?
Users browsing this forum: No registered users and 105 guests
